Question about KitchenAid Dishwashers
The dishwasher does not pump out the water; left with yucky nasty white-colored at the end of cycles. We've tried three different cycles and it will not pump out the water. Help Yuk!
    Champion:
  • 245 Answers
Either your water pump is bad or most common problem is your drain line is either crimped or clogged.
Posted on Aug 27, 2010
How do I get rid of white residue on dishes in dishwasher?
if its hard ? then its minerals in your houses water , install a demineralize filter on the washer line , if it flakes off with your finger nail then its left over soap , your using too much or your water pump needs cleaned out or replaced
Aug 15, 2016 | Kenmore Dishwashers
Lights 1 and 2 flashing indesit IDL40
I used the solution above and my dishwasher now working!!! I would add, plenty of towels and a tray or three to catch the stinking water that comes out of the outfow when you tip it up. Yes 6 screws to remove the back, but on the Indesit IDL40 two additional longer screws in the centre are helpful to remove. Then just tuck the bit that was attached out of the way. My pump was cream and white - check out pumps online to see what they look like. Undo the one screw holding the pump in place and then you have to twist it to release three little pegs. I washed outs loads of small bits of grit. Then easy to put back together. Re-attach the drain pipe to your drain, electric plug at wall and water inflow pipe. (Check for leaks!) I am so happy! Took me two hours but I had to hunt for the info and find the hidden screwdrivers. Husband will be pleased I think.
Jan 11, 2014 | Indesit 18 in. D41 Slim-Line Free-standing...
Nasty white residue left on dishes at end of cycle, and dishes not cleaned
The ****, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and **** in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101
Aug 23, 2011 | Kenmore Dishwashers
Our dishes are coming out partially dirty with a layer of soap scum on them. We have tried three different types of soap and nothing is helping.
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle.
Hope this helps... Please post back if more information is required.
Daniel
Jan 07, 2011 | Frigidaire 24 in. FDB635RF Built-in...
My Bosch dishwasher is taking hours (at least 3 - maybe more) to complete a cycle. There is gummy, yucky stuff building up inside - sorta pinkish brownish. Could the water not be hot enough? A couple of...
if your on demand heater is one of the small ones that mounts under the sink, it will not flow enough water to fill your dishwasher. the dishwasher is waiting for the water level to fill before it starts washing. your bosch will heat its own water. hook it up to a cold line ahead of the water heater so that the fill valve is fed with full pressure. the residue sounds like detergent build up. when you get the water issue resolved, run a few cycles with no dishes and no detergent, on the highest temp setting. add a cup or two of white vinegar or dishwasher cleaner ( order online or get from an appliance repair store) through it. Dont forget your dishwasher has a filter in the bottom under the spray arm that needs to be cleaned periodically. if you dont clean it once a month it will get all kinds of nasty stuff built up in there.
Nov 20, 2010 | Bosch SHX46A07UC Built-in Dishwasher
Water left in bottom of dishwasher after cycle
a little water is supposed to remain in bottom so that pump will not lose prime
Nov 07, 2009 | Dishwashers
Diswasher Pump won't stop running
Introduction: This may work for your problem, but only if you're finding that you cannot get further water to flow into your machine. If your machine fills, OK, then this ISN'T a solution to your problem.
I have a Bosch SHV. My sink drain backed up, and the water accumulating in the sink then migrated to the dishwasher, through the drain pipe, causing the dishwasher to fill up and, it turned out, overflow a little. When I turned on the dishwasher, the water drained, but no new, clean water came through the hot water pipe. The drain just kept running, but nothing else happened.
Here's what happened. Under the main chamber of the dishwasher, by three inches or more, is a white plastic tray. It sits almost at the floor, and it may not be obvious that it's a tray capable of holding water. The overflow water spilled into that tray, which in turn caused a float in the far left side of the tray to lift (the way a toilet float lifts when the water fills in a toilet tank) and shut off the water intake valve (like the toilet float shuts off the toilet water flow). So long as that valve is closed, your machine will not run.
STOP: disconnect power supply at this point for safety.
To see the white plastic tray and thereby fix the problem, you'll need to take off the BLACK TOE-KICK (attached on my unit by two star-head screws at its bottom) and, possibly , the OUTER PANEL OF THE DISHWASHER DOOR (in my case, a custom wood panel (attached by a few screws through the inner side of the door, two screws that are accessed by popping off little--smaller than a dime size--covers on the sides of the doors, and then the door panel lifts up and out). (I took the outer panel off, but I can't remember if I would have had to reach into the white tray without doing so.)
Once you do that, you can see the white plastic tray. It doesn't come out--at least not without removing the entire machine--so try this. You can take your fingers and feel over and into the tray. You'll probably feel the water--I did. Look at the far left of the tray with a flashlight. Back there you'll see a flat, round, 3-inch diameter piece of white plastic sitting at the bottom of the tray. To its center is a generally U-shaped lever looking device, which, at its far left end, is connected to a red stick pointing up into the machine. When water goes into the tray, the float rises, causing the U-shaped lever to rise, causing the red stick to raise, which (though I couldn't see it) causes an electrical signal to run to, and shut, the valve for your water intake.
I took paper towels, and then a narrowly cut sponge, to sop up the water in the tray. I then took my shop vac and, using it as a blower, blew what little water was left right out. You might be able to use a hair dryer, but first sop out what you can or it'll take forever. Once you've done that, put everything back together and plug your dishwasher back in. My buttons are at the top panel. To reset, hold down the two buttons marked for clear drain for three seconds and release. You should be able to start up then. It took 15 seconds before the water started to run, but it did and the machine works fine again.
Interesting note: The valve that stopped the water from flowing in automatically opened once I got the water out of the tray. You don't need to reset the valve.
Good luck.
Montpelier Man
May 04, 2009 | Bosch Dishwashers
Tablets not dissolving
either there is not enough water (check water valve) or the pump filters are clogged (check and clean as necessary)
Jul 06, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Dishwashers Logo
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
