Question about Dryers
There is a loud squealing noise when in use. Sometimes intermittent but worse on lighter loads. I was told it was the wheels that make the drum turn. I have no idea how to get at those wheels. All lint/dust/pet hair is removed, all clean inside. It appears the whole case is one solid piece
  • Dryers Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Note: Some tops hinge and tilt backwards so they do not have to be removed.
Also remove the screws holding the lint filter in place.
Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Posted on Aug 28, 2010
FISHERPAYKEL DRYER SQUEALS
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
Mar 13, 2015 | Dryers
Frigidaire affinity front load dryer
You need an upper felt and a rear drum bearing. If you buy the felt make sure you get the special adhesive to install it. The squeal maybe part of this or it could be the rear drum bearing. You can learn how to replace the rear drum bearing here in the article I wrote. http://gomestic.com/do-it-yourself/how-to-replace-a-frigidaire-dryer-rear-drum-bearing/
Jan 29, 2014 | Dryers
Loud squeaking dryer
I have one of these units. They are great appliances. What you have is a very common problem with these units, the drum support bearing is going bad. I think they make a repair kit, but it's a chore to get to. If you are mechanically inclined, you'll do fine. Just make sure you remember the order you took stuff off, and reverse it to get it all back together.
Nov 29, 2011 | Frigidaire FEX831CS Top Load Stacked...
I have a '93 Honda Accord with 230,000 miles. Recently it's been intermittently making a loud squealing noise when turning left or right at low speeds (like the squeaky sound you might hear when rubbing...
In some honda s the PISTON and the VALVE share the same space ,check if your honda does or not ,because you wil have to re build that motor if that happens,timing belts are at every 90,000 miles
May 02, 2010 | 1993 Honda Accord
My Maytaag dryer has a loud intermittent squeal. It will often work for 10-15 minutes with a quiet squieak or no noise, then the loud squeak starts up. I can turn the dryer off, but the squeal immidately...
I think the drum drive belt is slipping because it occurs more with a large load. Other possibilities are: A drum support wheel bearing could need lubrication or be replaced. Also some drum support wheels have a rubber coating that wears off causing misalignment and noise. Possibly drum gasket (sometimes felt material) where drum meets rear panel is worn allowing metal-to-metal contact--should be replaced. See the following for info about dryer repair including belt replacement:http://home.howstuffworks.com/how-to-repair-a-dryer.htm
Sep 21, 2009 | Dryers
Squealing front load washer
the problem is that the bearings are worn,i have done this on a number of washers myself and its a pain to do as sometimes you have to replace the spider on them which is what holds the belt around the drum,if i were you ,i would get a new washer as you could still have problems with it as a result in the damage its done to the outer drum,hope this is any help to you.rgrds paul.
Jun 07, 2009 | Maytag PAV2300 Top Load Washer
Squeal which sounds like it's underneath the car.
Do you know if he turned the rotors when brakes were done?
Dec 01, 2008 | 2000 Toyota Avalon
Dryer Noise
You need to have you belt replaced. Over time the belt will strech.
this causes the dryer to still spin but the belt will sometimes loose the grasp of the drum and cause the belt to spin only.
This happens because over time with heavy loads of towles and jeans pull down on the drum as it is being loaded. Than when in cycle the jeans will drop from the top to the bottom pulling aginst it even more..
Aug 14, 2008 | Dryers
Washing machine
Peace Friend,
ngfam1 At your service!
1-it may be the belt squealing or high pitched nosies telling you it wants to go!
2- It more than likely is the rolling suspension that the drum spins on!I've seen the older models with one of 3 wheels that the drum rolls on is worn and wobbling or screaming or screeching etc.
3- I've seen also a few times that the motors heat shield, a simple piece if tin with two screws or bolts holding it down was "loose" and vibrating causing a loud metal squeal noise all the time or intermittently!!
If I were there hands on I could fix it!
Only a trained laundry tech can make the electronic diagnoses.
Unfortunely, another point to consider!!
How old is the appliance?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
You will be fine
Bless You ngafm1
*****PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF*****
Aug 05, 2008 | Kenmore 24032\24036 Top Load Washer
Squealing!!
the noise is coming from the drum axle bushing that allows the drum to spin on it's axle. Gain access to the rear of machine and apply some high temperature grease that is found in automotive parts stores to the bushing. run it while observing spinning drum at rear for any possible other problem where squeal can be found such as drum slides.
Dec 26, 2007 | Frigidaire GLEQ2152ES Electric Dryer
Dryers Logo
Top Dryers Experts
