Question about D-Link Computers & Internet
D-link doesn't have coaxial cable port for internet
  • 220 Answers
The router does not have th cable port, the modem does. The modem hooks to the cable then a rj5 cable runs from the modem to the router.
Posted on Aug 27, 2010
My cable box is hooked up but no signal can u tell me whats wrong
If you hookup your TV directly to the coaxial cable, bypassing the cable-box, do you get a few channels? If so, then the coaxial cable is carrying a signal, which is good.
How are you hooking the output from the cable-box to the input(s) on the TV? Coaxial output port on box to coaxial input port on TV?
Red/blue/green "component" outputs on box to matching inputs on TV? Red/White audio outputs on box to red/white inputs on TV? HMDI output from box to HDMI input on TV?
You have to "tell" the TV which of the inputs:
* coaxial (with TV set to Channel 3 or 4)
* component
* HDMI
to "listen" to.
Oct 24, 2014 | Samsung PN60E6500 60-inch 3D Plasma TV
How to connect a philips antenna to a trutech tv
Unplug your television and turn the set around so the back of the set is facing you.
  • 2 Disconnect the antenna or cable connection from the television's "VHF," "Antenna In" or similarly worded port if it is connected.
  • 3 Examine your splitter and notice one end of the device has a coaxial port while the other end has two coaxial ports.
  • 4 Plug the coaxial end of the television antenna into one of the two coaxial ports on the splitter.
  • 5 Plug the coaxial cable coming from the cable television connection outlet into the second coaxial port on the splitter. Use the port next to the one you used to plug the television antenna into.
  • 6 Place one end of a 2 foot piece of coaxial cable into the single coaxial port on the splitter.
  • 7 Plug the other end of the 2 foot piece of coaxial cable into your television's "VHF," "Antenna In" or similarly worded port.
  • 8 Plug in the television set and turn it around so the screen is facing you.
  • 9 Use your television's remote control to access the "Menu," "Setup" or similarly worded function. Or press the "Menu" or "Setup" button on the front of the television.
  • 10 Select the "Channel Setup" or similarly worded function. Set the Input to "Cable" and perform an "Auto Scan" to locate all available cable television channels.
  • 11 Select the "Channel Setup" or similarly worded function, then set the input to "Antenna" and perform an "Auto Scan" to locate all available broadcast channels. Your television will locate both broadcast and cable television channels.
  • 12 Scan the channels on your television to make sure all available channels have been found. If you are missing any channels that you know you should have, manually program the channels into your television using the "Channel Setup," "Manual Channel Setup" or similarly worded function.
  • Oct 17, 2011 | Televison & Video
    I have a Roku, which allows me to transfer Netflix films to my TV. Since we no longer have a WiFi it must be attached by wire. I have a Linksys Cisco router. Can yo give me directions on installing both...
    Okay, the router "if needed" first. Do you need a router? A router is used mainly to connect multiple devices to one internet connection. The Roku is one, if you have computer(s) also, then yes you need a router. Is the Linksys router wireless?
    From the wall the coaxial cable TV/internet cable goes into the cable modem and another coaxial to the Cable box. Wire to the TV as desired. From the cable modem to the router use a RJ 45 cable into the WAN/Internet port. Now use another RJ 45 cable to the Roku and RJ 45's to the other ports marked 1 to 4 as needed for computers. If the Linksys router is wireless you can set up everything wirelessly.
    Instructions for setting up the Roku is at the link below.
    http://support.roku.com/entries/244199-how-do-i-set-up-my-roku-player
    Good luck,
    Cullen
    May 19, 2011 | Linksys Computers & Internet
    I have Belkin N150 Rouer. My internet is Time warner. It has no connection between the modern and Belkin router. How can I set up Belkin N150 Router to solve this problem?
    f the modem light keeps blinking, it means that the router hasn't been configured yet. Also, rarely, it can be an issue with WAN port/modem port on the router or the ethernet cable connecting the modem to router or finally, modem may not be working as its not applicable in this case(as you said).
    1.Connect comp.--(gray port) router (yellow port)--modem
    2.On the computer, open the router page by typing 192.168.2.1 in the address bar of browser
    NOTE : IF YOUR INTERNET SERVICE PROVIDER IS CABLE FOLLOW THE BELOW STEPS
    3.Under Internet WAN , SELECT the connection type as Dynamic.->NEXT
    4.On the far left column, click on "MAC address" under Internet WAN.
    5.Click on clone and apply changes and finally check Internet status
    6.If internet status > Not connected, we need to do a network power cycle
    7.For this, unplug the power from router, then from modem, then unplug the coaxial cable from cable modem.
    8. Wait for 60 sec, then connect the coaxial cable, then connect power to modem, wait for lights on modem to get steady, then finally, plug in the power to router.
    Now, you may see proper lights lit on the router.
    All my best wishes for a fast internet service through the router.
    FOR PPPOE OR DSL CONNECTIONS
    1.Under Internet WAN , SELECT the connection type as PPPOE ->NEXT
    2.ENTER THE USERNAME & PASSWORD PROVIDED BY YOUR IN INTERNET SERVICE PROVIDER
    3.CLICK ON APPLY CHANGES
    For any advanced help, revert asap!
    Thanks and regards,
    MILAN
    Jan 20, 2011 | Belkin Connect N150 Wireless Router...
    Cmment utuliser ce modem
    1. Save your work and shut down your PC.
    2. Connect the coaxial cable from the coaxial jack in your wall to the coaxial port on the rear of the modem. Turn the connector clockwise until the cable is firmly connected to the modem. Gently tug on it to make sure it is connected.
    3. Connect the appropriate cable, USB or Ethernet to the matching jack on the rear of the modem. Connect the other end of the cable to the appropriate port on your computer.
    4. Connect the modem's power adapter to a surge suppressor or a dependable wall socket.
    5. Press the power switch on the front of the modem to turn it on. Power up your PC. If you opted to use the USB connection method, you may have to install the appropriate drivers. Check your owner's manual for specifics.
    6. Launch your web browser http://192.xxx.xxx to verify Internet access.
    Dec 04, 2010 | RCA Thomson Digital Cable Modem (DCM305R)
    Modem light keeps blinking Have tried resetting. Restoring to default settings. If I hook the computer directly to the time warner modem I can acces the internet fine. Thanks
    If the modem light keeps blinking, it means that the router hasn't been configured yet. Also, rarely, it can be an issue with WAN port/modem port on the router or the ethernet cable connecting the modem to router or finally, modem may not be working as its not applicable in this case(as you said).
    How to configure the router for Time Warner?
    3.Under Internet Settings, change the connection type as Dynamic.
    8. Wait for 10 sec, then connect the coaxial cable, then connect power to modem, wait for lights on modem to get steady, then finally, plug in the power to router.
    Thanks and regards,
    Arvind
    Jul 04, 2010 | Belkin F5D8236-4 Router
    Can i connect my audio and video cable to a coaxial cable? so one side is coaxial cable and the other is audio and video cable one for the the wall and the other audio and video for the tv, this is beause...
    U have HDMI ports,order HD from the cable or telicom compannies.Use a HDMI cable for the tv,also get HD channels.Do not have HDMI ports than ur Main signal board must replaced the Antena analog coaxial it broken.Well not able to buy the coaxial input for the antena along for part.
    Jan 10, 2010 | RCA HD52W58 52" TV
    Hd tv to vcr
    What model and manufacturer DVD/VCR combo are you using. if it has a HDMI port, you should buy a HDMI cable to your combo player than to your HDTV (most don't have this High Definition port.) 6f3606c.jpg
     otherwise, it probably contains a composite port, connect the red to the red (Left) white to white (mono) and yellow to yellow (Video) than connect the wires to the matching port on your HDTV) then switch the input to AV or Composite. 9701d83.jpgb5e3eb0.jpg
    If this fails, you need a coaxial cable.85dec5e.jpgconnect a coaxial cable to your player then to the coaxial port on your tv. change the input to "either Coaxial, Cable 3 or any input that sets it to coaxial input.
    Mar 24, 2008 | Sanyo DVW-6100 DVD Player/VCR
    Computers & Internet Logo
    Top D-Link Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
