Question about Maytag MDE308DAYW Electric Dryer
Maytag dryer model MDE308DAYW will not start. Why?
  • Maytag Master
  • 43,501 Answers
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair ? The dryer will not start
heatman101
Posted on Aug 29, 2010
vest6
  • 196 Answers
SOURCE: Maytag Electric Dryer MDE308DAYW doesn't turn on at all when pressing the button
Since the vent was filled with lint I would check the High Limit termal fuse located on the front of the heater asm. It is best to replace the fuse and thermostat. These parts are part of a kit that can be purchased from your local supplier. The heater asm is located in trhe bottom left of the dryer. and looks like this
Posted on Jan 18, 2008
larryyb
  • 291 Answers
SOURCE: ihave a maytag electric dryer model #MDE308DAYW
make sure it is unpluged ,,,,, take the two screws out on bottom of front panel, pull out and drop down, remove 2 screws holding top down and raise, 4 5 1/16 screws holds front cover in place, take those out, left up and remove ,,,, you can see all from there ,,,,,, drum also has to come out to replace parts.
Posted on Nov 25, 2008
stewsapplian
  • 8 Answers
SOURCE: model # MDE308DAYW dryer runs won't heat
check this page the break down on the dryer theres 2 thermostats and the heater check yours to see if you have coninuity across the heater and thermostates
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=MDE308DAYW&productCategoryId=0151200&brandId=3048&modelName=MAYTAG-LAUNDRY&diagramPageId=00003&componentDescription=BASE,%20HEATER%20&%20MOTOR&documentId=M0610236&backToLink=Return%20to%20Sub%20Components%20list copy and paste
my email is
stewsappliance@rogers.com
if you need help
Posted on Feb 11, 2009
dragonsthatk
  • 547 Answers
SOURCE: dryer not heating
most likely heating eleament change you can find here as well as diagram http://www.partstap.com/ please rate me thank you for useing fixya
Posted on Feb 25, 2009
  • 1122 Answers
SOURCE: what do i take apart the dryer to replace the
the steam on the front was 2 spring clips,one on each side in the front, use a putty knife to pop it up,then looks on the back wall and you will see the thermal fuse and the heater coil-mike
Posted on Feb 05, 2010
Please in very careful detail exsplain how to attach four prong plug wires to my maytag model no mde308dayw please help?
Here is a tip that will help you with changing your dryer plug. Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Sep 03, 2011 | Maytag MDE308DAYW Electric Dryer
MDE308DAYW NEED TO REATTACH THE BELT BUT DONT REMEMBER HOW. IS THERE A DIAGRAM I CAN GET?
http://www.repairclinic.com/Dryer-Belt-Diagrams?red=Dryer-Repair-Help#DiagramE
You need to see diagram E for maytag models. I hope this helps you out. If you need further assistanc, I would be glad to help.
http://repair-help.com/kb/index.php?article=105 here's another one too.
thanks,
mike
Jul 19, 2011 | Maytag MDE308DAYW Electric Dryer
I have a maytag dryer model # mde308dayw. How do you access the heating element to replace it?
remove 2 screws on the front cover by the floor lift bottom of front cover outward toward you and remove ,then undo wires at door switch,then remove drum belt and drum,then the heater element is at the right side near the base in a duct assembly
May 04, 2011 | Maytag MDE308DAYW Electric Dryer
I have a Maytag Dryer that has a twist knob selector that you push to start the dryer. The dryer stopped producing heat and then the knob would no longer start the dryer. The light inside went out at the...
Has the Timer gone bad? check the connections to the dryer because the timers sometimes die, make sure to turn of the power and unplug the unit form the wall.
Mar 25, 2011 | Maytag Dryers
My Maytag model MDE308DAYW squeaks and grinds when turned on.
i would assume that either the rear roller(located directly atop your heater, or yout idler pulley has gone bad , parts are probly about $40.. not a bad repair, you can probly find a how to on you tube
Oct 09, 2010 | Maytag MDE308DAYW Electric Dryer
Dryer won't start
On the bottom left is the heating element. On that element is a limit. If open the dryer will not run.ba9d1b0.jpgHere is an amana late model service MANUAL:
Apr 07, 2010 | Maytag MDE308DAYW Electric Dryer
Dryer squealing?
you need to replace the felt around the door if it is not this it is in the motor and I would just use it tell it dies then replace. thank you for using fixya
Jun 19, 2009 | Maytag MDE308DAYW Electric Dryer
Maytag MDE308DAYW Electric Dryer Logo
118 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
