I am having trouble with the ez grabber software. It keep freezing in the middle of recording. Do you know a way to fix this?
    Sergeant:
  • 201 Answers
Hi reinstall the program.check your download isnt being blocked by your fire-wall.
Posted on Aug 27, 2010
I can not find the video I recorded.
Just make another picture with EZ Grabber and notice the location of where that "grab" is going to be saved. After you save that image(which you should name your name, so you can find it easier) to the location, you can use the Windows Manager to locate some of the last screen shots you saved. You can moved them to the Desktop and decide where your wan them stored.
Mar 24, 2015 | Computers & Internet
How do you edit with the ez grabber vc500
Hi
I give below a link to the EZ Grabber installation manual.
http://www.derbymagic.com/files/EZGrabber_manual.pdf
I have been through this but can find nothing to indicate an "edit" facility.
I then tried this link
http://www.dmmdownload.com/downloads/CURRENT/PVR/Diamond%20VC500CXT%20Walkthrough%20Response.txt
which clearly indicates an edit facility via some Arcsoft software which presumably is supposed to come with the grabber.
It is possible that one of the "software utilities" on the webpage (link below) may contain the software required.
http://www.diamondmm.com/driver-downloads.html?option=com_content&view=category&id=599&Itemid=1014&select_item=354_598&select_item_354_598=355_599
Good Luck
Aug 25, 2014 | Diamond Multimedia ( VC500) Video Capture
No Auto Stop on EZ Grab when VHS is done playing
hi, as long as you don't have a professional VHS player/recorder with a serial control, and a dedicaded software to control it, it is impossible for your soft to know that VHS as finished, you don't have the problem with a firewire input, as the control passes by the FW cable in the two directions, but you can solve that (easy way) by setting up the capture time to approach the real timing !
for the MP4 format, the easy graber doesn't capture in this format without the use of the CPU, because it doesn't have hardware encoding, so that's why you can't reach good quality by capturing directly on MP4, you would need a card like hauppage game capture to have full MP4 (H264) hardware encoding with really good quality, and without any CPU use !
Mar 13, 2014 | Diamond Multimedia ( VC500) Video Capture
I hear the sound but only see a blue screen on computer vhs hooked up to? it was working other day?
Software maybe became corrupted a disk drive where your storing files may be getting to full. I would check those two things out first. Burn what you have now and dump the files stop doing the crossover for now unplug ,machine and reboot computer to see if this is a computer issue if it continues delete the Easy Grabber software and re-download it again. Make sure drive where storing is fine. When I do this sort of thing I use an external drive that will not affect my main computer instead of a direct to C:\ process this is just a good idea in my humble opinion. Hopefully you will be able to load Windows back up once everything else is checked out. John
Apr 12, 2012 | Computers & Internet
I have an EZ Grabber Item No: A07JR. Trying to get VHS film played on a Sharp VC-MH815 6xHead/Nicam/Hi-Fi Stereo Player Recorder. Useing video composite from the player to USB attached to a Toshiba...
This is a solution, probably resolve your problems as well, for converting VHS to DVD, its a tip I posted some time ago, might help you out:-
There appears to be quite a few problems with people trying to convert their video tapes to DVD using a PC and propriety converters, editing programmes etc.
Friends have also has such issues, lip synch being one of the most prolific.
I've successfully converted mine, without too much issue and managed to avoid these issues.
I hook up my VHS recorder with a DVD recorder2_bing.gif which also has a HDD. Daisy chaining it on to a TV to monitor. All with scart leads.
Play the tape, record to the DVD hard drive. Finally edit and dub to DVD.
Have fun ..............
Nov 25, 2010 | Cameras
I use a standard wheelchair and often drop things. It is difficult for me to get down from my chair or to lean over to get things. I would like to attach a grabber to the side of my chair for easy and...
Try an EZ-Grabber reaching tool; http://arcoa.com/products-ezg.html
I don't know if they will attach to the side, you may want to put a strip of velcro around it to keep it handy. Also check Amazon.com for similar items.
Aug 11, 2010 | Health & Beauty
My Diamond vc500 constantly takes pics HELP!
Check the configuration settings - you may have the automatic frame grab feature activated.
Feb 08, 2010 | Diamond Multimedia ( VC500) Video Capture
I have a EZ Grabber but do not know how to work it.
had same problem. ensure right selections are made in the souce menu. & that your connectors are out connectors and not ins.
Sep 18, 2009 | Ulead Videostudio 8 for PC
Trouble recording video on Model IC50C
I told MI that the EZ Media software sucks the last time I had a reason to do business with their support. I highly recommend that you verify that you are using the latest version of said software from the MI site.
http://www.microinv.com
Mar 26, 2008 | Micro Innovations MCNIC50C Webcam
Computers & Internet Logo
265 people viewed this question
David Payne
David Payne
