Question about Dell Inspiron 6000 Notebook
How to find wireless switch on dell inspiron 6000 laptop running windows XP
  • 734 Answers
There is no physical wireles switch on your laptop. You should however, be able to hold down the "fn" key at bottom left of the keyboard and then hit the F2 key at top left to turn your wireless on or off. If that does not provide the desired effect, then your wireles adapter may be disabled, in which case you should right click on the wireless icon in the bottom right system tray and choose "Repair" or "Enable".
Best of luck to you.
Posted on Aug 27, 2010
4 Suggested Answers
  • 3278 Answers
SOURCE: my laptop DELL Inspiron 6000
Hello.
Typically, the problem is with the operating system or memory.
First, boot your system and press F8 repeatedly. Access Safe Mode and login. Choose System Restore and select a date before your system started to freeze. Note that your system updates will go back to that date.
If still a problem, disconnect all cables. Remove the battery. Remove the memory cover. Remove and reinsert the memory modules (they are removed and reinserted on a slant). If multiple modules, test one at a time.
Hope this helps.
Posted on Apr 13, 2011
  • 67 Answers
SOURCE: Blue screen on Dell Inspiron 6000 Laptop
OUCH... Might need a new harddrive or motherboard. Does it even let you go into the bios? Maybe you can do a full reinstall to save you the dough.
Posted on Jan 06, 2010
  • 2246 Answers
SOURCE: i have dell inspiron 6000 laptop, ie running on
yes its possible, younjust need win7 installer, run at winxp then chose advanced setting upgrade, thats it
i hope this helpfull
please rate my answer
thanks for using fixya
Posted on Dec 12, 2010
Netgear wgt624 wireless router installs through wizard up to step 3 and then stops. the computer is a dell inspiron 6000 laptop.
I never use the software supplied with the router, you don't need it. Google "let windows manage wireless" and you'll find many walkthroughs.
Mar 01, 2011 | Dell Inspiron 6000 Notebook
I have dell inspiron 6000 laptop, ie running on windows xp home edition i want to upgrade windows xp to windows7 is it possible
Dec 12, 2010 | Dell Inspiron 6000 Notebook
Jan 06, 2010 | Dell INSPIRON 6000 CENTRINO...
Possess dell inspiron 6000 centino wireless, need drivers and xp
You can contact Dell Technical Support and see if they will send you a new XP CD. All the drivers can be downloaded at Support.dell.com for that system. If you can't get Dell to replace the CD, try Ebay. Here is an Example:
http://cgi.ebay.com/Reinstallation-Dell-CD-w-MS-OS-XP-Pro-SP2_W0QQitemZ300352622860QQcmdZViewItemQQptZUS_Software?hash=item45ee69510c&_trksid=p3286.c0.m14#ht_500wt_1182
Sep 30, 2009 | Dell INSPIRON 6000 CENTRINO...
Wireless network connection not working
For some reason known only to Dell, the default setting for the Inspiron 6000 built-in wireless network adapter is 'off' or 'disabled.'
If you used Dell's restore disk to reinstall XP, the radio button is turned off. Go to control panel/system/device manager, find the wireless LAN device, right-click on it and choose 'Properties.' Under 'Wireless radio' check 'on' or 'enabled.'
Go back to Windows network setup wizard and go back through the steps using the 'restore network connection' button. You should be good to go.
There's an EXCELLENT network manager from Cisco named 'Network Magic' that takes all the guesswork out of setting up your internet connection. I highly recommend it. They offer a free trial and I think may even have a 'Lite' version that helps with simple connections without the bells and whistles of the full blown program. I'm not sure about that, but I can't tell you how much time it's saved me troubleshooting and setting up networks for my clients.
Jun 11, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 won't connet wireless network after reinstall
check DEVICE MANAGER if the wireless card have the right driver installed. if you found that the wireless card have yellow exclamation point on the right it means, you installed a wrong driver.
check also in BIOS if the wireless card is enable and the switch is turn on.
press Fn+F2 to enable wireless radio/anthena (funtion key with wireless icon in blue color)
some dell laptop have hard switch located right side check this and turn the switch on.
if you want to see the icon n task bar, go to control panel....network connection...right click on wireless adapter...select properties...check Show on taskbar
Apr 03, 2009 | Dell Inspiron 6000 Notebook
Reinstall preoloade software
need recovery disk that came with laptop
Mar 29, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 with network card Intel/Pro Wireless 2200 BG
So u can connect to the router, but you arent allowet to access the internet?
The router gave your dell a new ip-number, but it dident gave you access to the net. You ned to do the settings in your router manual, let the router give your dell full access.
Good luck
Dec 05, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
232 people viewed this question
Alun Cox
