When I power up all I get is a clicking sound and it won't open up on my computer.
  • 395 Answers
A clicking noise is a bad harddrive, you will have to replace the harddrive and reinstall the os from a cd
Posted on Aug 27, 2010
Sunroof won't close
see the diagram attached and fix it. God bless youaa64eb51-7e11-4e93-a5bc-68a552df4913.jpg3d325aa6-02b4-4a16-b487-b8a581cd3d55.jpg
Jul 15, 2013 | 2002 Toyota Camry
Hp dx2200 computer won't power off
If your HP computer refuses to power down, this means that there are still programs open that Windows can't close. Normally when you select the "Shut Down" button from your "Start" menu, Windows closes all open programs, then closes itself, and your basic input/output system (BIOS) turns off all of your hardware. If Windows can't close all open programs, your computer won't be able to power off. This means that you must close these programs yourself.
Right-click on the window of an open program on your Windows taskbar (Bottom of Screen) Click "Close Window." Windows manually closes the program. If a window appears on-screen indicating that Windows cannot get the program to close, click the "Force Close" button in this window to have Windows force the program to shut down. Repeat "Step 1" for any additional programs that are open on your computer. Click "Start." Click "Shut Down." Hope this helps.
Dec 10, 2012 | Computers & Internet
Maytag dryer 2003 was working great I took one dried load out put another in and started the dryer. Working just fine then I found a wet garment that I dropped so I opened dryer door added this item...
When your dryer won't start, it could be a number of problems from a broken door latch or start switch to an exhaust duct blocked by lint. It could even be a tripped circuit breaker or blown fuse.
The first step in troubleshooting any electrical appliance is to ensure that it is plugged in and receiving power. While dryer plugs do not come loose easily, it can happen.
For more troubleshooting tips, read Dryer won't start for possible causes, signs to look for and things you can do. I hope this helps!
Aug 03, 2012 | Dryers
My Liftmaster garage door won't open or close. I hit the button and it make a sound and clicks but won't close
Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad. Tell me - if it won't open how do you know it won't close?
Feb 22, 2012 | Sears Craftsman LiftMaster Chamberlain...
I have Creative I-Trigue L3800 Speaker System, but I only get a redlight, won't power up. The Power supply works. What else can I try?
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
if you dont have a disk with the drivers you will have to download them
hope it helps
Oct 05, 2011 | Creative Labs I-Trigue L3800 Computer...
1996 GMC JIMMY WILL NOT START: Turn the ignition and there is a repeated clicking sound. The interior lights, radio and power windows still function. Replaced the "in line" fuel filter under the...
It sounds like you probably have a shorted battery cell. This will not only cause the repeated clicking that you described, but it will also rob power when jump-starting from another vehicle. There is probably enough power when jump starting to turn the starter over, but after the starter take the power that it needs, there is not enough power to operate the computer system....so I have no doubt that you probably are not getting any fuel. The computer has to tell the fuel pump to run. If there is no power for the computer....I think you can figure it out from here.
Replace the battery and try it again.
Please also review this article: My Car Won't Turn Over
Aug 12, 2011 | GMC Jimmy Cars & Trucks
My speakers won't turn on at the outlet that my power strip is plugged into, nor when plugged into any of the outlets on the strip, however the computer and monitor are running off the power strip and...
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar:
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Jul 01, 2011 | Logitech X-530 Computer Speakers
Acer Aspire 5538 Won't power up at all. I have charger in and plugged up, when I try to puch power button it clicks off. What can I do?
It sounds like your computer's charging port is disconnected from the motherboard. The charging port cable probably has to be re-soldered to the motherboard to be fixed. If you are not skilled in computer hardware repair-ale I would suggest going to a computer technician.
May 13, 2011 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
