I have my toughbook cf-50 and the battery doesn't charge just a red light blinking..... I am not a tech woman, but if is possible give some instruction and how to fix I will give a try Please? Thank you
  • rbigras Aug 27, 2010
    Sorry technocraff, but all this I already did and nothing works!
    I check the power, I bought new battery and nothing!
  • 540 Answers
Hi!,
The battery or the charging circuit may be defective please remove the battery and then wait for 60 secs after that power on and check the issue if the issue do not resolve then repair the pc.
Posted on Aug 27, 2010
Panasonic CF 50 battery light flashing red light
A "Red" Flashing Battery Light on ALL
Panasonic Toughbook Models means
that the battery is no longer functional
and can no longer hold a charge properly.
If you really require a battery then you
may be able to order a replacement
battery from the Panasonic Parts Dept.
An original battery cost might exceed the
value of an old CF50 so be aware and
take note.
It is possible to completely remove the
battery pack and use the CF50 without
a functional battery pack with no problems.
Good Luck
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989
Sep 25, 2012 | Panasonic (CF-50MB2FDKM) PC Notebook
Toughbook CF-74 Doesn't Charge or Power On. Core 2 Duo 2.0GHz.
Try powering the unit from the wall socket without the battery. This will eliminate the battery as the faulty componet.
Yes I would say this is a fault with the receiving power connector on the notebook. It will need to be repaired.
Take care!
damnor01
Sep 16, 2012 | Panasonic Toughbook CF-74 (CF-74HCDAZBM)...
My company uses Panasonic Toughbook CF-18. We have ones that are over a year old, over 6 month old, and even just a few months old. In the past few weeks we started experiencing a problem where the units...
The battery interface has broken away from main board at the limit stop. Requires trained tech to repair. You mentioned these are new.. Cf 18 have been discontinued for years. Are these cf19's
Sep 08, 2011 | Panasonic Toughbook 18 CF-18NDHZX-VM...
Battery light is blinking red and will not charge
Welcome to Fixya! If the battery light is blinking red,that indicates low power, there's a possibility that the problem is with the AC adapter, or the battery or maybe the DC port itself, please follow these simple steps for you to be able to isolate the exact problem.
1. Removed the battery.
2. Connect the laptop directly to the power outlet without using the battery just for the meantime.
3. Turn on the laptop. If the laptop is able to power on, that means that the AC adapter is working fine as well as the DC port. If the laptop is not able to turn on, it maybe the AC adapter itself or the DC port.
4. Try to use another AC adapter if possible, make sure that that AC adapter is working fine. If the laptop is still not turning on, the problem is with the DC port itself. In that case, you will need to replaced the Motherboard itself.
Hope this will help...Thank you for using Fixya...
Feb 28, 2011 | Panasonic Toughbook CF-73 Notebook
I have a toughbook cf-19 and the charging lite keeps blinking red
You have a DC connector problem:
Symptoms of a broken power jack
1. If you wiggle the power cord or the AC Adapter connector on the back of the laptop, the power LED and battery charge LED start to flicker.
2. Battery will not charge in the laptop.
3. Laptop runs fine off a charged battery.
4. With the AC Adapter connected the laptop appears to be dead.
No power LED or battery charge LED activity.
5. Laptop randomly powers off without any warning.
If your laptop is out of warranty, then you can fix the problem by re-soldering DC-IN jack on the system board. If it
Jan 29, 2011 | Panasonic Computers & Internet
Panasonic toughbook cf-48 two batteries went bad within a day
Place battery in freezer for 2 hours / remove and recharge, might make it last longer. (Removes any "memory" in them)
Might be worth checking the charger to ensure its working OK. Just becuase the light is on doesn't always mean its working.
Mar 10, 2010 | Panasonic Toughbook CF-51 Notebook
I was on my Panasonic Toughbook CF 73 this morning, I had been using a wireless connection, but I could not get the wireless to work, so I plugged in the adapter and the phone line for dial up, I got...
On all Panasonic Toughbooks the following works.
Please unplug you Toughbook and remove the battery pack.
Then Please do not put the battery pack back in.
Without the battery pack, plug back in the Toughbook.
Try to start the Toughbook, it should work.
If it does not, try to hold down the power button for 12-15 seconds continuously. This should "reset" your Toughbook.
Good Luck.
Richard, Montreal Based Panasonic Authorized Toughbook Dealer since 1989.
Nov 29, 2009 | Panasonic Toughbook CF-73 Notebook
Battery light flashes red when plugged
that means it is charging and your battery is low in charge but if it contineous on red light and it is plug to the power supply, then have your battery check in the service center
Nov 04, 2009 | Panasonic Toughbook 29 Touch (P/N...
Manual for Panasonic CF-27 Toughbook
Web Site
http://www.panasonic.co.uk/html/en_GB/220239/index.html#anker_220239
Donot enter model# in first slot.
Enter Computers in second
Enter Toughbook in third
Select CF-27E
Everythink is there, two pages.
Manual isn't much use.
Jan 13, 2009 | Panasonic Toughbook CF-27 Notebook
Computers & Internet Logo
213 people viewed this question
David Payne
David Payne
