Question about Maytag 24 in. MDB4100 Built-in Dishwasher
We turn on the Dishwasher but no water coming into the dishwasher
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Aug 28, 2010
Changed the washer, turned tap and dishwasher on but water won't go through to dishwasher
Might be better to check if the water is coming out of the tap. Also confirm if you are getting any error code on the dishwasher.
Feb 06, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
No water comes into my Bosch dishwasher when I turn it on.
Here is a tip that will help you to find out why water will not come into thedishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Mar 31, 2011 | Bosch 24 in. SGS45E02 / SGS45E08 Exxcel...
I turn on the dishwasher you hear a cycle of water and then turn on the light F7 and the dishwasher stops.
f7 means a water flow meter problem. Either your dishwasher is not getting proper water pressure, or the flow meter is bad. Check to make sure you have good water pressure to the dishwasher, and then check that your water is coming in at a good flow rate. If both of these are ok, then replace the flow meter. If your house water pressure to the dishwasher is good, but your water flow coming into the dishwasher is slow, then your dishwasher water valve is probably plugged. Some valves you can take apart and clean out, and some you will need to replace. Good Luck,
Mar 28, 2011 | Dishwashers
Water does not come into the dishwasher. can hear the pump, the heater works, the indicator lites illuminate, but water does not come in. The water supply is hooked up and turned on, there is good flow...
Usually the problem is the soleniod valve that lets the water into the dishwasher...
here is a tip that I wrote that gives many more details about this problem...
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Aug 21, 2010 | Dishwashers
No water is coming into the dishwasher. What should I do?
I will have to assume the dishwasher turns on when you press the start button.
Very hard to provide solution without knowing the make and model of the dishwashwer.
Possible causes of water not coming when dishwasher program has commenced are-
1. water tap is not turned on.
2. the water inlet solenoid in dishwasher is faulty
3. the float switch at base of dishwasher (depending on model) is triggered and thinks the dishwasher is already full of water.
Happy to provide a specific solution if i know the details. Please post a comment.
Jun 13, 2010 | Dishwashers
Dishwasher won't wash (water doesn't come in)
just a suggestion it sounds like a plumbing problem with the water hook up have a good service man come and inspect it
Sep 19, 2009 | Whirlpool 24 in. ADP5962 Free-standing...
PDW7880J10SS: No water
First check to be sure that the valve that controls water coming from the hot water supply is turned on. This may be right under the kitchen sink. If it is turned off, just turn it back on and u should be set.
However, if you have water coming to the dishwasher but no water in the dishwasher it has to be one of two items:
Water-inlet valve The water-inlet valve lets water enter the machine. If this valve is defective, you need to completely replace it. It's usually located behind the lower access panel on the left or right side. It's the device with the main water line (usually copper) from the house, a rubber tube to the dishwasher, and two wires attached to it.
Float switch The float switch is a small electrical switch that's located right below the dishwasher "floor." Above the switch, on the inside of the dishwasher, is a plastic cylinder that floats up as water fills the dishwasher. If this switch is defective, or if the plastic float gets caught or trapped in the raised position, the water can't enter the dishwasher. If the float switch is defective, you need to replace it.
Feb 11, 2009 | GE 24 in. Profile PDW7800 Built-in...
KitchenAid dishwasher overflowing; water will not stop coming in
If it is filling when the dishwasher is off then you need a new water valve.
Jan 13, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Asko 1805 ALL lights flashing and no water coming out
High water level is often in the pan under the dishwasher.
  1. Unplug or turn off breaker.
  2. Remove kick panel.
  3. Remove water from pan.
  4. plugin/turn on breaker.
  5. watch for leaks.
May 30, 2008 | Asko 24 in. 1885 Built-in Dishwasher
Maytag 24 in. MDB4100 Built-in Dishwasher Logo
59 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
