Question about Ovens
Kenmore 911.47649100 I purchased this oven in 2001. Double wall oven - self clean top and bottom. Ever since the purchase I have had nothing but trouble. First the self-clean latch problem, which sears fixed. Then I had nothing but trouble with the control panel. You could only press the Clear/Off button with any results, which doesn't help much when you need to cook! I have put 7 new control panels in over the years - two Sears provided and the others I purchased. I now have $2000+ in this oven and am now getting the famous F7 error I've been seeing on the internet for years. I don't understand why this oven wasn't recalled, it is a dud! A $1400 dud. Do you know of any permanent fix to this problem? You can e-mail me at Thanks, Wendy Hall - Texas
SOURCE: oven
I used the self cleaning mode for 2 hours and the error f2 keeps flashing and beeping, I did try to power off with the breaker and left it off for about a half hour and it still continues to beep and flash f2, what should I do?
Posted on Nov 18, 2008
SOURCE: Dead Whirlpool Double Oven
This happened to us the first time we used the self-cleaning feature. The repairman said we had to replace the whole electronic panel -- but when he put in the new panel it didn't work either. It turned out he just needed to replace the oven shutdown thermal fuse I believe. We finally got up enough courage to try the self-cleaning again and the exact thing happened. The door is locked and the electronic panel is dead again. So when we get it fixed we will never use the self-clean again.
Posted on Dec 05, 2008
  • 1689 Answers
SOURCE: Flashing locking door light
hi wega,
the door's locking mechanism is controlled by a switch when you shut the door down. much like the light switch on your refrigerator. when you initial closing the switch for locking the door will be triggered does locking the door.
there is a possibility that this switch on your oven is press / stuck that is why it keeps on saying "locking door" which will eventually never be completed.
Find the switch on your door panel, this is usually near the hinge of the door. it can also be safely located with in the hinge assembly, if this is true, there will be no buttons or holes visible.
if you can open the door panel up or remove the casing you will be able to locate the switch on the door hinge and its assembly.
hope this helps.
Posted on May 16, 2009
  • 89 Answers
SOURCE: Kenmore oven error code f10
on that type of range F10 indicates a problem within the electronic control, but it could possible be caused by a faulty temperature sensor.
I would recommend service from a technician
Posted on May 27, 2009
SOURCE: F7 error message on GE oven
one other comment about the F7 message having delt with this stupid oven for years and after replacing touchpads and controls the touch pad is the cause of the F7 in one of 2 ways either the ribbon cable is shorted (the repair for this has been posted by several people and is good) or a stuck button .One cause of the stuck button at least in my house has been steam coming from the oven flowing over the touch pad this can get moisture in the touchpad shorting it out causing a button to stick giving an error message also making the oven unusable....what I did solved the problem I figured I was going to have to spring for a new touch pad so I peeled it off the front of the oven got under the edge with a knife and lifted it off (it is stuck on fairlly well but will lift off) once this is done i squeezed every button between my fingers and flexed the touchpad back and forth (flexed not bent) ..I noticed the edges are not sealed well allowing moisture between the mylar surfaces poor design! i replaced pad and sprayed edges with silicone spray soaked the front also around the window area figuring the silicone would get between the surfaces and help prevent this problem Ta Da oven all better too bad I didn't figure this out sooner but I hope this helps someone....GB
Posted on May 08, 2010
Why don't top oven broiler and bake elements heat?
we had that problem once. it turned out to be the control switch was broken
Apr 10, 2016 | Kenmore 27 in. Electric Self-Clean Double...
I have a Fisher & Paykel double wall oven that I purchased in 2005. The top oven which was used most often stopped heating up to temperature in normal time. What used to take 5 minutes to get up to 250...
Google searches report that after running the self cleaning cycle this can happen. I am experiencing this issue with my Fisher&Paykel AeroTech Double OD302 but with the BOTTOM oven. I'm concerned as Thanksgiving is coming up and I need this baby working!
Nov 08, 2010 | Fisher and Paykel AeroTech Double OD302...
Cannot use self cleaning feature on Meile double wall oven. Get the same error message on the top and bottom oven. A giant F and fault 09.
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Oct 28, 2010 | Miele H398BP2 / H398B2 Electric Double...
I own a whirlpool double wall oven. The top is self cleaning but the bottom is not. I purchased this oven in early 2005. Today when I tried to use the self cleaning feature the entire oven went off but the...
Sounds Like the clock control unit may be bad, or the auto latch assy itself. I may have the part for you. What is the model number of the unit?
Sep 15, 2010 | Whirlpool Ovens
Main top crack do I need to replace the entire top?
Hi jerseyfol58,
Hate to say it, but yes. The entire "ceran top" comes as a whole, with the exception of the burner`s.
You might consider purchasing the top but having a pro install it, it is quite involved.
Hope that answer`s your inquiry.
Good luck.
macmarkus :)
Dec 07, 2009 | Frigidaire 30 in. Electric Gallery Series...
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Asker's Testimonial " Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! " - amymrocks
Dec 24, 2008 | Frigidaire 27 in. Electric Double...
Maytag "Magic Chef" electric double wall oven
check the high limit swtich. You need to remove the back of unit to find it. replaced it part# is:w10175596
Jan 02, 2008 | Maytag CWE5800A Electric Double Oven
Kenmore 47779 double oven; lower oven doesn't work after self clean
Sounds like a thermal overload has opened up during clean. It may be mounted on the back.
Nov 02, 2007 | Kenmore 47772/47774/47779 Electric Double...
Electric double stove
Some double oven models have only one that is self cleaning. If you do not have a cleaning button for the bottom oven, it is not self cleaning. The solution is to use the top oven for those messy baking or roasting chores and use the bottom oven for the clean baking chores.
Mar 26, 2007 | Kenmore 41389 Electric Double Oven
Ovens Logo
97 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
