Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Have an old 1415 cub cadet. The motor will start and run for a few minutes and then shut down. Have changed wires, fuel filter, rebuilt the carborator. Any suggestions?
  • 40 Answers
SOURCE: cub cadet lt1050 poor running
when you cleaned the carb was the needle replaced. also what is the compression on this engine. if a unit has low compression they will sometimes only run on full choke. is there good fresh gas in this unit. No water..(if in doubt trow it out)
Posted on Mar 12, 2009
joboo1
  • 257 Answers
SOURCE: transmission oil ? for cub cadet tractor
Hi, Cissy, Every Cub Cadet is different, and they keep their manuals to themselves. With your exact model and serial number, you can go to their website and view the manual for your model which should have the type of oil you need. Their website is www.cubcadet.com and go to service. If you have trouble, let me know, but I will need the model and serial. Good Luck, this should Fixya!
Posted on Mar 23, 2009
  • 110 Answers
SOURCE: Cub Cadet LT1042 PTO won't disengage
If its an electric PTO then the switch on the dash is bad, Its a lever type ungagement then the little break shoes that rub on the blade spindles are either worn out or mis adjusted.If it started when you changed the blade drive belt its possibly the wrong belt??
Posted on Nov 01, 2009
redbeard00
  • 957 Answers
SOURCE: my cub cadet tank stops running 5-20 minuts after
Yes you may need a carb kit. It is not good practice to by-pass the fuel filter. The orifice in the jet is very small.
But anyways, There Could still be a blockage inside the carb, a small leak at the manifold, or the jet is worn out.
Let me know how it goes.
Posted on Apr 28, 2010
  • 4 Answers
SOURCE: I have a Cub Cadet lawn tractor that just stop
CHECK THE FUSE
Posted on Jul 02, 2010
Cub cadet rzt 50 with kohler engine runs a few minutes and shuts off
sounds fuel related. check the fuel lines and filter be sure they are good. if you unhook the fuel line at the carburetor and let it run out into a bucket for a few minutes, it should have a steady stream of flow. if it slows down or stops loosen the fuel cap. if it starts back to a good flow. replace the fuel cap. that may be causing the problem. be sure the vacuum tube for the fuel pump isnt cracked or hard.
Apr 04, 2018 | Cub Cadet Garden
I have a Cub Cadet Model 364 with a 18 H.P Briggs & Stratton motor. It runs fine for about 20 minutes. Than starts hesitating. Like the motor wants to stall out. Help!
Firstly, try to run the engine without cap on the fuel tank. If it stays running well, clean out the ventilation hole in the fuel cap ( or replace the fuel cap ).
Check for dirt in the fuel tank, fuel tank connections, hose, strainer, filter. Clean everything!
Check if you still have sparks when the engine stopped from itself.
Check if you still have compression when engine has stopped from itself ( valve settings too close )
Sep 28, 2016 | Cub Cadet Garden
Cub Cadet HDS-2135 13B-214F100, runs great for 45 - 60 minutes then cuts out, only run on full choke, cannot mow but runs. Cools down works fine again
check the fuel filter and fuel line. it may need to be insulated to protect from heat. running on choke means it is starving for fuel . take the carburetor off and clean it real good. be sure the fuel lines are away from heat source.
Jun 09, 2016 | Cub Cadet Garden
Cub Cadet LT1050 Runs fine..20 min...dies...wait 20 min....runs fine 20 min.
Check the breather in the fuel cap, run it with the cap loose and see if it is any better.
May 30, 2013 | Cub Cadet Riding Lawn Garden Tractor 25hp...
Cub Cadet shuts down, oil full but blinking light, runs like a champ til then
oil light says on for about 2 hrs from when it due to be serviced by the hr metre not when you have serviced
Apr 08, 2013 | Cub Cadet Riding Lawn Garden Zero Turn...
I have a cub cadet that wont stay running.
Is the gas more than 5 months old? If so drain the old gas and replace with fresh gas.
If that does not fix it try replacing the fuel filter.
If that doesnt fix it try cleaning and re-gapping the spark plug or replace the spark plug. If none of these easy fixes do it then it could be a dirty carb.
Apr 04, 2010 | Garden
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
