Question about Vtech KidiJamz Studio
I'm looking to reconnect a Kidijamz microphone back to the circuitboard inside the microphone. The wires were pulled out and can be resoldered. I just need to know which color wire goes where. There are 4 Red, Brown, Black and Blue. I know where the black one goes.
How can I fix a broken cable inside a sennheiser mzh3040?
you have to unsolder the wires on the coil assembly then pull everything out through the bottom. replace the bad wire, reassemble the xlr end and resolder the wires to the coil.
Aug 05, 2014 | Sennheiser Audio Players & Recorders
Keeps saying turn off message with new batteries
Ours had the same issue. I took the Vtech Kidijamz apart. The power button has its own little board. I unscrewed that. It connects to the next board via two wires. I reflowed the solder for all the connections for those two wires (four solder points total). Issue fixed. FYI: reflowing solder just means heating each solder point (with a soldering iron) until the solder gets soft and then removing the iron to let the solder cool and thus harden.
Oct 05, 2013 | Vtech KidiJamz Studio
Vtech KidiJamz keyboard: keeps saying turn off message (Let's jam again later..) and then turning off even with new batteries in place.
Karoake will not put sound through speaker or microphone memorex mks8595
download your instr. manual from www.retrevo.com or www.manualslib.com
Amplifiers are assembled with many of the same components as other appliances, so fixing basic elements is similar. For example, cords may not consistently deliver electricity, switches and controllers can cause problems, and fuses may need to be replaced. Frequently, however, what the amplifier needs most is simply a thorough cleaning with some canned air and/or contact cleaner.
The first step in fixing internal parts in your amplifier is to open the unit up. Most amplifiers are encased in a two-piece housing--top-front and bottom-back.
audioamplifier3.jpg Besides fuses accessed from the back of the cabinet, many amplifiers include one or more internal fuses. Disassemble an amplifier:
  1. Make sure that the electrical cord is unplugged from the wall receptacle.
  2. Remove screws on the side, back, or bottom to separate the cover from the chassis.
  3. Slide the two halves apart to expose the internal components mounted on the chassis (lower frame).
  4. Inspect the internal end of the electrical cord for looseness or damage caused by being pulled (a common problem) and replace as needed.
  5. If there is no power, but the cord works, look for an internal fuse. Test the fuse and replace as needed.
  6. Use a can of compressed air to carefully blow away dust that is attracted to electronic components. If excessive, use a vacuum cleaner with a plastic tip (so delicate parts won't receive static electricity) to clean the inside of the unit.
  7. Use electrical contact cleaner to clean the input jacks and speaker terminals. If one of the input jacks is disconnected from the wires, either reconnect or resolder it.
Oct 01, 2012 | Televison & Video
Audio Tech at831cw lapel mic wires disconnected
normaly when pulled out the cable is also come inside defective, probably better a new mic spare. you can spend time repairing and still no working well
Jan 02, 2010 | Audio Players & Recorders
Astatic 636l microphone Cobra 29ltd classic
pin 1= sh & bl
pin 2= wh
pin 3= red
pin 4= blk
yellow = not used or put on pin 4
Nov 02, 2008 | Astatic 636L Noise Canceling Microphone...
Need to reconnect wires inside microphone
Usually black is the ground wire, or shield and red is the hot wire that goes to the center contact or one away from ground. White or green could be common or ground too. Graphics:
https://www.google.com/search?q=microphone+model+5895+wiring&client=firefox-b-1-ab&tbm=isch&source=iu&ictx=1&fir=f2aToZE7X9AjLM%253A%252C-Aeo5QT9ebcsqM%252C_&usg=__V4gXVSInodd_bBjOw1pAd6yuKkU%3D&sa=X&ved=0ahUKEwiY_rPa3rfZAhUGON8KHdnNA1kQ9QEIKzAA#imgrc=f2aToZE7X9AjLM:
Feb 21, 2018 | Shure MICROPHONE Microphone
Astatic mic. model 636-L
http://homepage.ntlworld.com/rg4wpw/astaticbook.pdf
Mar 13, 2008 | Astatic 636L Noise Canceling Microphone...
Vtech KidiJamz Studio Logo
Top Vtech Toys Experts
Nikki  Mclean
Nikki Mclean
GI Consulting
relojmesa
Are you a Vtech Toy Expert? Answer questions, earn points and help others
