Question about GE 24.6 cu. ft. Side-By-Side Refrigerator with LightTouch Ice and Water Dispenser
Water Dispenser Hi, The water dispenser dispenses water very slowly...will not dispense at all when the undersink filter water dispenser is on. Could it be a pump? Thanks in advance! Steve
  • Anonymous Mar 14, 2014
    our water dispenser is not dispensing and do we have a water filter? we did not purchase, it was in an existing home we purchased
    Genius:
  • 1,073 Answers
Water fill valve or if equipted need to cnage water filter
Posted on May 06, 2008
No water from dispenser Matag New filter solenoid valve working, tube to dispenser seems to be blocked
Hello Hans;
My name is Peter. I am a retired field service refrigeration technician.
There could be several areas that would effect your water dispenser not working:
1.) When you depress the water dispenser do you hear a 'Click'? If not you have a bad water dispenser contact switch.
I would send you a diagram but I do not have your model number.
2.) In the lower back of your fresh food section is your water dispenser water tank. At times this can freeze near the freezer section. Look in the lower corner of the freezer & your fresh food section for ice build-up.
3.) You could have a bad water filter. This does happen often. Remove the water filter and test you water dispenser.
4.) Do you have water leaking out of the bottom of your dispenser door? If so you have a split in the tubing in your water dispenser door.
5.) Is your ice maker working? Often the water valve to your refrigerator becomes plugged up and you do not get sufficient water pressure 60 PSI to operate your water dispenser solenoid valve.
Nov 15, 2014 | Maytag MFD2561HE Stainless Steel Bottom...
Inside water dispenser pumps water out really slowly on GE Profile PFS22MISBBB
It is possible that your water filters are getting plugged. Have you changed any filters lately?
The meat pan lever may also be turned to the coldest position and on units that have a low water usage, this will also cause the tank to freeze. You will want to lower the meat drawer setting or use more water from the door. This does not apply to Top Mount water dispenser models, because they do not have a reservoir. Problem requiring service, glass fill time.
View a short video about troubleshooting water dispenser issues :
Play Video
View a short video about slow water dispensing issues:
Play Video
  • Dispenser drips water constantly will be a water valve problem, and should be checked by a service technician. If you would like to schedule a service appointment, please contact GE Consumer Service at 1-800-432-2737 or schedule a service appointment on-line.
  • Dribble as defined as a small amount of water (few drops) that may miss the glass ONLY AFTER USAGE. This is due to a delay in the overall system.
    Dribble can be minimized by the following actions:
    - Purge the tank, by holding down the dispenser for 2 to 3 minutes, to remove any trapped air that may be building pressure and causing the dribble.
    - A few drops is normal, but you can also prevent water from missing the glass and dripping down the cradle area by moving glass slower when removing it from the cradle.
    - You may need to periodically empty the recess grill and clean out underneath it to prevent overfilling and water dripping down the front of the refrigerator.
  • Also, remember the dispenser in the door will not operate unless the door is closed
  • Apr 10, 2012 | GE Refrigerators
    Bought a new Maytag side by side. Will not put out water. Tried the 5 sec on and 5sec off to flush the air out, still didn't work. What next?
    Hi and welcome to FixYa, I am Kelly.
    First off you need to make sure the freezer door is CLOSED and water filter is properly installed in the filter housing. Without a model number I can not tell you the exact location of the filter. There is a water lock out function of the water filter housing that will prevent proper water flow until the filter is installed correctly or removed completely. Also... there is a water tank / reservoir that has to be filled completely with water before you will see any water at the spigot. Please pass your model number so I can better assist you or call the Maytag Sercive Center so they can walk you through the initial set up procedure of your refrigerator. (They will also need your model number) Go to http://www.maytag.com and register your appliance before making the call.
    1 (800) 344-1274 U.S.
    1 (800) 688-2002 Canada
    Before making the call check out this information about troubleshooting:
    http://maytag.custhelp.com/app/answers/detail/a_id/110/kw/Water/session/L3RpbWUvMTI5ODY4MTEyNi9zaWQvam9CYWV5bms%3D
    - After connecting the refrigerator to water source or replacing the water filter, flush the water system. Use a sturdy container to depress and hold the water dispenser lever for 5 seconds, then release it for 5 seconds. Repeat until water begins to flow. Once water begins to flow, continue to press and release the dispenser bar (5 seconds on, 5 seconds off) until a total of 3 gal. (12 L) has been dispensed. This will flush air from the filter and water dispensing system, and prepare the water filter for use. Additional flushing may be required in some households. As air is cleared from the system water may spurt out of the dispenser.
    - Make sure the dispenser is not locked. Some models have a lock feature that deactivates the dispenser levers and control buttons. The lock button is on the dispenser front cover. This feature controls unintentional dispensing during cleaning. Press the Unlock or Locked button to reactivate the dispenser levers and allow dispenser function. You may need to hold the button for 2 to 3 seconds.
    - If there has been a recent power outage or the power supply has been off for more than one hour, the power outage indicator (on some models) will disable the dispenser function. The dispenser display will read "PF" to indicate power failure. To use the dispenser, press and hold the "Reset" button for 3 seconds until you hear the beeps.
    -A clogged or incorrectly installed water filter will reduce the water flow to the water dispenser. Check for a problem with the filter by removing the filter and operating the dispenser. If water begins to flow, then the filter is either clogged or incorrectly installed. A clogged filter will need to be replaced.
    If the filter is clogged and you are not able to immediately replace it, leave the filter out so the water system is in bypass mode. With the filter removed, the water system will continue to operate, bypassing the filter, and the clogged filter will not cause slow water dispensing. However, in order to have filtered water, you will need to install a new filter.
    All Genuine Maytag Water Filters retain beneficial fluoride and are NSF Certified for drastically reducing chlorine taste and odor, particulates, lead, mercury and cysts.
    To ensure glass after glass of clean, refreshing ice and water, change your filter yearly or whenever the system light indicates.
    about the filter:
    http://assets.whirlpool.com/files/usr/animations/ANM000085.htm
    The information above should get your water working. If not please listen for a solenoid buzz as you actuate the water in door function. No buzz either the dispenser is locked off or.... you have a valid warranty claim.
    Thanks for choosing FixYa,
    Kelly
    Feb 26, 2011 | Maytag Refrigerators
    The inside water spout on this refrigerator stopped dispensing water
    Checckwater pressure.The 1/4" water supply line should deliver at least 9 ounces of water in 5 seconds. If not, the water pressure is low. Make sure the dispenser is notlocked. Some models have a lock feature that deactivates the dispenser andcontrol buttons. The lock button is located on the dispenser front cover.This feature controls unintentional dispensing. Press the"Unlock" or "Locked" button to reactivate the dispenser andallow dispenser function. You may need to hold the button for2 to 3 seconds. A clogged or incorrectly installedwater filter will reduce the water flow to the water dispenser. Check for aproblem with the filter by removing the filter and operating the dispenser. Ifwater begins to flow, then the filter is either clogged or incorrectlyinstalled. A clogged filter will need to be replaced. Thanks.
    Feb 03, 2011 | Amana ARB2259CS Bottom Freezer...
    Water dispenser dripping water all the time
    First be sure the refrigerator is connected to a cold water supply. After connecting the refrigerator to a water source or replacing the water filter, flush the water system. Use a sturdy container to depress and hold the water dispenser lever for 5 seconds, and then release it for 5 seconds. Repeat until water begins to flow. Once water begins to flow, continue depressing and releasing the dispenser lever (5 seconds on, 5 seconds off) until a total of 12 L has been dispensed. This will flush air from the filter and water dispensing system, and prepare the water filter for use. Additional flushing may be required in some households. As air is cleared from the system, water may spurt out of the dispenser.
    One or two drops of water immediately after dispensing is normal. It may be necessary to hold the container under the dispenser for 2 to 3 seconds after releasing the dispenser lever.
    Hope this will be useful.
    Thank you
    Jan 04, 2011 | Whirlpool 25.4 Cu. Ft. Side-by-Side...
    Water dispenser runs very slowly. it doesn't seem
    If it's not the filter, then the water valve is most likely defective
    Oct 30, 2017 | GE Monogram ZFSB26DRSS Stainless...
    My water dispenser flows very slowly. The unit is
    Check for clogged output valve. Second the filter candles require an annual change as they also get clogged from filtering water.
    Thanks for using fixya
    proton
    Aug 14, 2009 | Refrigerators
    Whirlpool side-by-side refrigerator - 2 problems
    I would suggest that you get a certified person to come out and look at it you very well could have bent the doors in the move.
    but... if you want to do it yourself.
    click here for a walkthrough
    for your drip:
    Flush air from the water system the first time it is used and after replacing the filter. Air trapped in the water line or filter may slowly travel through the coiled water reservoir to the dispenser, pushing any water ahead of it. This can cause the dispenser to drip. Water needs to completely fill the lines for all air to be cleared.
    • Use a sturdy container to press and hold the water dispenser bar for 5 seconds, then release it for 5 seconds. Repeat until the water begins to flow. Once the water begins to flow, continue pressing and releasing the dispenser bar (5 seconds on, 5 seconds off) for an additional 2 minutes. Repeat if dripping starts again because air can re-enter from the water supply.
    • As air is cleared from the system, water may spurt from the water dispenser.
    • Make sure the refrigerator is connected to a cold water supply.
    Jan 26, 2008 | Refrigerators
    Refrigerators Logo
    1,375 people viewed this question
    Top Refrigerators Experts
    Sal De
    Charles T Nevin
    Charles T Nevin
    RepairNinja
    RepairNinja
