Question about Maytag Neptune MAH5500B Front Load Washer
Sounds louder than normal, in spin cycle. - Maytag Neptune MAH5500B Front Load Washer
    President:
  • 670 Answers
Could be the drum bearing failure. Turn the inner wash drum by hand. If it feels rough or makes a rumbling sound would mean that the bearing have failed.
Posted on Aug 27, 2010
Grinding noise before spin cycle
Good Morning John,
I see that you are hearing a grinding noise before the spin cycle in your Frigidaire washer, model# GLET1031CS0. A certain amount of "grinding" or gear sounds are normal in a heavy-duty washer. If you notice that the grinding sound appears to be getting louder, I suggest contacting either the manufacturer or your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
Mar 16, 2014 | Frigidaire Washing Machines
Washer goes through each cycle but won't spin at all. Generates a grinding or louder than normal noise during spin cycle
Sounds exactly the same probs I have and have been told it may be the drum bearings. Still waiting to find out if it is fixable.
G.
Feb 22, 2011 | Washing Machines
The washer recently began producing a high pitch squeek during the washing cycle, and a louder than normal sound during the spin cycle.
The motor Carriage is not pulling back fast/far enough special poly lube you can use other lube just wont last long or will deteriorate wheels quickly. What you can do is set for spin, hold open lid slightly with one hand pull back on motor slightly. If sound stops you got it. Other wise sounds like mount stem may need replacing if you do also replace spin bearing this is under basket and outer tub on top of transmission.
Nov 25, 2010 | Maytag Neptune MAH5500B Front Load Washer
It made a quite hum during the spin cycle, instead of the normal (much louder) spinning sound. When I turned it off I noticed it had a rubber/electric burning smell.
If it's a squealing sound, your belt is probably bad. If it's a humming noise with those smells you listed, it might be your transmission going bad.
Nov 02, 2009 | GE WBSE2090A Top Load Washer
Washer very louded in spin cycle.
Most likely this will be the drum bearings.
Bearings normally last quite a long time but some will fail sooner than others. Quite often bearing failure is due to a faulty drum shaft seal which allows a small amount of water through and in to the bearings. The bearings then start to rust, which then accelerates the wear on the bearings.
Replacing the bearings needs well above average DIY skills to do, so unless you feel confident to tackle the job, can get hold of a tech manual, and can get hold of new bearings, it's time to call an engineer for a quote and then draw your own conclusions as to whether it's worth it.
Oct 02, 2009 | Washing Machines
I have WP Duet HT front laod washer. Model #-GHW9250ML1 Type 199 080 SC/WG Problems - 1. while the tub is spinning it makes a knocking sound. When the tub slows it knocks louder. What is the problem and...
COULD BE LOOSE BASKET OR REAR BEARING LEAKING OR SIMPLY SUSPENSION SHOCKS BROKEN ,, EVEN SHOWS 1 MINUTE JUST ESTIMATE TIME NOT READY TO SHUT DOWN NORMAL ON DUET MACHINES
Nov 29, 2008 | Washing Machines
Loud spin cycle
OTHER THEN CHECKING THE WATER PUMP I THINK YOUR RIGHT THE BEARING ARE GOING,IT WILL WORK FINE TILL THEY LOCKUP THEN THE BELT WILL BURN OFF,BUT I WOULD CHECK THE WATER PUMP ALOT OF TIMES IT JUST THAT,LET ME KNOW -MIKE
Nov 03, 2008 | Frigidaire FTF530ES
Washing machine is louder then normal on the spin cycle.
This sounds like the rear bearing is going. After getting louder, the next problem is grease appearing on your clothes during the spin cycle. This is a very major repair.
Jan 10, 2008 | Kenmore 43042 Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
42 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
