Question about Humax LD2060 20 in. EDTV-Ready LCD Television
Humax 20" lu20-td2 tv just flickers use to flicker then come on now just flickers thank ernie
    Problem Solver:
  • 17 Answers
Needs new capacitors if you look on mainboard it is 31 32 33 just fixed 2 with same problem
Posted on Jun 29, 2011
  • Matthew Clarke
    Matthew Clarke Oct 23, 2013
    Where are the caps on the main board I assume they are electrolytic but cannot find them I have board rev1.0
Hi there I have a humax lu20-td2 won't scan for channels
If it wont scan anything, you possibly have a broken tuner. On some models you can change the tuner yourself , on others you will need to send back the unit for repair.
If its build in then forget about the " diy" repair, however if you see 2 screws (each one on the left and right side of the cable input) you can take the faulty tuner out, and replace it with a new one.
Apr 07, 2015 | Humax Televison & Video
How do i unlock Humax LU23-TD2 TV
If you wish to get some details; check the site linked here. Pull up older posts.Surf the site with patience.http://electronicshelponline.blogspot.com/
Visit the associated blogsites too.
Sep 21, 2014 | Humax Televison & Video
Why is my vizio tv flickering?
either inverter board fault or power supply fault!
Jun 07, 2014 | Vizio L32 32 in. LCD HDTV
Setup humax lu23 td2
have you tried plugging other any other components to the ports to see if it does the same thing
Dec 01, 2013 | Televison & Video
Hi there I have a 20" Humax IDTV - LU20-TD2, it
Look for any jammed buttons on the remote or on control panel. Try changing the input device to something that you are sure, works.
Jul 29, 2012 | Televison & Video
Humax lu23 td2 cannot retune it say menu not avaliable when i press the menu button
Is tv being used in the av modes if so tuning menu will not show. Possible cause could be external units like dvd player are taking control . Unplug all external unit and try menu again
Regards Derrick
May 13, 2012 | Televison & Video
I have a Humax LU23-TD2 Flat Screen LCD TV and I think the fuses have blown. Anytime I try to plug it in (has only been twice) i get a flash and a bang.
I have the same tv, has started to give out a few seconds of black screen on the odd occasion whilst watching-might b going the same way.. the tv repair bods might b your only solution if u dont know any electrician that could give it a test
Dec 29, 2009 | Televison & Video
Flickering tv
Fuses in the power supply are either good or bad and no in between. They will open under a shorted component in the TV no matter if it is in the supply or other sections of the TV, They just protect a circuit from further damage should a short happen. To me, your flickering of the screen could be due to a "cold solder joint" on one of the circuit boards and this is a common problem as the boards are "wave soldered" at the time of manufacture and sometimes the solder joints on a circuit board are so thin or not complete and in time the solder joint on a part that gets rather warm will come undone with heat or cold. Point is; this will require getting inside the TV and looking at the solder side of each board with a good magnifying glass to spot this. First thing in any electronic repair is a "visual inspection" and no way around it. Another thing that can go bad, is some of the circuit boards are connected together by small plug in cables with small connectors on the end. You then could simply unplug each cable one at a time and then reseat the connection and if your really lucky this will find and cure the intermit problems with the flicker. Do not get inside the TV with the power cord still plugged in should you decide to try this out. There are many other things such as a part on a circuit board that is going bad and this is where you will need an experienced TV repairman that knows how to fix your brand and model of TV. Sorry, but fixing TV's and not being able to be there to observe the problem is hard to help from this end. Good luck, Dennis
Apr 14, 2017 | Televison & Video
HUMAX TELEVISION LU23/TD2
Same problem Humax LU20/TD2 TV; Virgin remote
Apr 13, 2008 | Televison & Video
Humax LD2060 20 in. EDTV-Ready LCD Television Logo
684 people viewed this question
Top Humax Televison & Video Experts
Andy Fraser
Andy Fraser
Tony
Are you a Humax Televison and Video Expert? Answer questions, earn points and help others
