Question about Panasonic Viera TH-42PZ80U Plasma TV
No power on my TH46PZ850U tv just the red light in front.
  • 7 more comments
  • dhar678 Aug 27, 2010
    Not in from of the TV today. But, they was a solid red light on the power indicator. I don't recall hearing a relay.
    I will check and let you know.
    thanks
  • dhar678 Aug 30, 2010
    I check the unit this weekend. when I press the power button I hear the relay and then the red power light in the front of TV blink on and off. The TV doesn't turn on.
  • dhar678 Sep 02, 2010
    I have 2 blinking lights
  • dhar678 Sep 03, 2010
    what can i do? I will have to buy a new board?
    which board is the 15v coming from?
    I just replaced the power supply with a new one from shopjimmy today.
    do you have the schematic for the power supply and the ETX2MM704MG A NPX704MG-1. i want to measure the output of that board
  • 10,594 Answers
Does power indicator on tv lit when tv plugged in?
If yes, do you get relay click sound when press power button?
Does power indicator or any other light blinking on tv front?
Let me know to diagnose possible cause of problem in tv.
Thanks.
Posted on Aug 27, 2010
  • 14 more comments
  • Shahid Electronics
    Shahid Electronics Aug 27, 2010
    OK, so no light of power indicator.
    Power supply board seems defective, please check main fuse of power supply board and replace it with same rating written on it if found blown. If fuse blow again, replace power supply board.
    make sure tv ac cord is unplugged while checking main fuse on power supply board.
    Let me know if you have additional question.
    Thanks.
    Thank you.
    Shahid Electronics Aug 30, 2010
    How many times power led blinking after long pause, led can blink 1 to 13 times and this blink is error code that shows possible section of problem in tv.
    problem in tv.
    I will check next time when I am next to the TV. will update you soon.
    thanks.
    OK, I have training manual for this tv that has troubleshooting info
    Power LED blinks info will help me to locate defective section.
    Thanks.
    The TV model is TH-46PZ850U not the 42".
    thanks,
    Training manual covers many model that has same chassis including your model as shown in below image.
    thanks
    No problem, let me know how many times led blinks.
    Shahid Electronics Sep 03, 2010
    OK, 2 blinks error code shows +15V supply problem on D Board
    Below image shows D board location in tv
    Need to test 15 volt supply on that board, if supply gets in that board but tv still shows 2 blinks then replace the board and if 15V is not being supplied, need to follow source of that volts that is power supply board.
    If you feel uncomfortable working with circuit boards then local tv repair shop is good option to get help.
    Thanks.
    15 Volt comes from PS (power supply) board
    I'm not sating that power supply board is bad, in fact I'm trying to convey how to troubleshoot the problem.
    Required service manual can be downloaded from HERE for small fee, it has schematics, part number details info.
    Thanks.
  • j_frombkln Nov 20, 2010
    i have the same problem with my TH-46pz850u. The light blinks 10 times, it wont do anything else. this just happen this week. its my main TV for the apartment cant afford another, really want to fix this.
  • Roberto Lecaro
    Roberto Lecaro Nov 24, 2012
    http://www.tvrepairdoctor.com
Popping noise and now won't power up. Red and green indicator lights blink on front of tv.
start by checking the power supply in the set and if not able to do that consider taking it to a shop for an estimate.
Jun 16, 2012 | Toshiba 52HL167 52 in. LCD HDTV
Red light flashing in the front
Power supply board is dead.Replaced the power supply board will solved this problems.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Mar 11, 2010 | Philips 42PF9631D 42 in. Plasma Television
Tv will not power up blue power light flashing,red temp and red lamp lights flashing
The lamp is likely blown - it is loacated behind the front panel and can be pulled out to check - unplug set and do not touch front of lamp.
Oct 11, 2009 | Hitachi 50C10 LCD TV
Cannot get tv out of stand by mode..
upon hitting the power button, the red light showing on the front of the tv should flash a couple of times, the screen should come on and the light goes off..the red "stand by " light stays on and we cannot get the screen to come up..needless to say, cannot get to the menu to change any display options...any suggestions?
Apr 10, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv wont turn on
Ur high voltage is dead,the FBT,the flyback transformer is dead.The big black block of plastic with a red wire with a cap hook to the CRT(tv tube).
Mar 19, 2009 | Sony FD Trinitron WEGA KV-36HS420 36" TV
TV doesn't turn on, red light flashing
numder of flasing indicate error code . so i need how many flash you can see when power on the tv using front power butten then i will suggest the solution
Jan 15, 2009 | Sony KV-32S45 32" TV
Standby/timer light stays on red. no picture or sound on tv.
my sony red light flash.but it will not turn on just clicks
Nov 26, 2008 | Sony KP-48S75 48" Rear Projection...
My samsung tv wont turn on, red light keeps flashing on the front.
i had this with my samsung and my mums instead of pressing red power button press either switch from analog tv to digital button or just press a number
Jun 04, 2008 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Panasonic Viera TH-42PZ80U Plasma TV Logo
648 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
