Question about Frigidaire Refrigerators
The fridge has a terrible odor coming from the compressor area.It smells like rotten eggs
SOURCE: Rotten Egg Smell
Repair man told me this is common with front load washers. I was told to put Sunlight dish washing detergent (for dishwashers not hands) in the machine (about 1/2 cup) and do a hot wash with the machine empty.
Posted on May 30, 2007
watugot
  • 290 Answers
SOURCE: Foul rotting vegetable type odor in top of Kenmore refrigerator
If the icemaker motor or heater short out it will cause a foul odor. I have never heard it described as cooked broccoli, but it can be pretty bad. Remove the icemaker and inspect the bottom of it where the heater element is and remove the white cover of the motor and look in there. You can take the three screws out of the motor module and see if anything is burned on it.
If you can rule out the icemaker, the next things to check would be the evaporator fan motor and defrost heater. Generally, if a fan motor starts causing an odor it will stop running completely and if a defrost heater goes out it will quit defrosting. It is possible, but unlikely, that something has gotten into the evaporator area and is sitting on the defrost heater so that it is "cooking" during the defrost cycle.
Check the icemaker first, it is the most likely cause of the odor. Post back with complete model number if you need further assistance and we will go through checking everything else.
Posted on Oct 24, 2007
SOURCE: Refridgerator water odor
I think I fixed the smell problem. Of course it may come back in a few weeks but what I did was I used a large syringe filled with vinegar and pumped that through the lines. I was able to get a really good seal using just the plastic tip of the syringe pressed really hard against my abdomine while I used the water despenser to let the pressure go through the line. I left the filter in because I think the bacteria had contaminated it as well. I kept refilling the syringe and pressing it into the fridge's water line and running the water dispenser at the same time until I got about 10 oz of vinegar in the lines. At that point I could taste the vinegar coming out in the water. I then ran out of vinegar (oops) so I started waiting till I could drive to get more vinegar but gave up after waiting over 1.5 hours (I had a reason why I could not just go and get more). At that point I was kind of worried I might pickle the lines and never get the taste of vinegar out so I reconnected the water lines and flushed the vinegar through (about 2,5 gallons). It seems to still be good tasting after the second day so at least I know the vinegar kills that bacteria, just not sure if I got enough vinegar through to completely fill the lines (it only tasted a little like vinegar when I ran out). I don't think a plumber would know to try this.
Hope this helps others.
Hal
Posted on Jun 21, 2008
  • 362 Answers
SOURCE: 1996 chevy c1500 w/rotten egg smell,loss of power,rough idle
Your catalytic converter is plugged up,  If you check the exhaust output at the tailpipe you will find it restricted.
Let me know if I  can assist further.
Lone99star
Posted on May 08, 2009
SOURCE: Foul odor from back area of fridge/Kenmore bottom freezer
I had the same problem, but just fixed it. I have a maytag bottom freezer and when the fan blower comes on, there was a foul/stale smell that permeated the kitchen. There is no drip pan that I could remove to clean.
I just removed four screws from the back cover of the fan blower area, reached in with a small cup of organic odor remover and poured it into the drip pan just under the fan blower.
Any odor remover would work. probably vinegar or enzyme odor remover would work, too.
I now have fresh smell when the fan blower comes on.
Posted on Jul 11, 2009
I have a Chrysler pt cruiser 2003 , when starting it's mis firing, it has no power when driving and it produces rotten egg smell
you have a clogged up catalytic converter there are some ways to unclog on youtube if you can get to it you can put a piece of wire in a drill and spin it inside to break up the carbon build up its hard to get out best to change good luck with it some people drill holes in it to relieve presure
Mar 19, 2015 | 2003 Chrysler PT Cruiser
What causes rotten odor in exaust
A leaking head gasket. Check the coolant level and if low,, you may need to use some sealer like Blue Devil.
Dec 10, 2014 | Cars & Trucks
Hesitating
check O2 Sensors, add a product called Ametech restore at next oil change, this does wonders for your vehicle, improved my BHP & MPG threefold , also as you say it smells bad (Like rotten eggs?) this will be the catalytic converter, either replace or add a product called cataclean to the fuel & take it for a run, It literally cleans all the **** fro the catalytic converter removing that rotten egg smell
Sep 13, 2012 | 1998 Chevrolet S-10 Pickup
We have a rinnai convector gas heater and when we turn it on it fills the room with a horrible gassy smell.
There are a couple of things that can cause this odor. But, being sure it's really a gassy odor is more important. It must smell like "rotten eggs" to be gas. If that is the odor you're smell, turn the heater of and contact an authorized Rinnai dealer for service.
If however the odor does not meet the "rotten egg smell", there are other things that cause the odor, but it's not really from the heater.
If you have painted or stained within the last 2 weeks, the heater has picked up the odor of the fumes (which you probably didn't notice) and has made time 50 times worse. The same holds true for carpet cleaning or new carpeting odors. If this fits the scenario, discontinue using the heater for a week or two until the odors subside. In the meantime, if weather allows, air the house out. Also, remove and clean the heaters filter, before restarting the heater,
I hope this helped you to troubleshoot & solve the problem.
Jul 11, 2011 | Rinnai Heating & Cooling
We have a terrible odor from fridge side. Cleaned it 3 times..found nothing and odor persists Any suggestion? No odors when doors are closed
What does it smell like? Burnt plastic , mold , rotten food? Check gaskets and temp in fridge, food could be spoiling. It is tough to get serious odors out of fridges. Bleach, vinegar are good for killing odors. Check manufactures recommendations.
Apr 14, 2011 | Viking 42 in Built In Professional...
Foul Odor
Odor from the water softening system can be attributed to several causes.
The best way to see if it is coming from the softener is to by-pass the softener and run the COLD water only for several minutes and see if the smell continues. Now run the HOT water and see if smell is coming from the water heater.
Some causes may be:
1. Hydrogen sulfide in the water supply (the water chemistry can change)
2. Sulfate reducing bacteria. Almost all water supplies have sulfates and if bacteria gets introduced into the plumbing system it acts with the sulfates to create sulfate reducing bacteria. Which creates a rotten egg smell in the water.
3. Salt additives can have many different affects on water chemistry and organics in the water causing musty, fishy, swampy type smells.
4. If you have a system for Tannins using salts with additives will always cause foul smells as it harms the Tannin media.
5. The ANODE rod in the water heater degrades and gives off a sulfur type, rotten egg smell.
RJ
Jul 22, 2010 | Culligan Under Sink Water Filter
My dishwasher smells like rotten eggs. Help!
Had a similar problem and started looking around inside the door. I tried to figure out how to remove the plastic air vent cover on the inside of the door (left side). I couldn't figure out how to remove it. So, we purchased a dishwasher cleaner at Lowe's ($4) and tired running it through the machine to see if it would correct the odor problem. It didn't. Somehow the "little lady" did manage to remove it (used a damn table knife of all things) twisted and popped the plastic air vent off. When it was removed she found the obvious problem, black foul smelling mold was growing under the plastic air vent that was radiating its terrible smell into the kitchen through the dishwasher door kitchen side vent . She cleaned the inside vent and the odor problem has left. I guess I'll never live this down, but I must admit that my wife solved the problem. Try this solution and see if it solves your problem. Let us know how you make out!
Humble Steve
Jun 27, 2010 | Whirlpool 24 in. ADP5966 Free-standing...
Odor from outside of Refrigerator
pull out the fridge and remove the back panel, and clean that area. Make sure no food is stuck under the fridge also. A rotten piece of fruit or other food, once under there, will smell until it totally decomposes. We have seen this before. Hope this helps!
Feb 13, 2009 | Kenmore 18.3 cu. ft. Top Freezer...
Refrigerators Logo
63 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
