I wan to add a powered speaker system (Boise), Which slot should I use, Headphone or Audio and what size plugs to I need? Thank you.
  • bfarmbruster Aug 27, 2010
    Yes, thank you!!!
  • 10,865 Answers
Hello. Since the speaker is powered, you can use either. The minijack plug and the 1/4 inch plug should both work but check to be sure. If it doesn't fit.......
Posted on Aug 27, 2010
I cant get sound on my viewsonic va520
You need to add some information - what is the source for the video that you are viewing on the VA520? The VA520 has no speakers in it. If it is a desktop computer, look on the back of the computer for a green 3.5 mm stereo audio port. This is your speaker out connection. Plug in any set of computer speakers or headphones. (Computer speakers may require a USB connection or to be plugged into an AC outlet to power the speakers.) You can find cheap speakers for under $20; good speakers will be more expensive. With a laptop or some desktops, you'll find a headphone jack on the front of the computer. (This will be labeled with a small picture of a set of headphones.) The headphone jack is also a 3.5 mm stereo port.
I hope this helps.
(laptops usually have internal speakers; most desktops do not have any internal speaker anymore. If you have headphones with RCA audio plugs, you can use a RCA F/F to 3.5 mm M audio adapter to use them with the computer. A stereo system may not work with a computer.)
Jul 24, 2012 | ViewSonic VA520 15" Flat Panel LCD Monitor
Boise
What model of TV are you hooking the Bose system pls? Alternately, determine if the TV you are hooking it into has a pair of white and red RCA connector marked Audio OUT.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Oct 14, 2008 | Bose 3 2 1 GSX System
My speakers are plugged into the computer they're power is on and they are'nt working
You must confirm that they are plugged into the correct output and also into a power source. If they are powered speakers it can either be the audio out or the headphone jack, if they are not powered then they have to be plugged into the headphone jack. Next confirm the audio driver is correctly installed. Finally confirm that the system sound and the sound for whichever program you are using is not muted.
Jul 14, 2011 | Cyber Acoustics CA-2014 Computer Speakers
If I hook up a set of headphones to the slot on the side of the TV the sound goes off and you can only hear sound through the headphones, no one else in the room can hear the TV. Is there a way to hook...
The headphone jack on the TV has switch built-in to kill the TV speakers when headphne jack is used, you need to use powered PC speakers with headphone jack and connect this PC speakers to the Audio line out of the TV set (RED and WHITE RCA audio line out). Basically the powered PC speakers are being used a headphone driver. Or you can get one of those wirless headphone system instead.
Jun 27, 2010 | Televison & Video
No audio thru the speakers, headphones only
you answered your question. let me explain: the head phone plug is a switch- that disconnects the speaker and only allows sound to the headset. the switch is either broken, loose-wire or dislodged.need to get inside the unit, You could of course get creative. put an adaptor to the headphone jack;the adaptor can now allow you to run wires to the speakers. adaptor is avail from radioshack-same size as on the headset.
Mar 04, 2010 | Philips MCM530 CD Shelf System
Adding Spaekers
If it's an original 321 system (series 1) then it has an audio output on the back. (via RCA jacks) You would still need an amp or receiver to connect the speakers to.. (unless they're powered speakers)
If it's a 321 series II or 321 series III- it does not have an audio output.
If the system has a DVD tray right in the middle of the media center, then it's a series 1.
Otherwise, you'd have to get a 1/8 splitter to come from your Mac's headphone output. (still- you will need an amp/receiver or powered speakers to have both 'rooms' playing the same thing from your computer)
May 29, 2009 | Bose 3 2 1 GSX System
Headphone jack size
Headphone jacks are either 1/4" or 1/8". If it's about the size of a pencil, its 1/4". If it's more like the size of your mouse wire, it's 1/8".
Apr 16, 2009 | Aiwa NSX-AJ20 CD Shelf System
My sony dav-s-400 system keeps activating headphone port output.
Just had and fixed the same problem that hundreds of people are suffering with this system!!
Sony DAV s400 - same problem, won't play though speakers and display indicates that headphones are plugged in - when they are not. Fairly easy to fix and took me less than an hour from start to finish:
1) Remove top cover
2) Remove circuit board that has Audio In/Out phono scockets (to get access to Amplifier Circuit Board)
3) Remove Amplifier circuit board (has the speakers attached)
4) Turn it over and remove copper heat shield
5) Resolder joints where the big brown capacitor is and where the wires go to the front headphone socket...and any other dodgy joints that you find
6) Reassemble.
Feb 03, 2009 | Sony DAV-S400 System
Need to over-ride built-in speakers so desktop speakers work. Ever since I hooked up my Compac W17q monitor, the built-in speakers have taken over, but I want my desktop speakers for sound instead. How can...
Assuming your using a Windows operating system, you need to got to the sound settings and set your computers soundcard as the preferred output device. (Its under Control Panel > Sounds and Audio Devices in XP)
Aug 26, 2008 | Compaq 17" Flat Screen CRT Monitor
Boise
yes you can.
just have your audio out from your tv going into an audio input on the bose system.
Aug 01, 2008 | Bose 3 2 1 GSX System
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
