Question about Siemens WFXD5200UC Front Load Washer
The front load washer kit top bolt punctured through the drum. Now we have a leak. These crack head appliance greedy idiots want to pick it up and take to there shop or garage and see if they can apoxy it or order a new drum. That would cost $500 just for the part and labor. Cant they fix it on-site or are they just thinking about taking us to the bank? Could I fix this myself and forget those greedy bastards. Seimens washer model wfxd5200uc
    Top Expert:
  • Siemens Master
  • 76,132 Answers
Go ahead and get the part the techs suggested.
Posted on Aug 27, 2010
Cold water leaks into tub when machine is off
Try to identify roughly the area the leak is coming from. This will eleminate some of the following
Hose Connections
Check the rubber washers or replace if the hoses are leaking at the WATER INLET valve
Door Seal
This is a common place for leaks. Carefully check by partially pulling seal inside out and check for punctures, pens, pencils... Additionaly if the door is not closing properly it may need a door adjustment. This can easily be done by loosening the hinge bolts on the front panel, adjusting and retighten. The seal is also known to get lightly snagged by zippers or rub by heavy items when close are being removed. This tends to cause the seal to get damaged at the six o'clock position. This is sometimes hardly noticeable but if it is leaking from the bottom of the door replace door seal.
Water Inlet Valve
If the hose connections are good to the water inlet valve check that water is not leaking from the valve itself it is replace inlet water valve
Drain Pump
Check the drain pump housing and all hose connections. The drain pump is behind the lower panel, behind the back panel, and sometimes removal of the front panel. Hoses can be tightened. If hoses or pump housing is leaking replace pump .
Outer Drum
The outer drum is 2 halves bolted together some washers have a seal between others do not. If the washer is leaking between the seems disassembly of the washer will be necessary. The top panel, console, front panel, door seal, struts. 9696d86e-1b8b-4b2e-af2c-6f3a3ae921dc.jpg
May 23, 2013 | Siemens WK61420GB Front Load Washer /...
Leaking from under front of machine
Hello there
Please read the entire solution to best match your problem I have provided below
During fill only If the washer leaks only during the fill cycle, check these: Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it. The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak. Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak. During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
I will post the rest of the solution in the next comment
Dec 26, 2010 | Kenmore 24032\24036 Top Load Washer
Noisey during spin
yes you are right noise during spin cycle is due to faulty bearing. If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly  and the outer shell with the tub bearing.
Sometimes the inner basket support will crack, this can give an clicking or banging noise as well.
Pictures of this job...
A sure indication was the brown junk/gookus leaking out if the rear bearing area and the belt has spewed it around in the drum that the rear bearing and seal was bad...
Picture1 - Picture2
The whole outer shell and basket come out to do this repair....what bad bearing and rusted shaft looked like...
Picture1 - Picture2 - Picture3
I had to remove the back panel. Undo the pump hose & water level hose, remove the 2 shocks, remove the motor, undo the front boot from the outer panel and remove the 2 springs to lift the whole assembly out from the back to work on it.
Picture1 ( boot pushed inside ) Help page1 - Help page2
It leaks Your washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
  • Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
  • The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
  • Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
All the time If the washer leaks all the time, check these:
  • Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
  • Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
  • Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
  • Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
May 07, 2009 | LG WD-16115FD Front Load Washer
I have Frigidaire front loading. During the spin
During fill only
All the time
Apr 03, 2009 | Frigidaire Washing Machines
Amana washer model LW6501W2 leaks in front during fill up
During fill only
All the time
Apr 01, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Water leaking from bottom of front lode washing machine
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
All the time
During fill only
All the time
Dec 01, 2008 | Frigidaire FTF530FS Front Load Washer
Maytag Atlantis Top Load MAV6250AWW Drum Leak?
During fill only
All the time
During fill only
All the time
Oct 22, 2008 | Maytag Atlantis MAV7260B Top Load Washer
Maytag Washer leaking from front
If I remember correctly, you need to remove the drum to get at the bolt that you are talking about. There is a rubber washer that provides the seal. The locking collar on the hub is Left hand thread. If you work at it you can get it loose.
Jul 12, 2008 | Maytag MAV2755A Top Load Washer
Kitchenaid Top Loader leaks
During fill only
All the time
During fill only
All the time
Apr 16, 2008 | KitchenAid KAWS700L Top Load Washer
Siemens WFXD5200UC Front Load Washer Logo
208 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
