Question about Sony KP-51HW40 51" Rear Projection Television
My sony projection tv have black spot on the about 8 inches by 16inches any sugestion.
    Top Expert:
  • Sony Master
  • 14,553 Answers
If it is a black box, check the menu under closed captions, look to see if TEXT is highlighted.
It can also come from a cable or sat box but the box should only show on some channels.
If this information helped you rate this solution as very helpful as I do this here for free.
SD TECH
Posted on Aug 27, 2010
My sony rear projection tv's red light started blinking 8 times, so I removed the high vltage splitter, so I needed to test the block. And you guys are sugesting for me to turn on the tv, now do I
Turn on very briefly and make sure the large red wire that entered the block is well away from any metal---if hear a frying sound and blink sequence is gone the block is bad( I used to put the wire into a old soda bottle as it has over 20 thousand volts coming out of it, much like the spark plug wires in a car---high voltage with low current.
Nov 01, 2012 | Televison & Video
What indicates the black arrow mark in 16inches,32inches,64inches in steel measuring tape
Typical framing is laid out on 16 inch centers. Example: the studs in a framed wall are 16 inches apart which gives the required strength and allows drywall to break at a stud when it is installed. Drywall sheets are 8 foot or 12 foot, if the framing is on 16 inch centers then the drywall will end at a stud. The tape measure is highlighted at multiples of 16 inches to make it easy to mark the studs when laying out the framing.
Jan 17, 2011 | Peachtree Woodworking 12' LEFT READING...
Black spots on TV when watching sports etc that have white in the picture. The black spots are showing up on the ice for instance (Hockey) all over the TV.
I SUGGEST CLEANING THE LENS ASSEMBLY. IF YOU LOOK ON THE SIDE OF THE TV CABINET YOU WILL A SMALL SQUARE THAT IS ABOUT 4 INCHES BY 6 INCHES HELD IN WITH ONE SCREW IF YOU LOOSEN THAT SCREW YOU WILL BE ABLE TO GET INTO THE CABINET OF THE TV AND CLEAN THE LENS GOOD LUCK
Jan 06, 2011 | JVC HD-52G786 52" Rear Projection HDTV
There is a big black spot on my tv it is a sony hd plasma tv what is it and how can i fix it
where is the black spot located on the tv please explain in details the problem with your tv if you want help.
Mar 01, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
I have a blue spot on the corner and the edge of the screen.
the problem you are having is with the optical block sony had a recall for this but I am pretty sure it has ended you can call sony tech support and see
Jan 25, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Blue spot on screen center. Peoples faces and show blue tint
if you have a Sony LCD projection ..Theres good chance optical block needs replacing .This spot will get bigger and will eventually cover most of screen the longer you use it .needs repair.If there is no warranty on this unit..I would estimate repair around 6- 8 hundred dollars ..
Aug 06, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Projection tv has 2 pictures split with 8 inches of black
IN THE MENU GO TO COLOR CONVERSION OPTIONS AND TRY THAT ,,ALSO TRY NEW CONNECTERS
Apr 24, 2009 | Panasonic PT-52LCX65 44" HDTV
Sony KP-51HW40 51" Rear Projection Television Logo
19 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
