Question about Brother IntelliFAX 4100 Laser Fax
Brothers Intellifax 4100
Can this machine be used as a printer? If so what is the process?
Can you pre program a 9 so staff can just dial the phone number
Posted on Jul 18, 2008
New drum replaced,but machine still ask for new drum
Wow. It's obscure and in the manual on page 13-24. Remove and replace the drum leaving the front cover open. Press CLEAR and then 1 to answser the Replace Drum YES question.
Apr 09, 2010 | Brother IntelliFAX 4100 Laser Fax
WHAT DOES NG MEAN ON THE FAX CONFIRMATION. I HAVE THE BROTHERS INTELLIFAX 4100E
Noise or other problems on the phone line. If inside wires and box checks out, call the phone company to check line to the house.
Let me know if I helped.
Oct 26, 2009 | Brother IntelliFAX 4100 Laser Fax
Have a brothers intellifax copier - fax about 5
clean laser... if still there change drum.. if still there clean ccd... if still there... contact brothers support and they will walk you through it or send you to a service center for it to be repaired
Oct 07, 2009 | Brother IntelliFAX 4100 Laser Fax
We have a Brothers Fax 2820 that continually stays in the sleep mode. How can I take if off the sleep mode.
Press Menu/Set, 1, 6, 2.
2 Use the dial pad to enter the length of
time the machine is idle before it goes
into sleep mode (00 to 99).
Press Menu/Set.
3 Press Stop/Exit.
Jun 11, 2009 | Brother IntelliFAX 4100 Laser Fax
NEED THE MACHINE TO ANSWER WHEN THE PHONE SENDS THE SIGNAL.
After making my post, I went to the official Brothers website for the 4100 FAQs and "Operating Instructions." Here's what I found. Set your 4100 set to the "Fax/Tel" mode. Press "Menu", then the number 2 (Fax), then number 1(Set-up Receive), then number 1 again (Ring Delay). Use right arrow key to increase. Once increased, press the "Set" key. You'll see the message "Accepted." Now press the "Stop" key to exit "Menu." This will now give you up to 4 rings before the fax auto answers. Inorder to send a signal by phone to remote start the fax just follow the instructions I copied directly from Brothers instructions for the 4100: If you answer the call on an extension phone (this is any phone plug into a phone jack on the same line) and hear a beep every 3 seconds (automatic fax) or just silence (manual fax), press *51(remote activation code) on the telephone keypad, wait to hear the Brother machine turn on (chirping sounds) and then hang up. I don't have anyone that can send me a fax right now to test it out. I'll have to try it in the morning. Hope this works for you.
THEOH
Feb 23, 2009 | Brother IntelliFAX 4100 Laser Fax
Hi, I just wanted to know if the intellifax 4100 will print also. I was going to connect to my laptop.
Yes, we used to connect to the fax machine to print via parallel cable, but our new laptop computer does not have a parallel port, so we connect via USB now to use the Brother 4100 Intellifax as a printer. It prints very nicely. We downloaded the driver from BrotherUSA.com
http://www.brother-usa.com/Downloads/
and clicked on Fax Machines, then our Intellifax 4100e, then View Download and selected our operating system and language. Just a tip - When you decompress the download, in the location to decompress to, add a folder to hold the files named Brother4100 or something like that, then when you add the printer, select that folder as your "Have Disk" location. Hope it works well for you.
Jan 09, 2009 | Brother IntelliFAX 4100 Laser Fax
Printer busy
sounds like the faxes are stuck in memory
look in the Troubleshooting section of the manual
http://www.retrevo.com/support/Brother-FAX-4100-Fax-Machines-manual/id/386bh847/t/2/
Jul 17, 2008 | Brother IntelliFAX 4100 Laser Fax
Brothers intellifax 4100
cassette is in front, put hand on bottom front of machine and pull, check to see if it is set to letter ( is the paper adjuster the part that can slide back and forth set to letter is there a switch in the cassette for custom and letter size? is it set to letter?
Dec 06, 2007 | Panasonic Panafax UF-585 Plain Paper Laser...
Brother IntelliFAX 4100 Laser Fax Logo
55 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
