Question about GE 24 in. GLD5860LSS Stainless Still Built-in Dishwasher
I have a GE Quiet Power 2 and the face plate (buttons) stopped working (i.e no lights, sound, action). Is there a fuse for this or something I can dismantle and replace? The dishwasher shares power and the shared sources are still working and the breaker is not tripped. Any suggestions?
    Problem Solver:
  • 19 Answers
Look for a bad fuse on the control board. Soldered in near the power connection. You may see a burn mark from under the fuse.
Posted on Sep 18, 2010
  • Chandler Laws Feb 18, 2012
    do I need to unscrew the control board
Kdc 448u has power but will not work
If you are sure that the unit has power, try resetting the unit. The reset button is on the left of the plug behind the faceplate.
Aug 19, 2012 | Kenwood Kdc448u
I have a GE Quiet Power 3 that has completly died. I cannot get a light to come on or anything to beep when pressing buttons. I checked the circuit breaker and outlet and they are both working fine. I...
A dead set simply means a cut off of power supply. Open the back cover of your dishwasher . Locate the area where the AC cord is located and look for the plastic fuse holder which is usually installed in one of the AC cord line open it and replace the fuse inside with the same amperage or value.
Nov 22, 2010 | Dishwashers
I have a GE GLD5860L15SS Quiet Power 2 dishwasher. Lately, no matter what cycle its on, it will start for approximately 2 minutes, and then shut off. The dishes are wet, so I know water is coming out. How...
Sounds like a motor overload switch. You may have a bind on your motor or a clogged water pump. Try removing the kick plate and take a look underneath. You'd be amazed at what can end up under a dishwasher.
Mar 07, 2010 | GE 24 in. GLD5860LSS Stainless Still...
I have a GE QuietPower3 dishwasher... the normal wash, heated dry, hot wash and hot start buttons are all flashing... can you tell me what is going on please?
try this, I was researching and found that this solution worked. While all the lights are blinking, close the dishwasher door and let the machine run through the cycles. This actually happens pretty fast. Then it will stop and quiet down and all the blinking lights will shut off. Then just press the buttons you want and hit start and the machine will start. The time it takes for the blinking light to shut off is about 1 to 2 minutes. It worked for me.
Aug 09, 2009 | GE Dishwashers
JVC KD -S680 needs help
maybe short circuit or similiar problem inside since its geting hot, probably not a problem with the faceplate I would remove the cd player from your car and take it to a professional for a diagnosis / repair estimate. Can't solve this one with text only.
Jun 18, 2008 | JVC KD-S680 CD Player
Power problems
Try brushing off the contact where the face plate goes on, may have something stopping it from working right
Apr 20, 2008 | Panasonic MXE CQ-C7413U FM / AM Receiver
Microwave stopped working
Generally, you get something unless the fuse inside is blown. There is generally a fuse inside the unit when you remove the button package. First, make sure that the outlet you have is good. Plug something else into it and see that it works.
Dec 16, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Whirlpool Quiet Partner II
press back and forth between hi-tempwash and sani rinse several times to get all lights to come on if not then press sani rinse and heated dry back and forth several times. one of though combos will start the test mode. the test mode will stop the light from blinking and you can use the dishwasher again
Nov 26, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
No Power to face plate
Hello James,You missing a Major supply to the Face,Take a Test lite and Ck to see if your getting voltage on the Memory wire Also ck Fuses ttech
Jul 20, 2007 | Kenwood KDC-2019V CD Player
all radios like your has two power inlets one is battery and the other is Acc or Ing. The battery line keeps power in the radio after you turn off your car both lines must work for the radio to turn on it sounds like a resister burn out thats why your face plate was warm.
Sep 25, 2006 | JVC KD-S680 CD Player
GE 24 in. GLD5860LSS Stainless Still Built-in Dishwasher Logo
395 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
