Question about GE Profile PSW26P Stainless Steel Side by Side Refrigerator
I have a GE side by side refrigerator about 7 years old it has a thru the door ice/water dispenser the water seems to be dropping in the ice tray inside the freezer and freezing in a mass at the bottom of the ice maker. what do you think is wrong?
    Champion:
  • 245 Answers
Your inlet valve is malfunctioning. Sometimes when they go bad they either let in to much water or none at all. It is located on the back under accesss panel where your water line connects to your fridge. Rate me if I helped you!
Posted on Aug 27, 2010
GE Side By Side Ice Machine & Water dispenser not getting water
you may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
Jun 05, 2010 | GE Profile PSW26P Stainless Steel Side by...
LOUD BUZZING SOUND WHEN DISPENSING WATER THRU THE DOOR
The water control valve on rear of refrigerator is weakening. That is typical sound for a coil that opens the side that dispenses water or ice tray refills to vibrate or buzz when weakening. If I had you r model number I could give you the part number. They are not expensive and easy to replace. Thanks, Sea Breeze
May 06, 2010 | Maytag Refrigerators
Water freezes in door dispenser
there is a length of line that runs thru the refrigerator, If it drops below frezing where this is located the line will freeze causing a blockage.
Mar 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
In door ice dispenser does not work but the water dispenser does.
check to make sure there is water or ice in your ice maker tray. If none then problem is usually a water supply issue to the ice maker. Behind the frig are the water supply inlet valves. One is for the water dispenser in the door. THe other is for the ice maker. However when one goes bad they both are replaced as one unit. Also Check position of fingers in ice maker. If not in a vertical position then try to reset the ice maker unit and worse comes to worse, replace it with a new one.
Nov 19, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile PSW26P Stainless Steel Side by Side Refrigerator Logo
65 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
