Question about Garden
Carb adjustments for homelite st-175-bc 17in cut textron ut# 20553b ser# hk3520809 double adjustment screws
  • 376 Answers
SOURCE: what is my lo hi carb adjustment for a homelite
Start with 1 turn out from bottom on both and adjust from there as needed. The screw closest the engine is low speed mixture adjustment and the outer is high speed mix. adj. Hope that helps. Dwain
Posted on Jul 01, 2009
  • 4088 Answers
SOURCE: Homelite ut No. 10748 textron New sitting long
Is there bar oil in the tank? Oil pump and/or pickup tube in oil tank are usual suspects.
Posted on Jul 04, 2009
  • 4088 Answers
SOURCE: Carburator adjustment for Homelite xl 12 chain saw
Turn both screws CW to stops (lightly), then back out each CCW 1-1/2 turns. This should get the engine running if it will. If it does not, check the lower diaphragm on the carburetor for hardness or cracking. You appear to be running on prime only--the carburetor doesn't seem to be pumping in fresh fuel. You may need to do a carburetor clean and re-kit. Check the fuel line condition and the fuel filter in the tank for plugging. Make sure the muffler and air cleaner are not plugged. Once you get the engine to continue running, warm the engine up. Open the throttle and adjust the H needle CW--the engine should start to speed up, but still 4-stroking. The proper setting is 4-stroking, but immediately 2-stroke when cutting. Release the throttle and adjust L needle CW so that the engine runs fairly smoothly, yet will allow the engine to 'follow the throttle'. Set idle speed screw so that the chain stops turning, but the engine continues to run. Hope this helps!
Posted on Apr 17, 2010
Testimonial: "Thanks for the help. A very complete answer should cover all the possibilities."
barterjoe
  • 338 Answers
SOURCE: Homelite mighty lite 26ss -
Starting with the question which screw is which: the low speed screw is closest to the engine and that makes the high speed screw farther away. Set the screws 1 turn out and then adjust as needed.
Posted on Feb 14, 2011
rycgl
  • 1545 Answers
SOURCE: I have a homelite ST-175G string trimmer. How far
I would like you to look at this carburetor tuning tutorial by a major carburetor manufacturer. They answer all your questions here:
http://www.zamacarb.com/tipspage.html
Posted on May 01, 2011
What is the replacement chain and bar for a homelite textron Little Red UT-10748
Ok, what you need to do is go on Google type in that model number UT etc etc and parts right after it. You will see a bunch of sites that have parts drawings, click on one of them, find your part numbers THEN do the same thing again, bqck to google, type in part number then the description, again you will see sites that will either offer the OM part or an aftermarket.
Nov 23, 2015 | Homelite Garden
Homelite ut-08068-r leaf blower leaking fuel
If we are talking about a hand held leaf blower. The fuel leaking from the carb is likely caused by a stiff metering diaghram holding the needle open. Rebuild your carb ( I suggest also replacing the fuel lines and primer bulb while you are at it) and double check the lever adjustment.
Oct 23, 2012 | Homelite Garden
Need to know; oil mixture spark plug setting for a homelite textron 330, ser.#3D2360270, Ut#10609
Hi gandp1993..
50 to One...oil to gas ratio 1 pint of 2 cycle oil to 6 gallons of gasoline.
Spark plug setting... .28 - .32
Please take time to rate me
Sep 22, 2011 | Garden
Need a chain tightner for a homelite textron ut no 105064 any ideas
There is a sscrew which moves the adjusting pin that you can see from the side. The screw is seen from the front. A screwdriver will do.
Hope this helps, if it does, please place a vote for me.
Thanks,
Handie Andie
Mar 27, 2011 | Garden
Homelite ST-155 trimmer; fuel air mix out of adjustment (operator error!). Will not start. Cleaned fuel filter, cap filter, added new fuel w/proper mix. Need basic fuel air adjustment to get it started.
do you have adjuster screw's on the carb???
if you do then screw them all the way in then back them out about 1 and half turn then slowly adjust until correct setting's are reached
Aug 18, 2010 | Homelite Garden
Wont idle have to run on 1/2 choke
yes, i have one myself. you must adjust the carb. there should be two screws to adjust the gas and air flow. try adjusting them to the right, both of thlem
May 15, 2010 | Homelite Consumer Products MightyLite...
Have trouble starting homelite textron chian saw carb setting
First is the gas mix right? 2 ids the air filter clean? 3. have you replaced the tank fuel filter to make sure it's getting gas? 4. is the plastic line cracked? 5. adjust both carb screws all the way down gently then reverse the screws counter clockwise 2 and 1/2 turns, this should allow it to start and run, once it has started let it warm up and adjust the idle for it to run smooth without dying. Once its running rev it up to make sure it does not have any dead spots in it then try a test cut, if it bogs down adjust the gas screw to in rich it just a little and try cutting again if it does not bog down you should be set. there are other things that can cause it to run poorly like a bad carb gasket or loose screws on the carburetor. If you need more help post here and I will give you some other things to look at.
Nov 07, 2009 | Homelite Garden
Would like to find out how to set carb hi/low speed on homelite mod ut 08030 leaf blower
This is not difficult but it takes patience. First screw both screws in full, then unscrew them out one full turn each.
Start your engine and working on the low screw first adjust it along with
the throttle control screw until you have ticking over nicely, then do the same with the H screw. Make your adjustments very little at a time. Stephen
Sep 06, 2009 | Homelite Garden
What is my lo hi carb adjustment for a Homelite Super XL ? with Homelite/Textron Div. Carb.
Jul 01, 2009 | Homelite Garden
Jun 29, 2009 | Homelite ZR10926 16 Chain Saw
Garden Logo
265 people viewed this question
Top Garden Experts
Jay Finke
Jay Finke
Dennis Key
Dennis Key
john h
