Question about GE Refrigerators
I Have a GE fridge with this motherboard part number WR55X10942. Recently the fridge started making the clicking sounds and shut off so I traced the sound to this motherboard. I am on the net looking for prices to replace this board and I run across this forum and looks like a whole lot of people are having the same problem with the same motherboard. This starts me thinking. Is this a common problem? Is this part under a manufacturer warranty? and why is the consumer having to pay for this obviously defective part when I see that a bunch of these problems are in units that are less than 5 years old? Then to add, someone goes and raises the price of the board another $20. Probably cause they are making a killing on them...Just wondering if this is a "normal" situation in the appliance world? Thanks for the help and info
SolutionGuy
  • 331 Answers
SOURCE: clicking noise-GSH22JFR/SH200106
Fluk, based on my experience with these refrigerators, I'd bet you the Mother Board has failed. That's where the clicking is coming from. To verify this, pull the refrigerator out away from the wall then remove the aluminum panel back there (there are 4 screws holding it in place). This will expose the mother board. You won't have to use any more tools to diagnose it... you'll hear the clicking sound coming from this board.
Your 5 yr. warranty information only applies to the sealed system components; compressor, condenser, evaporator and freon. The board isn't covered, I'm sorry to say. You can try calling GE at 1-800-GE-CARES (1-800-432-2737) and explain to them that your board has failed, but I doubt you'd get very far. (They will probably try to talk you into having a GE repair company come out and do the repair, though. <-- at a cost of about $275.00.)
You can repair this for the cost of the part... about $120.00. The part number you'll need is WR55X10552 and can be obtained from your local appliance parts store (like Sears) or purchased online. There is an instruction sheet that comes with the replacement part... read it carefully. This is a very easy repair, it can be done in about 20 minutes. Remember... If you repair it yourself, UNPLUG YOUR FRIDGE BEFORE YOU BEGIN!!!
*TIP---> After you have the repair completed, plug your fridge into a quality surge protector, like this one or something similar.
Posted on Oct 14, 2007
Sea Breeze
  • 4655 Answers
SOURCE: 3 YEAR OLD FRIDGE. DEFROST PROBLEM. FREEZER NOT
Your refrigerator has a defrost timer located inside the fresh food compartment if bad this will stop the defrost, I did not see a circuit bort for the model ED5FHEXMQ Make sure your model is correct because it will mislead any attemp to give help, Thanks, Sea breeze,
http://servicepartstec.blogspot.com/
Posted on Mar 27, 2009
SOURCE: Need help finding the defrost timer in GE fridge !!
frigidaire Model frs22zrg Water leaking into the the dispenser (where you put the glass. Also the ice dispenser become iced and where the ice comes out.
The moisture is inside of the freezer part, may need a time or the heating coil is not working.
Posted on Aug 08, 2009
aasc
  • 1606 Answers
SOURCE: Whirlpool fridge incessant buzzing
The knocking noise when cuts off , is a compressor internal motor support spring , broken . This does not mean the compressor is bad , only noisy for the rest of the compressor life , but should be covered under the 5 yr warranty . The gurgling sound is the refrigerant being pumped thru the system . The buzzing could be from the compressor also . My suggestion , would be to call a factory warranty company , to see if they can replace the compressor under warranty .
Posted on Sep 07, 2009
Testimonial: "Super quick reply and very helpful - thank you!"
SOURCE: My GE side-by-side howls. Model GSL25IGRBBS.
First of all - make sure you route the green grounding wire connector from the board to one of the screws, holding the board cover. If you leave it hanging - you can kill the board if the wire touches some of the board elements.
Second - check what kind of sensors you have in your fridge. There are three of them: one in the fresh food section, and 2 in the freezer.
If any of the sensors has black compound where the wires enter the white plastic cylinder, you'll need to replace it with the newer one: WR55X10025
Locations: One behind the damper cover in fresh food section (far left top corner)
One in the far left bottom corner (small cover with 2 white wires to it)
One (which most likely makes the problem) is on top of the evaporator (coil in freezer section, behind the lower back cover). Ifyou replace any of them - make sure to insulate the splice points with food-grade silicone.
Posted on Oct 16, 2009
Testimonial: "You truly are my guru. I don't know how you knew exactly what to look for, but the thermosters were just as you described. Thank you, it works!"
Have a GE GSS25QSTA Fridge and tonight, smelled weird smell coming from that and then making a sizzling noise?
Sounds like either your motherboard or compressor start relay may be having trouble. For a location Click Here=>
GSS25QSTASS Rear Section, Motherboard and Compressor Components
In this photo you will see location # 801 and 735. Part number for the 801 is=> WR55X10942 and part 735 is=> WR09X10107 Click Here for=> GE/Artica Technical Information and here for a=> Service Manual I will be here to see if the smell and sounds were coming from another location but if for some reason the refrigerator has stopped cooling I believe I am on to the problem. Please rate if correct or if you need assistance and advice on what to do to solve this completely let me know, Thanks, Sea Breeze
May 01, 2011 | GE GSS25QSTSS Stainless Steel
Digitai temp display dead fridge makes clicking noise
This sounds as if you have lost the low voltage side of the motherboard. You can look over the motherboard by unplugging refrigerator and pulling away from the wall. In photo Here=> PDS22MFSACC GE Cabinet Parts You can see item number 801 in the photo that is the motherboard location. Look it over closely back and front while power is disconnected. You may just see burn marks. The motherboard part number=> WR55X10942 where there is no photo and here where I have a photo=> WR55X10942 in right sidebar half way down that page.
Couple things really are important are the tech sheet and wiring diagram
Here
I know yours is a bottom freezer but clicking on the wiring diagram opens into a new tab GE Service Manual. You can follow with me on that if you would like to do
it yourself. Let me know, Thanks, Sea Breeze
Jan 17, 2011 | GE PDS22MFS Bottom Freezer Refrigerator
Hi i have a ge fridge,about 3 years old model #gdl20kcsabs it started making a clicking sound and started defrosting everything. it has also been getting very hot on the outside bottom freezer panel to...
Clicking sounds (not immediately preceeded by a power loss) indicate a bad relay on the mother board. Replace the mother board, WR55X10942)
Aug 21, 2010 | Refrigerators
Click click click repeatively - lights and digitals flash every time it clicks. GE Profile PDS22SFSBLSS
Replace the motherboard, part number WR55X10942
It is easy to replace, from behind the refrigerator.
Apr 25, 2010 | GE Refrigerators
Clicking sound coming from the back
The board on the back wall behind the metal plate has gone bad. wr55X10942 is the part number I believe. You can try unplugging unit for about 30 minutes and then plug back in but sounds as if the board has gone bad on you.
Apr 12, 2010 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
Loud buzzing sound. warm fridge and freezer
Could not find info for the model listed could it be PFS22SBASS...any way the most common reason for your issue is the main motherboard part #WR55X10942
prices vary $180 - $200. The circuit that operates the compressor is most likely at fault. Most boards are located at rear of unit lower right, it controls all refer functions. Not hard to instal,l but due to the cost most electrical parts bought are not returnable.
Ric
Mar 09, 2010 | GE PFS22SBSSS Stainless Steel French Door...
A clicking sound was coming from behind my fridge and the temp display was not working. digital display. the light in the fridge comes on but the fridge is not working What could it be?
You have a bad main control board , located on the back of the refrig , behind an 8" X 10" panel . Part number WR55X10942 . This control board , usually clicks when the compressor tries to start , or when the compressor cooling fan tries to start . It also controls the display .
Sep 24, 2009 | GE Profile PDS20MFS Bottom Freezer...
My GE Fridge is making a clicking noise and Digital display out
Replace the mother board. (part # WR55X10942 )
Aug 21, 2009 | Refrigerators
Refrigerators Logo
77 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
