Question about Sony Cybershot DSC-T200 Digital Camera
DSC-T200 WILL NOT SHOW IMAGE...
When I turn on the camera, the menu and everything works perfectly, the only issue, which in the grand scheme of things IS quite important, there's no image whatsoever. Thinking that maybe that its the screen only, when I take a shot, it also is black. I placed my memory stick in and I can view my old pics. So I'm wondering if there's any type of remedy or repair that I can do, before being forced to take it to get fixed, losing an arm and a leg...
Osiris
  • edcharl Jun 02, 2008
    I have the same problem my camera is DSC-T3 when theres a new solution pls email me at cybermac888@gmail.com
  • markapollo Jun 26, 2008
    Camera takes photos but screen is white in all functions, viewing, taking photos or video. Model is DSC-S40.
  • 10,594 Answers
DSC-T200 has faulty CCD Imager and needs to replace. Sony Service Center will do the job propely.
DSC-T3, your camera has same problem and good news for you is Sony will repair it free of cost.
Check the following Sony web link for details.
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT33&news_id=161
Posted on Jun 21, 2008
I have Sony Cybershot DSC T200 camera. It can take perfect pictures, but I can't see anything in LCD screen as it has colored vertical lines all over the screen. What can be the issue ?
If your pictures taken with the camera are seen when downloaded to the PC, the it is sure that the LCD is faulty or damaged.
The presence of vertical lines show that the processor driver to the LCD has failed. You have confirm cost of the new LCD before it can be decided.
Jul 13, 2011 | Sony Cyber-shot DSC-T500 Digital Camera
Are there any ways to change the language Japanese to English for dsc t200
Touch [HOME] to bring up the main menu. Select Settings (toolbox icon). Select the "A" icon. Select the desired language.
Sep 23, 2010 | Sony Cyber-Shot DSC-T200/B Black Digital...
I have a sony DSC-T200 and the flash won't work. It doesn't even give me the option of turning it on. What do I do?
I had the same problem.
Touch "menu" then under the "rec mode" change from burst to NORMAL.
Then you can touch the flash icon and turn the flash on.
Jul 07, 2010 | Sony Cybershot DSC-T200 Digital Camera
Sony dsc-t200, making a noise and not focusing correctly
Its steady shot magnet sensor fault.if u mechanic cut off the steady shot connection fix steady shot lens in center n fix it its cure
Feb 28, 2010 | Sony Cybershot DSC-T200 Digital Camera
Sony Cyber Shot DSC-T200 The camera motor keeps running creating a blur image I changed the battery but the problem remains
The problem was solved after I called Sony customer support . They directed me how to reset the cameria to its original setting
Thanks
Feb 08, 2010 | Sony Cyber-shot® DSC-T200 Digital Camera
Sony DSC T200 image fault
pls see this link to get help from Sony
http://esupport.sony.com/US/perl/news-item.pl?mdl=DSCT1&news_id=161
http://eservice.sony.com/webrma/web/index.do
pls rate me FIXYA for help
Apr 03, 2009 | Sony Cybershot DSC-T200 Digital Camera
Flash off sign.
I had a similar problem, where the only option on the menu for the flash was off. I initialised the camera (reset everything), and the flash options have reappeared, and it now appears to work fine (initialise is in the settings menu from home).
Dec 31, 2008 | Sony Cybershot DSC-T200 Digital Camera
Digital Camera blurring
It is problem of bad CCD imager IC and this part needs to be replaced.
Sony will repair it free of cost as per announced scheme for this problem in DSC-T1 Camera.
Please click on Sony CCD Support for details. If you are in other country, let me know to guide you more.
Dec 15, 2008 | Sony Cyber-Shot DSC-T1 Digital Camera
Sony DSC-T200
Try initialising the camera (settings menu) - the flash options came back on mine, and the flash worked again.
Jul 09, 2008 | Sony Cybershot DSC-T200 Digital Camera
DSC-T200 "FILE ERROR"
Yes your data card needs to be formatted or replaced. try formatting the card in the setup menu sometimes this helps. Hope this does the trick.
Mar 30, 2008 | Sony Cybershot DSC-T200 Digital Camera
Sony Cybershot DSC-T200 Digital Camera Logo
169 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
