Question about Roper Refrigerators
I have a Roper Frost Free top freezer model Model@RT16DKXXW06 Serial#EB2423742 Type#16ATR92 Mfg 06/92 the pats 6-8 weeks it has been leaking water on the floor I assume from the defrost cycle. What can I do to stop this Is there a drain I need to clean out or a drip pan I'm unaware of that I need to clean?
  • 139 Answers
Yes the drain is in the rear of the freezer ..you will need to remove the covers on the bottom and the back to see the drain..remove all the ice buildup on the bottom ..then use hot water to thaw drain...the reason for the line freezing up is freezer is set to cold freezing leftover water from defrost..let me know good luck/joe/
Posted on Aug 27, 2010
Frost free freezer issues
Can you provide a number? Please the model number is important
Appliance 911 Sea Breeze
Leaking Refrigerators
Sep 25, 2015 | LG Refrigerators
My Roper refrigerator has water inside it at the bottom and on lower level shelves. How can I correct this?
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Good luck
I hope this helps
Gene
Aug 01, 2011 | Roper RT21AKXKQ Top Freezer Refrigerator
Water is leaking under the refrigerator. This is
If everything else on the refrigerator seems fine (freezing and refrigerating are fine), then you probably have a problem with the drain hose under the evaporator coil. On frost free freezers, there is a heater that comes on periodically to melt off all the frost on the evaporator coil, and that defrosted frost (water) goes out a drain hose and collects in a pan at the back of the unit where it can evaporate.
Either the drain is clogged with ice inside the freezer, (in which case you might notice ice building up on the bottom of the freezer, or perhaps water collecting on the bottom of the refrigerator if your freezer is on top) OR there is something wrong with the pan at the back of the refrigerator, like a crack, or it somehow got tilted so that the water pours out. It is located behind the panel on the back.
Or perhaps, and this would really ****, the water line that supplies your ice maker is leaking, if you have one. If you do have one, I would recommend turning the water line to the fridge off before pulling the fridge out.
Sep 14, 2009 | Kenmore Refrigerators
Too much water coming out of the pan (in the front of the ice maker) and copper pipes on top left side are covered with ice.
Not real sure just what you are saying as to what pan? The copper pipes that go to the evap plates where the ice is made are supposed to frost over. They get colder than dew point of the air so this is normal. But all the pipes should frost. Does the unit shut down and give any type of beeping noises? This would be the control giving you a trouble code. You may have a water valve leaking. Turn unit off and see if water continues to run. All water should stop within a few seconds. Let me know what you find. Please verify model and serial numbers.
Aug 13, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Leaking water inside fridge/freezes the food
Most likely your defrost condensate drain in the rear of your freeze is frozen over. I have put together a long page on the link below. Little too much about leaks in refrigerators and how to solve the problem to fit this page. Choose the part that applies most to your situation and let me know how I may help you resolve yours. I'll be here if you need so click on the link below, Thanks, Sea Breeze
HOW TO FIX A DRAIN LEAK INSIDE REFRIGERATOR AND FREEZER PART 2
Aug 13, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Proline freezer door leaking
If this is not a frost free model It sounds like you have a freon leak. This is almost never worth fixing. Any fix would be temporary. You can never really trust it again.
If it is a frost free model it could be just stuck in defrost. Most commonly the defrost timer.
Jun 30, 2008 | Freezers
Defroster leaks
you have a cloged evap. drain. the rf is defrosting properly but with the drain be clogged the water has to go somewhere which is generally in the crisper draws on top and bottom models. two way to clear up this issue. turn rf OFF for at least 48 to 72 hrs. to allow the drain to de-ice or take matters into your own hands and take the back panel off of the freezer and using boiling hot water pour it down the evap. drain tube until it flows like you just flushed a tiolet
Jun 01, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Water leaking from inside of refrig.I think it could be Ice maker
defrost the freezer drain tube with a hair dryer
May 09, 2008 | Refrigerators
Refrigerators Logo
49 people viewed this question
Top Roper Refrigerators Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Sal DeAngelo
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
