Question about Kicker 06ZX750.1 Car Audio Amplifier
Went through the checklist you gave me.
I took your checklist and went over all of it. this is what i found.
the amp is in the same spot as its replacement. it is not hot at all, not even warm at any time.the gain was up pretty high, so i turned it down to a little over half.the wires are both 4 guage.as far as i know, the speaker wires are all brand new and i didn't see anything wrong with them.now this is where i get lost lol.the sub is a 4 ohm dvc sub. they are wired in parallel, i took the sub out of the box and looked at the wiring. i did want to know however, if the positive wire going to the terminal on the box has to be from a different coil than where the negative wire goes to to the terminal (positive from coil one and negative from coil 2?) right now they're coming from the same coil.i don't think the battery or alternator are bad because i only upgraded my sub and amp, meaning there was already a combo in my jeep, i just bought a better setup.and i don't have a capacitor. i checked all of this before work this morning and it didn't cut out for the entire drive.when i left work however, it did the protection thing.the only thing i didn't check was the wiring behind the deck.i would need to know what i'm looking for there. thanks for your help so far anyway. worth the ten dollars.
  • tyler
    tyler May 07, 2008
    i've never changed the battery in my jeep, so it's either the stock chrysler one or just a standard replacement battery.the morning i drove to work, which was about 745 a.m., it pounded and sounded great for the whole ten minute drive.it hasn't stayed on longer than 5 minutes other than that one morning.the 750.1 is powering a single kicker comp vx 12 in sub.and yes the birth sheet tested the amp at 880 rms at 2 ohm.the low amp thing sounds like it could be why, because i also have a kicker zx200.2 amp powering the 6.5 polk components in the soundbar. is there a battery that may work that's a tad bit cheaper than optima? or just any battery at least 800 cranking amps?you're helping me very much by the way. thanks.
  • tyler
    tyler May 07, 2008
    well i'll make a trip to walmart after work today and pick up those things you suggested.it sounds like this could be the problem, considering it cuts out for a few seconds BEFORE it goes into protection, not just shutting off all at once.never hurts to have a new battery anyway..i mean i sent the amp back to kicker a couple weeks ago because it was doing something similar to this, and they said nothing was even wrong with it, so i guess they're not going to lie to me.i'm fresh out of ideas lol..
  • 156 Answers
Ok... but just remember this AMP is rated 750w x 1 @ 2ohms or 375w x1 @ 4ohms RMS So its a mono driver AMP works great with a single sub.
But I see kicker 750's that put out 850 sometimes 900w RMS
I do recommend using at least a 2 farad CAP and a really good battery like at least 800 cranking amps... I usually use like Yellow or Redtop(Optima) batteries 850-1400 cranking amps for kickers+ a single 2farad cap. What happens is a low amp battery will not provide enough "BAM" to keep the AMP working properly at its required voltage/load.. This is why your AMP is not even getting hot/warm its turning off to prevent "Low-Load damage"
What is the cranking AMPs and what type of battery do you have because kickers without CAPs and great batteries can destroy an Alternator reguardless of your current problem.
You should easily be able to pound your chest open and **** the oxygen out of the cab of the truck with a single sub... and the fact it went into protection mode later in the day... not right when you hopped in the truck in the morning tells me the battery might be the culprit... Not saying buy one but.. they are cheaper than a new alternator lol... and if you do blow your alternator make sure you get a higher rated alternator than recommended for your jeep. I think your wiring up to the AMP is fine... Was that sub hitting in the morning?? did it take your breathe away? What type of speakers and what size?
Posted on May 07, 2008
  • Ronald Tisdale
    Ronald Tisdale May 07, 2008
    Yeah you don't have to have the Oprtima they are pricy.. a good 950 and ^ cranking amp walmart battery will be fine...think the stock jeep battery was like 550-600 cranking amps. So yeah.. and keep your eye out for a 1 or 2 farad CAP nothing fancy but it will keep you from burning up the Alternator.. Taxing the battery and shorting its life... blown fuses at intermidiate times... and surprisingly it keeps the AMP running cooler than mixmatched voltage loads... like when you turn the A/C on or the Headlights this causes drops and spikes in system. Check this out.. been doing this for a few years... get ahold of a PC laptop cooler mat.. they sell em at walmart for like 20 bucks... Cut off the USB at the end... strip the cables back and attach the power cables to the AC power on and ground on AMP... install the cooler mat under the AMP or lay it right on TOP... looks badass too and the Fans kick on when the AMP does too.
    Oh yeah and the Walmart batteries have 3 year walkin warranties... so...in 2 years get a brand new one...and if you say have a 3 year warranty... and its been 4 yrs...6 month.. they will credit like 75% of the price of the old battery to the purchase of a new one.
  • Ronald Tisdale
    Oh yeah the Fixya rating from the premium solution from before is done. So if you click Fiya for this question it's not going to charge you anything..this is the free forums section.. just FYI if you were worried it might. Oh yeah use the contact gel on your battery hookups too you'll only need like the $1 packet from AutoZone but dont use it on the AMP just the battery.
2 Suggested Answers
  • 1596 Answers
SOURCE: 2 4ohm dvc subs to a bxi 608 ( 600watt mono)
take the positive on the sub and run a wire to the other positive the run a negative to the other negative then to your pos and neg on the box do the same on the other side then tie your two positives and two neg together and you got 1ohm and that amp willl handle it all day
Posted on Jan 29, 2009
Will taking ibunate for pains cause bleeding after colposcopy
Yes ibuprofen causes thinning of the blood and that can cause bleeding. A family member just had one and the doctor said NSAID meds of any kind.
Jul 20, 2017 | The Health & Beauty
Car cranks but will not start
first thing take the 120 amp fuse out and throw it away
the 100 amp fuse was installed originally to protect the wiring and other related parts
next by connecting to the wrong terminals there is a power surge that can damage the electronics in the ECM unit and alternator
removing a battery for a charge can corrupt the immobiliser system
I would suggest that you use a scanner to read any fault codes that may be stopping the engine and then reset the CPU program in the ECM to reset the immobiliser
Aug 07, 2015 | 1997 Honda CR-V
I have a 2007 Honda Civic 2 door bought the car found the legacy LA 960 in the trunk worked great for 1 year took on a 500 mile ride and woofer gave out. Took to a repair shop they said fuse of 20 amps...
1. Stop going to this shop.
A fuse that keeps blowing is a sign of a problem. You never replace a fuse with one of a higher amperage because the idea is the fuse is suppose to blow before the the wires melt and catch on fire. The reason it stopped working and the fuse didn't blow is probably be cause the wire did melt someplace and you are lucky the car didn't burn. If it did burn and the insurance company found the 40 amp fuse, they would probably have refused to pay.
The idea that a repair shop would do this tells me that they don't know what they are doing. Read this
FUSES
Oct 18, 2013 | Legacy Audio LA960 Car Audio Amplifier
How do you fix a frozen flip video ultra?
I fixed mine! When I turned it on it only had the flip logo on the screen & it would only shut off if I took the batteries out. I tried everything - holding the on switch for 30 sec, holding the record button & the on switch for 30 sec, deleting every bit of data from the camera, reinstalling the software onto the camera, leaving the batteries out for a month... I took it apart & found a burnt spot on the motherboard. I scraped it with a pocket knife, put it back together & now it works like new!
Jun 23, 2009 | Pure Digital Flip Video Ultra Camcorder
Infinity 336rms amp worked for over a year then one day stopped?
check your fuses. Also check the power wire connection to the amp and then the ground source maybe move that if there is paint under it. check fuses on the amp. Check ohm load to the amp from the speakers.
May 27, 2009 | Infinity Reference 611a Car Audio...
Powers on but will not run, goes BONK when button is pressed.
OK, I have fixed my Roomba!! First I went out and searched the web for Troubleshooting info. What I found was the diagnostics that the factory uses to test them. So going through the diags. I found that 3 of the 4 IR Sensors along the front were not working. So I took the Top Cover off, then removed the Sensors from the front Bumper. I found a red wire that had been cut from the drop. Repaired the wire and all is good !!!!
Jan 02, 2009 | Roomba Robotic Floor Bagless Vacuum
Possible bad alternator?
Bad alternators straight out of the box are not uncommon. Replace it again and hope you get a good one. Make them test it on the bench before taking it out of the store.
Sep 03, 2008 | 2002 Saturn VUE
My DCT646-2 no one can hear me.
take it apart and clean the mic with alcohol. (I took out a black round cover it had on top to reduce eco)
Worked for me.
cheers,
Oct 04, 2007 | Uniden DCT646-3 Cordless Phone
Kicker 06ZX750.1 Car Audio Amplifier Logo
132 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
