Question about Planet Waves Full Function Metronome Tuner Ct 05
I have a Planet Waves Chromatic Pedal Tuner that when engaged, all it does is blink, no letters come up. It doesn't seem to matter if it has a battery in it or is hooked to a DC power supply. It cycles thru the three settings but doesn't actually tune. Is there a way to fix this? By the way, the warranty is void.
  • 10,865 Answers
Hello. I recommend that you call the company directly and check out your options. They may be able to direct you to a local repair shop. Here is their contact info.
D'Addario & Co.
PO Box 290
Farmingdale, NY 11735
631-439-3300
Posted on Aug 27, 2010
Serial number N554137
You haven't asked a question. If you're looking for the year on a Fender Starcaster, you're missing a letter or two from the front of the serial number. I suspect you're looking for info about a different guitar than a Starcaster.
Nov 30, 2015 | Fender Starcaster Strat Electric Guitar -...
I've changed battery in isys+ pre amp on vintage vec500 and now tuner doesn't work (it is blinking green on note tuner no matter of tune and no note letters showing - blank screen)
Is the battery installed in correct polarity? If so- try rotate it in position to rub through potential corrosion.
Since it has a remote battery, it would not hurt to look at the installation to make sure no wires are broken. Especially the ground wire to the pickup.
It might also be a good idea to apply some contact cleaner to the output plug since it is in the power circuit. Cycle the plug in and out a few times to clean the contacts. Also some contact cleaner to the preamp controls would be useful.
Be aware some lubricants may contain silicone and that can interfere with wood finishes or repairs to the finish in the future.
Apr 06, 2012 | Music
Need manual for korg chromatic tuner ca 1
Here is a download of the manual:
http://pdfservicemanual.com/download/http://www.korg.de/uploads/tx_softwarecenter/CA1_Handbuch.pdf
Enjoy!
PvT
Sep 25, 2011 | Korg CA 1 Chromatic Tuner
How to use korg chromatic tuner ca 1
Let me know if you have specific questions, and I'll be happy to help!
Regards,
PvT
Sep 25, 2011 | Korg CA1 Chromatic Tuner
Any way to sever the "bypass" connection from either the "A" or "B" input? Scenario would be an Electric Guitar in input "A", which passes it's signal out the...
Just use WYE connectors and run each guitar to their destination without using the bypass output of the tuner at all... Each guitar into a WYE into the tuner and then continue to the amp and DI box.
Mar 19, 2011 | Korg Pb02 Pitchblack+ Advanced Chromatic...
Hi, i have a acoustic guitar and i am trying to tune it but i do not know how to use the Matrix Chromatic Tuner SR-1050
Hi
Simply turn the tuner on using the power button. Play an open string note close to the tuner (no more than about 1/2 metre away) - for instance the low E on string 6.
The built in microphone will pick up the sound and, if your guitar is reasonably close to being in tune the led light labelled 'E' will illuminate on the lower scale on the tuner along with one of the three other leds to indicate whether the note is flat (b), in tune (green) or sharp (#).
Due to harmonics any or all of these three leds may flash but it is the one that is on the most that matters.
Adjust the tuning peg until the green is on constantly when you play the string.
Move on to the next string
Note - if the string is more than a semitone sharp or flat a different light may flash (e.g if the low E string is 3/4 of a tone flat the D light will come on).
If you wish to tune your guitar to another instrument that is not at perfect pitch (and perhaps cannot be easily adjusted - like a pipe organ) you can use the calibrate button to adjust the setting of the tuner. This temporary recalibration will be lost when the tuner is turned off.
Mar 01, 2011 | Matrix Auto Chromatic Tuner Sr1050
Hi, i have a acoustic guitar but i do not know how to tune it with the Matrix Chromatic Tuner SR-1050
That tuner has a built in microphone to listen for your guitars sound. Turn it on and set is close to your guitar as you tune it.
Brand new chromatic tuner tu-3 pedal, plugged guitar into input and it powers on. Guitar plays through the amp, but when I hit the footswitch the check light and tuning bar do not light up.
Change the battery first. It could be dying and just barely have enough power to come on at first, but not to do anything else. If that doesn't solve it, you've got a defective one and you can go exchange it.
Feb 24, 2011 | Roland Boss Tu-3 Chromatic Tuner Tu3...
Planet Waves Full Function Metronome  Tuner Ct 05 Logo
53 people viewed this question
Top Planet Waves Music Experts
Michial Gueffroy
Are you a Planet Waves Music Expert? Answer questions, earn points and help others
