Question about Keurig B60 Coffee Maker
My B60 just stopped working, is there a fuse on this thing that may need replaced
Fuse
Nope. If it got a power surge there is no telling what has happened to the many solid state components inside. I would check the transformer first, that is, IF you can get inside that thing.
Search you tube for disassembly instructions, there are a few.
Once you get inside check the power transformer. It should have continuity across the two input wires, and across the two output wires. If not, replace the transformer using the part number on the label.
Jun 26, 2013 | Keurig B60 Coffee Maker
My well just stopped working.
Well water has too many minerals. Use Distiolled water.
Sep 23, 2012 | Keurig B60 Coffee Maker
Keurig B60 lost power purchased Nov..2010
Because the debris has now clogged the exit port and needs cleaning with a paperclip end. pg. 18 Manual.
Jul 27, 2012 | Keurig B60 Coffee Maker
Keurig B60 not brewing a full cup
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sep 22, 2011 | Keurig B60 Coffee Maker
My 4 year old Keurig B60 just keeps saying "not
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Feb 19, 2011 | Keurig B60 Coffee Maker
My Keurig B60 only make 1/2 cup and then stops. Any suggestions?
heatman101
Dec 26, 2010 | Keurig B60 Coffee Maker
New Keurig B60 stopped working!
I had the same issue. I now believe that there was some "vapor lock" type issue. Mine would say the same thing, and i could hear the pump running, but the water level was not changing in the reservoir. I unplugged it, removed the reservoir, let it cool, then tipped it on its back for a few minutes, then on each side. Truthfully I was trying to see if there was some kink in the tubing. Couldn't find a problem, so set it back up and it runs great again.
Jan 01, 2010 | Keurig Special Edition B60 Coffee Maker
B100 shorting out
looking for fuses will not solve the problem
triggering the reset button is an indication of over load current and that is a short
take it to an appliance repair shop for repair or junk it
Dec 07, 2017 | Keurig B60 Coffee Maker
Keurig B60 Coffee Maker Logo
319 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
