Question about Arris SURFboard SB5120 Modem
I have a Motorola Surfboard Modem sb5120 and i payed 200 dollars for the set up of it for internet i feel like a fool because i did not get to use it once after i payed for it because a storm knocked the power out in my apt and when everything turned back on only the first 2 lights and the pc activity light would turn on i am using a ps3 with the modem not a computer i can get into the sb5120 interface but i dont know what to do after that to fix it i can not reach the man who set it up so you guys are my only hope i have tried everything to get it to work again all the basic things plugging in and out resetting i need numbers
    President:
  • 1,768 Answers
1. 1st you must contact your Internet Service provider to see if your
connection is good.
2. getting in to the router and see the status of the router should be the
next step.
Since you don't have a pc this will be difficult because the pc has the
browser screen to see what is happening in the router. The interface
for the user is seen via the pc screen using the 19.168.0.1 IP address.
3. The gaming instruction or gaming setup instructions for your router
are in the "advance tab" the instruct set can be also abtained by going
to the manufacturers site.
4. To add devices to the Surfboard router you will have to either
connect with an Ethernet cord or you will have to set the router up
wirelessly for you device.
5. if you had a electrical surge at your apartment you may have
damaged the router to the electrical spike if no surge protection was
used.
6. to know if your router is ok the "power light" should be green
If you have flashing yellow lights on the "link" then you have lost
connectivity with your Internet Service Provider and you need to have a
router reset. ^The provider should be able to walk you through the reset
process.
Posted on Aug 27, 2010
I need driver for usb motorla sb5120 on vista
Hi, check this URL hope it will be helpful
http://download.cnet.com/Motorola-SURFboard-SB5120-USB-Cable-Modem/3000-2112_4-170001.html
Oct 26, 2010 | Arris SURFboard SB5120 Modem
I can't get ports open on my surfboard 5120 modem, the router is configured properly and it showed them open when I first set it up but they closed and now I can't get them to open again. Once after...
call 1-877-466-8646 this is motorola's tech support line. Thier agents are very very good and will either fix your issue or tell you exacxtly where to go to get it fixed. But if they need to walk you through the set up process t does cost 30 dollars, but they can tell you how to get the set up info for free if you dont wanna pay
Oct 09, 2010 | Arris SURFboard SB5120 Modem
Reset Motorola SURFboard SB5120 Modem
This is a direct link to show you step by step how to reset the modem http://www.ehow.com/how_5125713_reset-sb-modem.html I hope this helps good luck
Sep 30, 2010 | Arris SURFboard SB5120 Modem
How to open settings of motorola SURFboard SB5120 modem?
Support for the Motorola SB5120, discontinued product, see next site:
http://broadband.motorola.com/consumers/support/default.asp?supportSection=DiscontinuedProducts
Connecting the device, see the "Quick Reference Guide":
http://broadband.motorola.com/consumers/products/SB5120/downloads/SB5120_Quick_Ref_Guide.pdf
For installing the modem the easiest way is to run the provided cdrom.
When not available perform the settings as showed in the guides.
Motorola 5100 series user guide:
http://broadband.motorola.com/consumers/products/SB5120/downloads/SB5120_User_Guide.pdf
See page 7 "Before You Begin" for the requirements and selecting either USB or Ethernet connection.
Page 22 gives the overview for the pages how to configure ethernet settings.
Oct 31, 2009 | Arris SURFboard SB5120 Modem
Reconnecting to internet after recovering from sleep mode
There are many causes of this, but the most common can be solved by going to the CMOS (BIOS) of your computer and disable the power saving on the ethernet, PCI or wathever where you modem is connected.
Jul 18, 2009 | Arris SURFboard SB5120 Modem
Connect Laptop to PC desktop which has cable connection.
YOU WILL NEED TO GET A WIRELESS ROUTER TO BE ABLE TO USE THE LAPTOP WIRELESS, iT IS A VERY EASY SET UP AND CONNECT THE DESKTOP WIRED AND THE LAPTOP WIRELESS TO A WIRELESS ROUTER.
May 06, 2009 | Arris SURFboard SB5120 Modem
Cannot set up Motorola Surfboard SB5120 modem
This usually means something is not correct with your incoming signal. If your cable wire into the modem is being run off an amplifier in the wall this could be effecting your service. If the signal is too strong the modem won't be able to communicate for internet.
You could check the incoming wire to see if it is running off an amplifier. If it is you would need to run a new line that is not on the amplifier. I would recommend comcast coming out to check the signal frequency and make the necessary adjustments.
May 04, 2009 | Arris SURFboard SB5120 Modem
Wireless router stops internet connection to modem during install
are you sure your hooking the comcast modem in the right place?
Feb 08, 2009 | Arris SURFboard SB5120 Modem
Arris SURFboard SB5120 Modem Logo
117 people viewed this question
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
