I want to change my security options - Computers & Internet
Service error 214702489 services status change
Recent Microsoft Service Packs for MSXML implemented a security "enhancement" which causes that service to interrogate an Internet Explorer security setting, "Submit Nonencrypted form data", prior to submitting or accepting forms sent with non-SSL encryption. If this setting is set to Disabled or Prompt, the calling action fails. Solution
  1. Open Internet Explorer and select Options from the Tools menu to open the Internet Options screen.
  2. Click on the Security tab and then click Custom Level to open the Security Settings - Internet Zone screen.
  3. Scroll down the list of settings until you see Submit Nonencrypted form data and click the Enabled radio button below it.
  4. Click OK to save the change and return to the Security tab of the Internet Options screen.
  5. Click OK to exit the Internet Options dialog.
Mar 07, 2015 | Microsoft Computers & Internet
Remove security parameters
If your computer is connected to a network or the Internet, it is advisable to use computer security tools, such as a firewall, to protect your computer from unauthorized access or viruses. Windows operating systems come with a built-in firewall, malware protection and Internet security. These settings are automatically configured to the factory's default settings when you purchase the operating system. To alter the settings for these security features, access the Windows Security utility through your system's Control Panel.
Open the "Windows Security" utility by opening your "Start" menu and selecting the "Control Panel" option on the right-hand side. Windows XP users can click on the "Security Center" link in this window. For Vista users, click on the "Security" option, and then click on "Windows Security Center." Click on the "Windows Firewall" option to change the settings for your firewall, if you are using XP. You can turn the firewall on or off, and also configure which programs are allowed through the firewall. Vista users should click on the "Windows Firewall" link in the left window pane and click on the "Change settings" link. In this window, you can block programs from passing through your firewall and grant access to new programs. Click the "Internet Options" selection to configure your Internet security settings. You can raise or lower the security level for different zones using preset configurations, or you can create a custom security level. You can also reset the Internet security level to its default settings. Click on "Automatic Updating" in the Windows Security Center to configure your system's update settings. In Vista operating systems, click on "Windows Update" and "Change Settings." You can configure your update settings to automatically check for updates daily or weekly. You can also set a convenient time for your system to update to prevent interruption. Automatic updating can be turned off by selecting the corresponding option toward the bottom of the window. Select the "Malware Protection" option to edit malware settings if you are using Vista. This option is not available in XP's version of Windows Security Center. You can turn the malware protection programs on or off using the arrow to the right of the "Malware Protection" bar. Click the "X" button to exit Windows Security Settings.
Feb 10, 2013 | HP Computers & Internet
If I do not have a streaming application running my system (XP) will go into standby before even startup has completed. I have changed the Power saving option to "never" standby, but no luck. It seems to...
go to control panel and open power option,
change your power scheme and all the other option is never or 5 hours.
and please tells, what security issue is going on.
further u find your security issue for the following.
go to Control Panel, click on Administrative Tools, and then Local Security Settings.
I hope u find you solution
Rizwan Ali
Nov 29, 2009 | Microsoft Windows XP Home Edition
My security code and i want to unlock it
Enter the lock code instead of the security code. After then to change the security code.
  1. Go to menu and there open settings.
  2. There open security settings.
  3. There will options such as change lock code or change security code etc.
  4. If you have forgot security code then you can't change it, better change lock code as your desired password.
  5. To change first get into change lock code and enter old lock code and after that input new password and its all done.
Aug 14, 2009 | Lands Phones
Need to change my security PW to WPA from WPA2 which xbox360 does not support
Went into my router settings and changed the security password for my network to WPA only. This allowed my Xbox 360 to see my network.
Apr 11, 2009 | Computers & Internet
Invalid security code
You are going to have to do a factory reset on it. You will lose all the stuff you had
Apr 01, 2017 | LG KG270 Cellular Phone
Password
Type in on telephone keypad:
5555#*
999#
999997#
Select Option 8
Select Option 4
Type in extension number you’d like to change followed by #
Select Option 5
Go to telephone you’ve just changed and type in 5555
Enter extension number followed by 997#
Select Option 3
Select Option 2
Select Option 3
Enter new security code followed by #
Confirm new security code followed by #
Hope this helps, Karen
Jan 07, 2009 | Toshiba DKT-2010 Corded Phone
Voice mail problem
You need to reset the password
5555#*
999#
999997#
Select Option 8
Select Option 4
Select Option 5
Select Option 3
Select Option 2
Select Option 3
Dec 29, 2008 | Toshiba DKT-2010 Corded Phone
Forgot security code
Hi bootta,
I have a guaranted solution for ur problem. U must send me feedback and post clarification request after the solution.
I have a method to bypass ur security code. Later on u may change it.
For it, the process are :
1) When the phone asks for security code, there is unlock option in the left hand side of the screen.
2) At that time, dont enter it.
3) Instead of it, press and hold left soft key and * button at once. (dont press them alternately, otherwise it dont work)
4) If u hv properly pressed the buttons, then it will ask an option " Press * to unlock ". At that time, fastly press the * button.
5) Now u have bypassed the security code.
6) Later on u can change ur security code by same process from the security option inside the settings option.
Looking for ur kind feedback and rate my solution too.
( for posting clarification request, u have to choose clarification request instead of solution in the "post a ....." option and post it.)
Sajan (sajwhat@hotmail.com/ sajwhat_2003@yahoo.com)
May 07, 2008 | Nokia 1600 Cellular Phone
Security code NOKIA 6030
Hi shibunokia,
Dont forget to send ur kind feedback and rate my solution !!! ( For posting clarification request, u have to choose clarification request instead of solution in the "post a ....." option and post it.)
Apr 27, 2008 | Nokia 1600 Cellular Phone
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
