Question about Home
I have a 400 model and the toilet keeps running. I have to take off the toilet cover and hit the level to stop from running
    Problem Solver:
  • 11 Answers
You might need a new float either that or the lever is just sticking
Posted on Aug 27, 2010
Can low water pressure cause my toilet cisterns to keep running
NO
persistent running is problem valve washers either in the water level control or the flush washer under the press buttons
low pressure will take a longer time to fill but when the level is attained the water will stop flowing in
Nov 16, 2016 | Home
Toilet driping sound at bottom after flushing
Either the flapper is not closing completely or the water level is too high so water runs out the overflow pipe. Level should be set at 1/2" below top of pipe.
Apr 27, 2014 | American Standard Home
I have a kohler model 703 # sb78drn, the toilet keeps running. i changed the flapper and now the toilet doesn't stop running. please help?
Try adjusting the float level. The float is what tells the toilet to stop filling. If the float is set too high, then water will just go down the overflow tube and never be able to get to the level it needs to turn off.
Mar 04, 2011 | Kohler Toilet - One Piece with Ingenium...
The toilet keeps running constantly - the tube in the tank is overflowing and i can not get the dripping sound to stop. Anything i can do?
The noise is because your float in the toilet is set at too high of a level and it is overflowing and making noise.
Reset your float, to adjust the water level just below the overflow pipe...this should stop your noise.
If it does not correct the problem then you will have to replace the water control unit inside of the toilet tank.
Please rate me
Dec 05, 2010 | Toto Washlet Elongated Toilet Seat Bidet
Toilet doesn't turn off after flush
The Kohler Cimarron is one of the most popular and reliable toilets out there. (My Favorite). However, depending on the hardness of the water and if you use cleaner tabs in the tank, these factors can lead to a malfunction.
The first thing you should do is hold the flapper (rubber seal inside the tank that releases the water down to the bowl) down with your hands for a few seconds after a flush and see if the toilet stops running. Sometimes the flapper doesn't seal properly therefore the fill valve keeps working non stop. Stopping the fill while holding the flapper down will confirm that your flapper needs to be changed.
If this doesn't work then try this....
The other common problem with a running toilet is with the fill valve itself. There is an attached float on the fill valve that goes up and down depending on the water level. Once the water level rises, it rises the float, and the float tells the fill valve to stop filling the tank. While the toilet is running (hissing), try raising the float all the way up with your hand and see if it stops. If it stops but not consistently with every attempt, then you will need to change the fill valve. I believe the Fluidmaster 400A is the replacement model.
Nov 23, 2010 | Kohler Cimarron Comfort Height elongated...
OUr 5 yr old duravit toilet is constantly running. Seems that tank water is seeping into bowl causing the mechanism to demand more water. Onl way to stop is to turn of water valve until we need. Before I...
if you can see the water running in the bowl it's a good chance that the flappers warn http://www.aplumbers.com/residential/toilet
1. tank the tank lid off.2. flush the rubber thing that comes up and allows the water to go to the bowl is the flapper 3. remove 4. replace that should fix it.
problem 2
1. tank tank lid off.2. if the waters flowing over the long tube in the center and down then the water level is too high3. adjust the level either it will have a ball **** or a float in either case   a ball **** adjusts by a screw on the fill valve. the float has a either a metal rod w/ a pinch clamp or a plastic long screw type thing.4. adjust water level .5. barely lift handle to allow a little water out til fill valve kicks on then release handle til valve stops .6. just keep re adjusting til you get the water level right there should be a molded in line for the level on the back of the tank.
Nov 16, 2010 | Duravit Tribeca US-Type Elongated Toilet...
I have the Kohler toilet with the top actuator, it flushes fine but won't stop running. If I lift the tank top I'm making the toilet flush again. Can this be fixed or do i have to replace the whole system?
(Problem 1) if you can see the water running in the bowl it's a good chance that the flappers warn. you'll have to look at the angle where the light hits the water. The water will be rippling where the top of the water meets the inside of the bowl edge.
For more info on how a toilet works = http://www.aplumbers.com/residential/toilet
solution 1
2. flush, the rubber thing that comes up and allows the water to go to the bowl is the flapper 3. remove 4. replace that should fix it.
problem 2 it could be the water levels to high.
(solution 2)
2. if the waters flowing over the long tube in the center and down then the water level is too high 3. adjust the level either it will have a ball **** or a float in either case a ball **** adjusts by a screw on the fill valve. the float has a either a metal rod w/ a pinch clamp or a plastic long screw type thing. 4. adjust water level . 5. lift the flapper to allow a little water out til fill valve kicks on then release handle til valve stops . 6. just keep re adjusting til you get the water level right there should be a molded in line for the level on the back of the tank.
Nov 14, 2010 | Kohler Acorn Lift-Knob Flush Actuator...
Our Toto ultramax model MS853113S will constantly
flapper most likely needs to be replaced not sealing completely is one problem----- the other is float level not shutting off water valve --and other is bad water valve not shutting off or worn and needs to be replaced remove cover and turn water on watch water level lift float up if water turns off valve good----turn off water if drain down flapper bad and needs replacement costs a couple of dollars to replace -if water stays level in tank than float needs adjustment or replacement
Aug 01, 2010 | Toto MS853113S#01 UltraMax Round Toilet,...
Our topflush toilet will nto stop running, once it is flushed. Theflapper seems secure. Not sure about the fill valve part.
after flushing observe flapper if it flops back and water is still getting by when tank is full than replace the flapper /if water is running down tube [high level]in tank than adjust level or if not responding to adjustment than flush unit is bad
May 31, 2010 | Kohler K-3360-G Revival One-Piece Toilet...
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
