Question about Microwave Ovens
Water is leaking down through what i am calling the vent in the top of the fridge inside and it is building up over a few weeks and then it runs out on the floor.
  • 5,911 Answers
I have experienced this very same problem before. There is a small condensate drain hole in the rear of the freezer compartment on some model refrigerators. If it ices over, the condensate has no where to go but down through the louvers and into the refrigerator compartment. It usually drips from the center overhead area down on to the shelves and accumulates in the bottom until it runs out the bottom of the door.. One way to tell is to check the back of the refrigerator to see if there is a visible drain line (larger in diameter than the ice make water line) that runs from the freezer compartment down to the compressor area. You may want remove everything and defrost the freezer and see if the problem goes away.
If you have questions/concerns, please post back with your MODEL NUMBER and let me know. I hope this helps you.
NOTE: Even if this is a frostless refrigerator, I have experienced the problem where ice can build up and plug the drain. You may have to remove the bottom tray in the freezer to access it.
Posted on Aug 27, 2010
We have water leaking from the back of the frige, coming from under the area where the copper tubing connects from the wall to the actual refrigerator. I can't identify exactly what's leaking. I doesn't...
This can be an auto defrost condition. If your fridge is auto defrost, what happens during the defrost mode, ice build up is heated (in the area immediately near the evaporator coils, not in the main area) . This ice becomes water and drains out via a small tube, typically at the back or bottom of the machine. This water normally goes into a pan under the fridge, and evaporates without the user being aware of it.
If anything causes excessive ice build up (opening the door too much, door seal leak, etc.) then you get too much water and the pan overfills and spills out.
I suggest that you remove the pan from under your fridge, clean it, and put it back, and test to see if yo actually have anything wrong, or not.
This leak would NOT be refrigerant, as you would cease cooling if so. it is all condensation, which is physics and normal...
Mar 20, 2011 | Microwave Ovens
I have a Whirlpool Gold top-mount fridge (GR2SH/GR2SHM). It's about 6 years old. About a year ago the freezer started to have ice build up and water would over flow into the fridge. I defrost the...
The defrost cycle is not working. After a predetermined number of hours of compressor running time, a timer actuates the defrost cycle, which stops the compressor and turns on a heating element to melt the ice. Either the timer or heating element is not working. Also, make sure the melted ice water is actually draining and not re-freezing.
Aug 31, 2017 | Whirlpool Microwave Ovens
My refrigerator has a leak behind the drawers on the inside . I have since had to put a towel at the bottom of the drawers or it will start leaking down the front and onto the floor every couple of days....
Moisture condenses out of the cold air inside the fridge. Many refrigerators have a drain tube in the bottom to allow the condensate to run into a drip tray under the refrigerator (behind the trim panel on the bottom) where it evaporates. Over time this tube can get clogged by food particles and the water backs up, eventually running over the bottom edge onto the floor. You can use a straightened out coat hanger or other stiff wire to clear it out. This should get the water back into the tray where it belongs.
Jan 21, 2011 | Microwave Ovens
Hi hope you can help, I have a 2 door fridge with a bottom draw freezer purchased new 2008 and I have lost the instructions.The prolem I need diagnosed is water leaking from the freezer draw. thanks.
Sounds to me like you have a leak, probably from an ice maker tubing connection or vinyl water supply tube itself. Have someone get a good flashlight and get a good closeup look at where the water is coming from. The water supply to the fridge's icemaker comes from the house wall, floor, or cabinet area of sink. Often they are connected to fridge, then someone moves the fridge to clean and the line gets run-over or tugged on too hard causing a leak. If that is cause, install a new line (hardware stores have these specific to ice makers, 1/4" vinyl or copper tubing) and it should be coiled several times in mid air near the wall, so if fridge is moved out it just uncoils not incurrs damage from un-noticed tension (full amount of water pressure in that little line).
2nd possibility for newer type fridge. All frost free fridges have a pan underneath that catches condensation from coils, from the pan the water evaporates into the air where balance is achieved and pan is never full. On rare occasions, like during moving, on some the pan isn't fastened down and can fall out of place, then condensation water from the coils falls to floor (not any great amount but some).
Jan 15, 2011 | Microwave Ovens
I have an intergrated fridge freezer and the water keeps freezing over the little hole at the back then the water drips down the back of the fridge into my veg drawer I have turned the temp down but this...
Common problem with fridges. Suggest you get behind the fridge and somewhere on top of the compressor, there is a small pipe that normally sits in a pan of a sort. You need to blow hard into the pipe which will release the blockage in the system and that will clear the line. Water will then start draining again onto the compressor. That will stop the water build up in your fridge.
Aug 08, 2010 | Microwave Ovens
My ge profile spacemaker oven is leaking water(?) i removed the metal filter and the liquid appears to be coming from inside. there is a metal "plate" about 1 inch above the filter and the liquid is coming...
unless something strange happened (like a spill) then the only component that has fluid in it is a large capacitor that is used to drive the magnetron ... if its case is ruptured then it will leak a few teaspoons of electrolyte .. thats a clear water or oil based liquid .. the failure of the aluminum case will cause a pop one time ... then its likelly the oven will quit working .. its also possible, if you have an outside vent for your microwave, that water is blowing into that vent down into the microwave .. check the exhaust to make sure its outside louvers are not damaged ..if it goes to the roof then make sure the rain cap is in place ..
Jul 02, 2010 | GE Profile Spacemaker 1.8 Cu. Ft....
The compressor does not work well and the bottom part emits heat
open door to the freezer and look in the back of the freezer and see if there is ice or frost building up,if so you have a defrost problem.it could be a bad timer or bad defrost heater or bad thermal switch.you nead a continueaty meater to check them out or call for a service call.
Nov 15, 2009 | Microwave Ovens
GE JVM1650 Microwave Suddenly Stops
Your magnetron tube is leaking RF energy inside and zapping the main board. It is NOT dangerous as any leakage will be contained inside the unit. You will need a new mag tube and it is covered by a 5 or 10 year parts warranty. Call GE Factory Service at 1-800-432-2737or schedule online at www.geappliances.com
Dec 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Water leaks into microwave oven
ok really if someone dareing enough to open the panel for microwave the shell i mean take to the porch let sun heat it for at least 2 days then go threw lightly wipe down insides of micro with water clothe to get water residue out of micro then place shell back on and screw down
once water gets into micro. its hard to tell how there performance will be after wards and putting a fan directly on a fan to airout wont help this will create other little problems like mold build up
the best thing is what i suggested at top you need a heat source to cook and evaporate the water inside which is the sun
Jun 02, 2008 | GE Microwave Ovens
Microwave Ovens Logo
62 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
