Question about Sega Genesis 2 Console
When I turn on my Sega Genesis, a black screen appears on the TV and nothing else happens. It shows nothing but a black screen. When you turn on the console you can hear it try to start with no success.
  • Sega Master
  • 427 Answers
Well try cleaning the game packs out with quips and rubbing alchal the game packs could just be dirty then I had a problem with my sega it would just show a black screen when I turned it on so I cleaned out the game packs and it was fine after that the worst case is that your sega is on its way out let's hope not but lukie games sells sega products too.
Posted on Jun 06, 2013
jyackle5
  • 8197 Answers
SOURCE: I need hook-up instructions for my 16 Bit Sega Genesis system con
Go to this link.
http://imageevent.com/gamescans/gamemagazines/segagenesismanual
Good Luck
Posted on Jan 23, 2009
  • 20 Answers
SOURCE: no picture for Genesis - RF or console?
The problem is most likely not the console. The first thing you should try is cleaning the contacts on your games. Most of the games have tamper proof fasteners so unless you have the right tools you won't be able to open them. You can take a q-tip with a little alcohol (damp not wet) and clean both sides of the circuit board on the cartridge until the q-tip comes out clean. Let it dry before sticking it into the console. If you do this to a couple of games with no luck try taking an emery board (for fingernails) and gently inserting it into the connector in the console a few times all along the length of it. Make sure to only push it straight in and pull it straight out. If you try pushing it side to side while it is in there you could damage the connector.
Posted on Dec 08, 2007
SOURCE: sega genesis 1993 model broken, no picture, just black
fixed it
Posted on Jul 01, 2008
  • 56 Answers
SOURCE: Problem with the 1st generation sega genesis
If the screen changes (From snow to black or something) when the console is turned on it sound like the console is partially working. Try cleaning the Cardridge pins que tip and some sort of cleaning fluid.
Once this is done insert and eject the cartridge several times then repeat the cleaning process on the cartridge. Hope this helps.
Posted on Jul 11, 2008
DarkWolfBomb
  • 80 Answers
SOURCE: how do i set up my sega genesis
There should be regular av cables and wall adapter for it. Mine came with the wrong cords and that might of happened to you. So if you don't know the av cables go in the back of the tv and plug's in the back of the sega. and the wall adapter goes in the wall. If you don't have the cords than get them off line. Type in:
http://www.amazon.com/s/?ie=UTF8&keywords=sega+genesis+cords&tag=googhydr-20&index=aps&hvadid=2858659671&ref=pd_sl_8zrz6m8bxu_b
cut and paste it online and you can get them.
Posted on Jul 18, 2009
When I try to hook my Sega Genesis up to my TV, why does nothing happen?
you should have a red light and if its on it should be working. I would just go on Amazon and buy a AV connector for the system, no need to use RF like its 1989 :)
Dec 31, 2015 | Sega Genesis Console
My sega flashes on screen but wont come on
Video game cartridge terminals and the console connector pin require servicing similar to this service.
Please let me know how I may assist further.
Apr 19, 2010 | Sega Genesis Console
I have a model 1 sega. Power light goes on but
are you getting at least a black screen? i would like to help you with this so if you want a run through email me on key-kun@hotmail.com and tell me ur you..
Mar 13, 2010 | Sega Genesis Console
I get a blank black screen when i turn on my sega
Take the game out and put it back in SEVERAL times.. try blowing the cartrage or the reader...there may be dust..also make sure there is nothing on top of the sega or touching the cartrage...make sure the sega isnt moving and is on the floor or on a shelf
Jan 05, 2010 | Sega Genesis 2 Console
When i turn the sega on the tv screen comes up blue, red, or black it won't go to the start screen
Hold open the cartridge slot with your finger and blow hard into the port, try again
Apr 28, 2009 | Sega Genesis 2 Console
Line across top of screen
Hey I had that same problem with my sega genesis,on my 52 inch rca hdtv,,its because your using the antenna plug to plug it to your tv,,look on ebay youll find for like 3 or 4 $. a s video for your genesis ,,no more lines ,, way better picture,, very clear,,hope to help,,, thanks
Jul 02, 2008 | Sega Genesis Console
Sega Genesis not showing a picture
As I had just a similar problem with my MegaDrive/Genesis maybe this helps: Try an older TV set. I am not joking. It might very well be the case that newer TV sets/high-end TV systems can't handle the signals of the older video game systems. I have a 100 hz TV set and whereas there are no problems with a SNES, with the MegaDrive I just had a black and white screen with bars running through it. On a 60 Hz TV set this problem does not occur. Keep in mind that there were no 100 hz/HDTV sets around when these video game systems were in general use.
Jun 18, 2008 | Sega Genesis Console
Sega genesis 1993 model broken, no picture, just black
Actually somethign like that happened to mine. you might want to try to place a piece of paper in the front of the cartridge that will make the cartridge stay all the way back this is due to the fact that some of the connectors were messed up and had to be extremely close to work.
Mar 28, 2008 | Sega Genesis Console
Sega Genesis 2 Console Logo
128 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
