Question about Mitsubishi WD-60735 Projection Television
Have a Mitsubishi TV wd60735 the tv volume just increases to max by itself, sometimes won't turn on, sometimes no remotes will work it and I have to pull the plug to reset it to get it to come on, have it on av surround now and the audio menu bar comes up and stays on saying tv speakers off, what is it and what do I need to fix these problems?
    New Friend:
  • 74 Answers
Sounds like your tact switches on the front of the TV are shorting out. Unplug the plug for the switches. if the problem goes away then try to clean the switches with rubbing alcohol, if still has problem replace switches.
Posted on Aug 27, 2010
Volume goes max and will not lower.
Hello
Please remove the batteries from the remote and check whether it is possible to use the local keypad on the TV? If the volume increases, it may be a problem in the local keyboard.
Apr 02, 2014 | Samsung LN32B550 32 in. LCD HDTV
Volume moves up and down by itself and then stays max volume
sounds like the main system board is kaplooiee..
well..do you like to dig into this sort of thing?..it will take around 400 and 2 to 3 hours..
Oct 28, 2008 | Mitsubishi WS-55511 55" Rear Projection...
TV volume increases by itself and doesn't decrease or respond to the remote control
Connect all A / V sources to the Home Theater Receiver then Video-Out from the receiver and totally mute) the TV.
Sep 30, 2008 | Soyo DYLT032D 32 in. LCD Television
Volume on the WD 57733 turns up to full blast by itself. Cannot turn on the mute button using the remote.
volume button on your remote is stuck in the increase position. try another remote if possible or remove the remote batteries so you can atleast use the TV manually
Dec 23, 2013 | Mitsubishi WD-57733 57" HDTV
LG TV 32H3300 - volume increasing and decreasing by itself. It will increase if it was turned up via remote last and then will decrease by itself when volume is decreased via remote because it was too...
The cause of the problem is that the switch of your tv is dirty when cleaning it you must be familiar to the unit and the parts you will remove to prevent any damage you can use a contact cleaner, when applying a contact cleaner you must only spray it to the switch. Consult a expert technician to do it for you actual.
May 15, 2011 | Televison & Video
Volume pegs to max. Turns itself on. Goes to menu. Intermittent
This is becoz your Internal Remote control response program chip needs to be replaced! You need it to get repaired at nearest service station. Or it may be due to Your keys pressed continously from remote control. Check both the causes! then decide. It will help you!
Dec 23, 2007 | RCA F38310 38" TV
I have a Mitsubishi 73"
i would suspect your control buttons on your front panel on the set have become shorted. specifically the volume buttom down. This is freezing you control functions. like someone is holding the volume down button all the time. or intermitantly. this cuircit board is on front of the set. I have seen this problem a few times at the shop. The common repair is to replace that button assembly cuircit board. I believe the last time it cost the customer around 85 dollars, but like all things depends on the part and the technician that puts it in.
Apr 21, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
Why does my 26 insignia do the following without touching the remote: volume up and down, changes channels and menu screen pops up
It could well be your remote control has a problem. Try removing the batteries from the remote control and see if the problem goes away, if it does, try new bateries on the remote controller, if that does not work you may have to get a new remote controller
Mar 24, 2010 | Insignia LCDTV26 26 in. Television
Volume increases to max, screen blinks, remote becomes useless
All I can offer as help is to disconnect the TV from the mains power completely and go away and leave it for an hour or so or even overnight. Then plug it back in and possibly it will behave itself again. BMW
Jun 07, 2006 | Mitsubishi WT-42311 42" Rear Projection...
Mitsubishi WD-60735 Projection Television Logo
214 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
