Question about HP Pavilion a1540n PC Desktop
Installing 1 gig of memopry in third slot - snaps on the end of the slots will not close. The first two slots are blue - the next two slots are black and the snaps on the end of the black slots are not notched like the ones on the bule slots.
  • HP Master
  • 27,725 Answers
Make sure the largest memory module is in the slot closest to CPU then push down firmly each end of the ram module
as for the notches the one with one notch is ddr ram the one with 2 notches sdram make sure that the module you are trying to install matches the slots and some brands are not combatible with other brands
good luck
Posted on Aug 27, 2010
  • rh5085 Aug 29, 2010
    Look, please read the words again:
    installing 1 gig of memopry in third slot - snaps on the end of the slots will not close. The first two slots are blue - the next two slots are black and the SNAPS on the end of the black slots are NOT notched like the ones on the bule slots.
    Memory card are identical but white levers that snap to hold the memory cards in are different, the levers on the first two slots are a little wider and are notched,
How do I replace ink jet in officejet 4500
Step one: Remove the old cartridges
1. Press the power button to turn on the product
2. Open the front access door. The carriage moves to the far right side of the product
3. Wait until the carriage is idle and silent, and then lightly press down on the cartridge to release it.
To replace the tri-color cartridge, remove the cartridge from the slot on the left.
To replace the black cartridge, remove the cartridge from the slot on the right.
Pull the cartridge toward you out of its slot.
Step two: Install the new cartridges
1. Remove the new cartridge from its packaging. Be careful to touch only the black plastic.
2. Gently remove the plastic tape by pulling the pink pull tab
3. Hold the cartridge with the HP logo on top, and insert the new cartridge into the empty cartridge slot. Make sure you push the cartridge in firmly until it snaps into place.
If you are installing the tri-color cartridge, slide it into the left slot.
If you are installing a black cartridge, slide it into the right slot.
4. Close the front access door.
May 27, 2013 | HEWLETT-PACKARD Officejet 4500 All-in-One...
What's your problem?bit ix38 quad gt motherboard with 2 gig of ddr2 ram i want to add a 1 gig stick of more ram that ive bought how do i do this? thanks windows seven
Top view of motherboard, scroll down. (Thought you might also like to read the reviews, and Comments)
http://www.bit-tech.net/hardware/motherboards/2007/12/06/abit_ix38_quadgt/2
Motherboard User Manual,
http://www.theraptorpit.com/forum/index.php?/forum/124-abit-motherboard-tech-support-unofficial/
1) On the motherboard the Blue ram memory slot that is closest to the copper heatsink, is ram memory Slot 1.
Also known as DIMM 1.
Ram memory ALWAYS has to be in this ram memory slot.
The Processor reads ram memory Slot 1 first.
2) The Blue ram memory slots are Slot 1 (DIMM 1), and Slot 3.
(DIMM 3)
The Black ram memory slots are Slot 2 (DIMM 2), and Slot 4.
(DIMM 4)
To run Dual Channel ram memory, means there are two LIKE ram memory modules ('Stick'), and they are installed in the SAME channel.
This would mean to alike ram memory modules, in both Blue ram memory slots, or both Black ram memory slots.
Since the ram memory modules need to be alike, they are generally purchased from the same manufacturer, and are the same kind.
Running ram memory in a dual channel configuration, is supposed to increase ram memory 'speed', up to 30 percent.
This is Baloney!
May look good on paper, but in actual use in the field it's cr@p.
Actual performance increase is more like 1 to 2 percent.
This has been proven by Tom's Hardware, and many, many motherboards, ram memory, Processors, etc.
So you have 2GB of DDR2 Sdram, huh?
Is it just one 'stick' of ram memory, or are you referring to two 1GB sticks?
If the above holds true install them in Slot 1 and Slot 3.
If not, and it is a 2GB stick of ram memory, be sure it is installed in Slot 1 (DIMM 1)
Install the 1GB stick in Slot 2.
It isn't the same as the 2GB stick.
It is 1GB.
Does NOT go in a dual channel configuration.
(Catching all this? There is NO dual channel ram memory!
It is ram memory that is -> ALIKE, and used in a -> dual channel configuration.
Used in two separate ram memory slots, that support the dual channel configuration.
Sold with the advertising scheme of 'Dual Channel', but really just means the two ram memory modules, (Or four), are -> alike.
1) Same Voltage used
2) Same Ram Timings
3) Same Chip Configuration
4) Same size in amount
5) Same frequency rate ('Speed')
With ram memory in a dual channel configuration, the ram memory modules team up on the task.)
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 31, 2012 | Computers & Internet
Hi. I have a P8H67 ASUS mother board. it has two PCI 16 Express slots. the first slot is Blue and second slot is black. When I put my 1 GIG DDR2 9500 GT graphic card in the first slot, it gives me 3 beeps...
There are 4 types of expansion slots on this motherboard.
The expansion slots on this motherboard are as follows.
Expansion Slots 1 x PCIe 2.0 x16 (blue)
1 x PCIe 2.0 x16 (x4 mode, black)
1 x PCIe 2.0 x1
1 x PCI
Sep 03, 2011 | ASUS US P8H67M PRO Desktop Motherboard...
I have an HP OfficeJet V40xi. My problem was getting an "cartridge black installed error" but it was properly installed! I am not try replacing with other cartridge yet...that might it be the...
The cartridge slots are not interchangeable so you will not put the color in the black etc.
Many HP printers will detect third party and re-filled ink cartridges and refuse to accept them. There is no way to override this in the software package.
I had a third party re-man ink cartridge work for two days and then the HP decided it didn't like it.
Apr 15, 2011 | HP OfficeJet V40xi InkJet Printer
How to load the ink cartridge
Replacing the print cartridges
  1. Make sure the HP all-in-one is on. WARNING: If the HP all-in-one is off when the print-carriage access door is lifted to access the print cartridges, the HP all-in-one will not release the cartridges for changing. Damage may occur to the HP all-in-one if the print cartridges are not docked safely on the right side when you try to remove them.
  2. Open the print-carriage access door by lifting from the front center of the device, until the door locks into place. The print carriage is on the far right side of the HP all-in-one. c00228292.jpg 1 - Print carriage access door 2 - Print carriage
  3. When the print carriage is idle and silent, press down on the end of each cartridge to snap it out of the carriage. If replacing the tri-color print cartridge, remove the print cartridge from the slot on the left. If replacing the black or photo cartridge, remove the print cartridge from the slot on the right. c00228293.jpg 1 - Print cartridge slot for the tri-color print cartridge 2 - Print cartridge slot for the black and photo print
  4. Gently pull the print cartridge toward you, out of its slot.
  5. If removing the black print cartridge to install the photo or gray photo print cartridge, store the black print cartridge in the print cartridge protector.
  6. Remove the new print cartridge from its packaging and, being careful to touch only the black plastic, gently remove the plastic tape by using the pink pull tab. CAUTION: Do not touch the copper-colored contacts or ink nozzles. Touching these parts can result in clogs, ink failure, and bad electrical connections. c00228294.jpg 1 - Copper-colored contacts 2 - Plastic tape with pink pull tab (must be removed before installing) 3 - Ink nozzles under tape c00228295.jpg
  7. Slide the new print cartridge forward into the empty slot. Push the print cartridge forward until it clicks into place. If the print cartridge you are installing has a white triangle on its label, slide the print cartridge into the slot on the left. The label for the slot is green with a solid white triangle on it. If the print cartridge you are installing has a white square or a white pentagon on its label, slide the print cartridge into the slot on the right. The label for the slot is black with a solid white square and a solid white pentagon on it. c00228296.jpg
Jan 14, 2011 | HP OfficeJet 6210 All-In-One InkJet...
How do i open dell 4600 to install RAM
Do be aware that this is older type motherboard adn will support only 512mb per slot. It have 4 slots and can therefore handle 2gb RAM in total. If you flushed BIOS with newest one, it may handle 1gb chips, but it is very finicky on that. You need to use slow memory, 184pin. I would not go higher than PC3200 (400MHz).
Now, you will need philips screwdriver, the procedure:
1. switch off computer and remove power cord from it
2. disconnect powered auxilliaries (monitor, external hard driver, similiar)
3. remove 2 (two only!!!) screws holding left side panel (that is left while you are looking at front of the computer) and slide panel out towards back, lifting it slightly.
4. locate processor and next to it, towards front of the computer are located 4 memory slots.
5. push outward little tabs on each end of memory slot
6. remove old memory by lifting it out, sometime they need bit of wiggling
7. align new memory notch and firmly press into memory slot till end tabbs close, you may help them bit by closing them in full on the end of they travel
8. new memory should be installed in pairs, first pair is going to slot 1 (closest to the processor), and slot 2 (third from the processor), if you install four sticks, next pair is going slot 3 (second form the processor) and slot 4 (furthets form the processor).
9. check and whiggle in all wires which you may touch during installation
10. close the case and re-do screws
11. remove and re-insert all cables on the back
12. connect monitor
13. connect power and switch on your monitor and computer
I would not upgrade memory on this motherboard above 2gb, especially if operating system is windows xp, windows xp do not handle memory above 2gb very well, and do not handle abow 3gb at all.
Let me know how did you go! :-)
Aug 13, 2010 | Dell Dimension 4600 PC Desktop
Ram
Okay, you don't need two video cards. Your 4 memory slots are grouped in two's. One set is black and blue, and the other set is black and blue also. These are your dual memory channels.
The reason you can't see more than 2 gig ram is because you are probably not running 64 bit Windows with a 64 bit processor.
32 bit windows will only display 2 gigs, but max memory is 4 gigs. It will draw on the extra 2 gigs if ever it is needed, but this does not happen very often, if ever.
Hank
Jul 14, 2009 | ASUS A8N-SLI Deluxe nVidia nForce4 SLI...
Wont boot 2 windows xp home when 2 gig memory installed,works with 1 gig,tried both slots with both 1 gig sticks.Screen goes black.
Seems the memory is not comatable with the motherboard. Replace the old memory and visit http://www.crucial.com, they have a scanner tool which will confirm what mem can be installed.
Apr 30, 2009 | Computers & Internet
Asus P6T Deluxe motherboard won't post with 3rd RAM DIMM
that port is bad. If all three is known working the only explanation is that its a bad ram slot
Mar 29, 2009 | Computers & Internet
HP Pavilion a1540n  PC Desktop Logo
29 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
