Question about Kenmore Washing Machines
Washer not agitating or spinning, when the washer was tipped to access gearcase there was a pin on the ground.. I know it came from thr washer, but where?
  • 139 Answers
Check the lid switch if it is out /or the metal bracket .is off the washer will not operate ..you need to pop the top section of the washer to get to the switch ..their are metal clips that hold it down in the front ..so get a flash light to find them they are about 3 inches from the sides in the seam of the top section of washer...let me know ..good luck/joe/
Posted on Aug 27, 2010
Kenmore 80 Model #11020802990 Won't Spin!!
i think you have a basket drive tube problem, what happened to mine was the thrust washer had ground off the bottom of my tube,the clip that holds the brake release arm fell off,the arm fell down breaking the 2 little pins on it, without that arm on the tube it won't release the brake allowing the basket to spin, you would have to remove the tranny to see if there is a problem there,,,,,also the top of the tube there is 2 notches that line up in your drive block,could be broken there,,,,you would have to remove the agitator to check there!
Feb 20, 2010 | Kenmore 24032\24036 Top Load Washer
Washer fills agitates and drains but wont spin kenmore 800 series
sounds like you need a drive coupling. tip the machine back and remove the motor and pump. the coupling is between the motor and gearcase.
Feb 07, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore washer agitates on spin cycle
Obviously the washer should be either just spinning or agitating. The transmission ,or in this style washer it is called the gearcase, is bad and would need to be replaced. The gearcase controls the spin and the agitate in this washer. The part number is 3360629 and retails for $172.77. To replace; Unplug washer, remove the 2 trim pieces on either side of the console, remove the 2 screws under the trim, lift the console and rotate to the back, remove the 2 retainers going from the back into the cabinet, remove the cabinet, remove the drain pump, remove the motor, remove the agitator, remove the gearcase with 3 bolts holding it on. The gearcase will now slide out of the washer. Transfer the clutch and motor mounting plate to the new gearcase and reassemble in the reverse order.
Thank you
Jan 23, 2010 | Washing Machines
Washer will not agitiate or spin
Motor coupler between motor and gearcase.
Mar 30, 2009 | Kenmore 24032\24036 Top Load Washer
Whirlpool washer won't spin
most likely just clutch ck for oil or water on it if oil most likely top seal gearcase is leaking ..remove agitator cap remove bolt in middle of agitator ..remove console screws remove clips under console holding cabinet on remove cabinet ..lean washer back remove pump then motor remove the 3 bolts holding gearcase in remove gearcase clutch is silver disk on top of gearcase with band inside ..band is actual clutch may try cleaning it but not hopeful about it being a permanet fix
Nov 12, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Ultimate Care II washer won't spin clothes more dry than soggy
Tip the washer backward, inspect the bottom of the gearcase for oil. If oil is present, the oil has migrated to the clutch causing it to slip during spin. The gearcase and clutch will have to be replaced if oil is present. Check the owners manual for limited warranty on the gearcase. If oil is not present, the clutch is just worn and should be replaced.
Oct 04, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Kenmore washer
If your washer is not spinning fast enough, or barely spinning at all, this is usually a symptom of any one or all of the following: 1. Bad gearcase (transmission). 2. Bad basket drive, with which the transmission couples to under the agitator. 3. Bad clutch/brake assembly. Which mounts on top of the gearcase under the basket drive. Usually a tell tale sign of a gearcase beginning to fail is the sign of an amber colored oil coated under the washer or inside the casing. I said, "usually". It doesn't always happen, but if you notice any signs of oil, the gearcase is shot. The basket drive and clutch assemblies are harder to diagnose and require some disassembly of the washer and the removal of the gearcase to inspect. Let me know if this helps.
Aug 01, 2007 | Kenmore 22642 Top Load Washer
Series 90
rack, on these direct drive Kenmores, any time you have the washer spinning and agitating at the same time, it is a gearcase problem. The gearcase is covered under warranty for 5 years. Probably around 133.00 labor. Catriver..post back.
Oct 02, 2006 | Kenmore 15864/15862 Top Load Washer
Trouble with constant spin
If your Kenmore is agitating and spinning at the same time then you have a gearcase problem. The gearcase is warranteed for 5 years part only. The labor would run around 133.00 Your model is a direct drive washer and changing out the gearcase is not that bad of a job. Part number for the gearcase is 3360630. Catriver..post back.
Jul 31, 2006 | Kenmore 22622 Top Load Washer
Washing Machines Logo
16 people viewed this question
Sal DeAngelo
fordexpert
Mike Carew
