Question about Logitech Cordless Mouse
I have i plugged into my usb correctly but its still not working
    Sergeant:
  • 223 Answers
Check the following. -connect to the rear USB ports -be sure they are new batteries. (obvious but sometimes forgotten) and more importantly their orientation. -press connect on the base. then press connect on the bottom of mouse. - try not to use shiny desk surfaces. Believe it or not sometimes this is a cause, try it on a piece of paper if there is any doubt. -check the computer Bios to make sure USB is in fact enabled. -after you connect the device, wait up to a minute for the computer to detect and install it before its usable. eg.. input device detected...... installing device...... i welcome your feedback or comments. cheers
Posted on Aug 27, 2010
How to get my keyboard back working on my desk top
1: if the keyboard has a round plug going into the computer, it is a PS/2 plug. Turn off your computer, unplug the keyboard, then plug it back in, making sure it is plugged into the correct place for the keyboard (and not the mouse). Then turn the computer back on.
2: If the keyboard has a USB plug, it is not necessary to turn off the computer first, just unplug the USB cable for a few seconds then plug the cable back into the computer. If it still doesn't work, try plugging the USB plug into another USB port on the same computer.
3: If neither option works, you may have a defective keyboard.
Sep 05, 2017 | Top Computers & Internet
Why when i plug in my garmin device does it show a computer but no maps
Are you using a simple USB lead plugged into a USB power source? If so, the unit is (correctly) going into its USB mode.
You can also try different USB leads, some do not have the data line so act as just a power lead. It's the data line that signals the GPS unit to go into USB mode.
Regardless of the type of lead, your unit will charge like this and then, when the lead is disconnect and the unit turned on, will work normally off the internal battery.
If this is your experience, you will need either the correct GPS power source or a "USB power" lead.
Nov 05, 2016 | Garmin GPS
USB keyboard not working
The biggest problem with tablets and phones is the micro USB socket. They are easy to break if you put them in the wrong way round and it is not always easy to see if they are connected correctly.
Check the USB plug and the the tablets socket are not damaged.
Check that USB keyboard works in another device and that another USB input device works in the tablets USB socket.
I am suprised it works at all. You state you are using Android 2.2 yet USB hostmode was only introduced with Android 3.1
There are some apps in the play store like USB device info which may help. For proper debugging you need an APK which is not for the average user. http://visualgdb.com/tutorials/android/usbdebug/
But cables and plugs are 98% of the problem
Good Luck
Jul 09, 2014 | Irulu 10.1"tft Wifi 3g Android 2.2 Tablet...
My usb won't work or reconize anything I plug in
Try out MS Fixit. Use IE (Chrome did not filter correctly). Select Windows. Use USB as the filter. There should be 2 executables, and maybe some other solution. This a fairly new and dynamic site, so a little feed back would be great. http://support.microsoft.com/fixit/
Oct 21, 2012 | Computers & Internet
I lost my plug in setup sheet that came with my computer that shows the correct locations that shows where to plug mouse keyboard and printer on my Dell Dimension e510 desktop
The Dimension e510 does not have ps2 assigned ports only usb, plug your usb mouse keyboard ect to any usb port you like, I promise it will work fine :)
Jun 01, 2011 | Computers & Internet
"cannot find specified file. Make
Try rebooting your desktop/laptop and plugging your drive into a different port..preferably one at the back of the machine.
Also do not use your usb stick through a usb hub.
Apr 18, 2011 | Electronics - Others
Find the correct connections on motherboard for usb ports
frist you have some port of usb on front pannel of cpu . connect the wire of usb . u can plug the usb card from on board pci slot then you need to enable your usb in bios
Apr 10, 2010 | EliteGroup K7S5A Pro Motherboard
I have 4 usb poorts on my barebone. two of them
If these are case front/top or other panel ports, verify that the ports are connected correctly.
if ports are configured correctly, remove all usb drivers via device manager. then reinstall them. if the problem still occurs you either have corrupt usb drivers (probably not since 2 ports work) or the USB ports were damaged in installation or because of usage.
sometimes the ports will not clear their settings, try the object you are plugging into the 2 non-workign ones to another port hen try something you never plugged into the 2 non-working. if you still get an error, its a driver or damage issues
Feb 11, 2010 | ASUS P1-P5945G Motherboard
Need to plug in a data cable. need usb software installation?
Plug in the USB device, anyways.
If it works, the driver has already been installed.
If not, take the USB device back to the retail store where you bought it, and get them to demonstrate how to correctly configure and install the device, using one of their computers.
Nov 09, 2009 | Computers & Internet
Logitech Cordless Mouse Logo
19 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
