Question about D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B)
My D link ADSL2 plus router work fine thru ethernet cable but has no wireless signal
    Sergeant:
  • 223 Answers
While connected with a wire surf using internet explorer into the routers console its either at 192.168.0.1 or 192.168.1.1 (most of the time anyway) , Enter the username and pass to get in, often both are admin or admin and blank. check the wireless tab settings in there to see if its enabled and configured.
Posted on Aug 27, 2010
  • Trevor Groves
    Trevor Groves Aug 28, 2010
    Did this help you, do you have any other questions?
  • Trevor Groves
    Please use the solution rating if your problem has been solved, or make a note if your still having trouble. Thanks! Gurvy
What kind of cable do I need to go from my modem to my roku?
RJ 45 (Ethernet) Cable should work.
Otherwise you can try connecting it to the WiFi Network.
Apr 03, 2014 | D-Link ADSL2/2+ Modem/Wireless Router...
I have a D-Link DSBroadBand G ADSL2+router. I cannot access the internet with the ether cable plugged in. I can access the internet via wireless and the ethernet cable with a laptop. I am able to access...
I suspect that your ethernet adapter has been made 'not enabled', but can't explain how to check it since I don't know which version of windows you're running. If you can get to the Device Driver panel, you can change it there...
May 02, 2011 | D-Link ADSL2/2+ Modem/Wireless Router...
Need help! Cannot access YAHOO and FACEBOOK,Thru tp link wired router (TL-R402M). Hope you can help me with my problem. Thanks! Jun Santos
try power cycle by removing the power of the router for one minute then plug it again. check the cable if all of it tightly connected to the specified port if it is a modem router it should have a 3 cable connected to it Phone line, Ethernet cable and the power adapter. the Ethernet cable should be connect to the back of your tower( computer). check you phone for a dial tone. check the light in the router like dsl , ethernet ,internet and activity. all of these must have a light.
Apr 14, 2011 | TP-LINK TPLink 4port ADSL2 Wired Route...
Recently i am using a d-link glb-802c router modem.i have noticed that i can access net without ethernet cable & the lan led is not lit when i am using this.is this abnormal?
This is a wireless router, so yes, you should be able to access the internet without a cable. The router also only supports wired lan, not wireless.
Aug 26, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
My ADSL 2+ works fine with wireless, but not with a local area connection. My PC uses this. I,ve switched cables, tried a cable with the laptop, and reset the router. No change. Any ideas? Steve
If the wireless connection is working fine it show that your internet security is fine and you can access net without problem
there could be a connection issues a within the cables
1) Connect the Ethernet cable to the Laptop and connect the other end to router E1.
2) Open the command windows (DOS ) by typing cmd or command on the Run option ..
START- RUN- type command then hit Enter
3) In the black command windows - Type IPCONFIG
c:\> IPCONFIG hit enter
it will provide with the correct IP ADDRESS and Gate Way Address
Check the gateway address - shout strat with 192.168.X.X
If it is not there is some problem -
4) Check the Device manager and check the Ethernet Adapter whether the adapter is enabled or Disables or Drivers are installed or not
Aug 10, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
D-link G524-T router; this works fine with a
If you get the same speed on all three computers, I'd recommend replacing the router. I can't imagine any possible configuration setting that would cause a router to communicate at only 10KB over a wired Ethernet channel.
Nov 25, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Need drivers for DSL-G624t wireless router
If you're connecting to the router by ethernet cable or wirelessly, you dont need drivers unless you mean the drivers for the ethernet adapter and/or wireless adpater in your PC.
If this is what you're after, your PC's manufacturer's website is the best place to look if you dont have them on CD/DVD.
If you're connecting to the router by USB port, then the D-Link webiste should have the drivers for downloading.
Sep 13, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
I am unable to connect through wirelss
You may need to go in, and configure the wireless part of the router.
From a wired computer, try going to http://192.168.0.1
This will allow you to configure the wireless portion.  The manual that came with your router will have your default admin username and password, as well as the instructions on how to configure the wireless part of the network.
Mar 19, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Trying ti install my dsl-2640b wireless g adsl2+modem router
If you have plugged the ethernet cable directly into the motherboard, make sure the onboard lan is enabled in the bios, if you have plugged into a pci nic adapter you will have to install a driver for it, winxp should have the driver for your adapter other than that I cannot help any further.
best of luck
Ray Winter
Dec 30, 2008 | D-Link ADSL2/2+ Modem/Wireless Router...
Belkin Wireless G wont connect to cable modem
If you switched ISP then you have tor reconfigure your router according to the settings of your new ISP.
Aug 24, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
D-Link ADSL2/2+ Modem/Wireless Router 4-Port Switch, 802.11g, QoS (DSL-2640B) Logo
83 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
