Question about Frigidaire FEF364DQ Electric Kitchen Range
How do you replace the baking element in Frigidaire Range FEF364DWA?
  • 5,911 Answers
The following link explains how to replace a heating element on an electric range:
http://www.fixya.com/support/r3575810-replacing_the_bake_or_broil_element_in_a
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
appliancepartspros.com
pcappliancerepair.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I have listed also have helpful exploded view parts illustrations to assist you in locating and properly identifying the parts you need.
If you have not purchased a replacement element yet, the part number you will need is 316075104.
If you have any questions about this repair, please post back and let me know. I hope this helps you.
Posted on Aug 27, 2010
Testimonial: "Thanks, I have ordered the part for replacement."
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
Replaced the baking element in my frigidaire oven but it still isnt working
Good Morning Karenand, thank you for your post!
I see that you have replaced the bake element in your Frigidaire range but it is still not working. If you wouldn't mind please providing me your model number, I can better address the issue at hand. The serial tag, which lists your model number, is typically located in the storage drawer, on the right side.
Meanwhile, I recommend resetting your range. This can be done by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn your range on. If resetting the power does not correct the issue, your range could be experiencing other issues such as: a communication problem with the EOC (Electronic Oven Control), an open thermal fuse or a potential wiring failure.
I ask that you please follow up with a comment, at your convenience, to advise if further troubleshooting is needed or if your range status has changed successfully.
Best of luck!
Jan 26, 2014 | Frigidaire Ovens
Frigidaire Gallery oven large element stopped working
Hello -
If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works, contact a professional to have the EOC (electronic oven control) diagnosed.
Sep 19, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
On Frigidaire Self-Cleaning Range, bottom oven element does not work while top element does; bake relay problem?
Sounds like the bake element is out. Remove it and test it for continuity. If you need further assistance please feel free to contact me.
Jul 09, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
How do I remove the bake element in a CFEF365RIS1 FRIGIDAIRE ELECTRIC RANGE.
  1. disconnect power
  2. remove screws holding bracket to rear inside wall
  3. pull element out slowly and disconnect wires,pull off
  4. if wire disconnects while pulling element out you'll need to remove rear panel to reconnect
  5. hope this helps,please rate my solution :)
Feb 03, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire ES200/300 316257123
look for a shorted bake element .. you should be able to see where it poped. ( some times ) if you have ohm meter you can ck for an open element . **** //
Dec 04, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Throws breaker when turn oven on
is it a new larger stove,then it could be a power supply deficiency,otherwise an element is bad or shorting to unit case and causing a trip
Aug 14, 2009 | Frigidaire FEF375E Electric Kitchen Range
Broiling works but baking does not work
CHECK FOR 240VOLTS AT THE TERMINALS OF THE BAKE ELEMENT. GAIN ACCESS BY REMOVING THE BACK PANEL OF THE RANGE. SOMETIMES THE TERMINAL WILL BURN OFF OF THE WIRE GOING TO THE ELEMENT. THE WIRE WILL JUST BE HANGING THERE. BE SURE TO UNPLUG THE OVEN BEFORE REMOVING BACK PANEL. IF THE WIRE IS BURNT, REPLACE THE TERMINAL AND REATTACH TO THE ELEMENTS TERMINAL. IF THE TERMINAL IS DAMAGED, REPLACE BAKE ELEMENT.
IF THERE IS NO VOLTAGE TO THE ELEMENT, REPLACE CONTROL.
Apr 03, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Open Questions:
Frigidaire FEF364DQ Electric Kitchen Range Logo
147 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
