Question about Pass & Seymour #660IGU 15A Ivory SP Toggle Switch
I have two pass & seymour 15A 660-wg switches side by side, one runs a fan, the other a light. I am switching the light switch to a sensor switch, but noticed a bridge wire connecting the two switches together. I have removed that wire, and connected the sensor switch. The sensor switch/light works, but the fan does not. Do i need to connect that bridge wire to somewhere to get it to work again?
  • 565 Answers
Yes. The incoming hot wire should connect to the sensor switch with a wirenut. Put another wire under that wirenut and jump it over to the fan switch.
Posted on Aug 30, 2010
How to wire
Power will go to one side of the switch and your two switch legs will be connected to the opposite side of the switch.
Dec 01, 2013 | Pass & Seymour #690WGCC6 15A White 2SP UL...
How to wire a pass & seymore 692 switch
Wiring diagram located at
https://www.legrand.us/passandseymour/light-switches/combination/led-lights/692ig.aspx
Jan 29, 2013 | Pass & Seymour #692LAGCC6 15A Almond SP...
I have installed the Pass and Seymour combination GFCI and the test button disconnects the recepticles and the light remains on.
I believe the GFCI is only meant to protect the receptacle. Plig something into it and try the test button and it should work as expected.
Jul 07, 2011 | Pass & Seymour 1595SWTTRWCC4 COMBINATION...
I to want replace a regular duplex outlet with a TM818-WCC6 and want just the outlet switched. How do I wire it?
The Pass and Seymour plug-switch combo has 3 screws
There is a dark screw on one side .... the black Hot wire from breaker box connects here
There are silver and brass colored screws on other side of device
The white Neutral from breaker box connects to silver screw connects here >>> this will give power to your receptacle
The black wire going to Load (light, fan, motor that you want switch to control) connects to brass colored screw ... the switch controls power to Load
How to test for black Hot
Remove devices and separate wires
Turn on power
Test each wire to bare copper wire
Tester lights up on black Hot wire
How to test for white Neutral
Test black Hot to each white wire
Tester lights up on Neutral
Oct 16, 2010 | Pass & Seymour #TM818WCC6 15A White...
Our switch for the ceiling fan burned out today. Instead of getting the same type of switch (rotary knob with push on/off) I bought a Pass & Seymour combination toggle switch (dual on/off toggle...
The wire to the ceiling fan are meant to send voltage to the fixture only and are not usually wired to control both the light and the fan independently. In order to do that, you may have to pull another set of wires to the switch box and then connect them to the light circuit in the box where the fan is. In regards to the other wiring that you mentioned, it makes no sense that the wires go to the stove fan and the bathroom fan unless those wires are source wires that carry the incoming voltage.
Mar 17, 2017 | Pass & Seymour #690IGCC6 15A Ivory DPLX...
Wire from breaker to a dual switches on same switch one for ceiling fan one for outside light
Wire from the breaker goes to the LINE side with the break-off tie connecting the two screw terminals on that side (common feed). The light "HOT" and fan "HOT" wires will be connected to the LOAD side of the switch. If the neutral (white) wires are present in this box, they should be joined together (wirenut). I prefer connecting the light to the upper switch terminal and the fan to the lower switch terminal since the light is an outside light and I presume that the switch is located next to a door or entry.
Jun 04, 2010 | Pass & Seymour #690WGCC6 15A White 2SP UL...
Switch will not stay in on position. i have to tape it at the top
The switch should be replaced, the spring detent no longer works.
Jun 02, 2010 | Pass & Seymour Pass Seymour TM870WCCC5WP...
Pass & Seymour #660IGU 15A Ivory SP Toggle Switch Logo
281 people viewed this question
Top Pass & Seymour Electrical Supplies Experts
ken skalski
Ottoniel
Mike
Are you a Pass & Seymour Electrical Supply Expert? Answer questions, earn points and help others
