Question about Magic Sing Along Consumer Microphone
Batteries are changed, song pack is inserted and all cables and adopters are plug in. But it is asking to insert music ram pack. what shall I do? the product has a series of AT0212020687, PCC ID:PBNSINGALONG.
I have connected the guitar to the amp but can't hear anything. This is brand new.
Put batteries in the guitar? Turn up the volume controls? Inserted cables fully?
Jul 23, 2011 | Peavey Rockmaster Guitar Stage Pack -...
Tip
Adding your own music to Super Smash Bros. Brawl
To play your own music on super smash bros brawl, follow these 10 simple steps, but first, this is what you need: an audio source (ipod mp3 player, etc.), SSBB, a wii, and AV cables (red, white, yellow on one side and silver on the other that can be inserted into your audio source
1 take an audio source (mp3 player, ipod, etc.) and plug in the AV cables.
2 Start super smash bros. brawl.
3 go to options
4 go to sound
5 set music off and sound max
6 set up your game normally
7 move your cursor over the stage you want to play.
8 remove the RED cable of your wii and insert the RED AV cable connected to your audio source
9 Chose your song
10 start your game!
on Apr 05, 2009 | Nintendo Super Smash Bros. Brawl for Wii
How to use the built in 5 in 1 card reader in acer extensa 4230? and how to download music into a sandisk microsd 2gb card using the built in card reader inacer extensa 4230?
I am glad to HELP YOU!
That "5 in 1 card reader" is exactly what it says it is: a UNIVERSAL CARD READER.
All you have to do is to insert the card into the slot and the machine will detect it automatically and will read it.
The microSD cards should be inserted first into a microSD card adapter and after that the both should be inserted into the slot.
As for downloading music right on the microSD card do like this:
# insert the microSD card into its adapter [together should look like a regular SD card]
# insert the adapter into the slot
# the machine will detect the SD card [just wait until it is detected]
# choose your song [mp3, wma etc.]
# right-click on the song and where it asks whre to be downloaded you will choose MY COMPUTER > double-click > the letter corresponding to your SD card.
You're done!
Do the same with all songs.
GOOD LUCK!
... and don't forget to RATE, please...
Apr 19, 2011 | Computers & Internet
How do i download music on my mp3 player?
How to Put Songs on Disney Mix Max
The Disney Mix Max portable media player is capable of playing audio files in the MP3 format. It can also play videos formatted as WMV and display photos formatted as JPEG. You can convert audio files into MP3 using the Disney Mix Max software -- Mix It Plug-in. The plug-in works with Windows Media Player 10. This software CD came with the player and is not available online. To download music to the device, you can use Windows Media Player 10 or Windows.
Things You'll Need:
* USB cable
* Mix It Plug-In installation CD
Instructions
Convert Non-MP3 Files
Install Mix It Plug-In. Insert the Mix It Plug-in installation CD into the computer's optical drive. Click "Install Mix It Plug-In" when prompted. If no screen opens, double-click on the "My Computer" icon. Double-click on the installation CD icon. Then double-click on the setup or installation file; this file is often formatted as EXE. Select to have the program saved to your desktop. Then double-click on the desktop icon -- "disneymixitplugin" to open the setup wizard. Click "Next" in the setup screen. Follow any additional setup prompts.
Open Windows Media Player 10 and create a playlist. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Open Mix It Plug-In. Select "Yes" when asked to save analysis information for your music files. The software will analyze each track's compatibility with the Disney Mix Max player.
Press "Go!" to start the conversion process. Once the process is complete, an inactive "Go!" will be displayed. All music that has been converted is still listed in your Windows Media Player 10 playlist. You are now ready to download music to the player using Windows Media Player.
Open Windows Media Player 10 on your computer.
Remove the USB jack cover located on the bottom of the Disney Mix Max. Insert the compatible end of the USB cable into the USB port on the Disney Mix Max. Insert the other end of the cable into the computer's USB port.
Click "Library" and click a playlist name. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Select the "Sync List" tab and choose "Sync List" from the menu.
Verify the items to be synced to the Mix Max, or right-click on a song title and select "Delete" to remove it. Click "Start Sync" to download music to the Mix Max.
Windows
Insert the USB cable to the Disney Mix Max USB jack. Connect the player to the computer with the USB cable.
Click on the desktop "Start" menu and choose "My Computer."
Double-click on the "Removable Disk" that corresponds with your connected device.
Drag songs saved on your computer with your mouse into the Removable Disk folder.
Tips & Warnings
If you converted files using the Mix It Plug-In, you will need to use Windows Media Player 10 to sync them to the player.
Mar 11, 2011 | Disney Mix Max Digital Media Player
My memeory card dont play songs in music player of my phone it just play songs of phones internal memory
Dear Friend,
You Didn't specified What Model you are using...Any way you have SOLUTiON here.....
  • Go to Music Player
  • Change the Folder to MMC/ any Music Folder in MMC
  • Update Music
  • OR (if still same)Format MMC with in Phone
  • Remove MMC from Phone
  • And insert MMC to Card reader
  • There you will find any Music Folder Created in MMC(digtal,Simple,Sounds,My music etc.)
  • Copy Music in to That Folder
  • OR Switch off Phone
  • Insert MMC to Phone
  • Update Music in Music menu/Refresh play list
  • You are done..
I hopE THIS HELPED YOU....... You may Feel Free Contact me,,, Thanks For Using FixYa
Apr 06, 2010 | Cell Phones
Problems uploading songs to cell phone from computer
hi
have you inserted the Memory Card in the phone?
using data cable you can only put the songs in memory card (in motorola phone)
if you want to put songs in Phone memory then use Bluetooth
please rate me
Dec 27, 2009 | Samsung SGH-d807 Cellular Phone
Sciphone 168 wont play music from media player
The Sci Phone is very iffy about reading stuff. It works more efficiently by plugging your phone directly to your computer using the usb plug. The songs must be in the "mp3" folder to play on the equipped audio player.
Aug 03, 2009 | AT&T CECT Unlocked i68+ Quadband GSM FM...
How do I insert batteries in the music box
if it's a long slim hole try use the coin.
Good luck
Jun 14, 2009 | Graco Pack 'n Play
I can't turn it on and i don't know how to charge it up. I don't know how to downloads songs.
I guess you are new to the world of Mp3 Players. These are the basic accessories which belong to any Mp3 Player Box Pack.
1. Mp3 Player.
2. USB Cable/Charger
3. Manual.
A USB Cable is some thing like this.
the bigger end of the cable goes to the USB Port of the computer, and the smaller end of the cable goes to the Mp3 Player. This process is for charging the Mp3 player as well as loading any songs in to the player. After you insert these into the Mp3 player, windows opens the player, and then you can load music files into it. I hope this solves your problem.
Mar 17, 2008 | Audio Players & Recorders
Downloading music from computer
easy. plug in the USB cable into your PSP and the other (big) end into your computer. on the PSP home menu, go all the way to the right and select USB mode. YOU NEED A MEMORY CARD INSERTED. click open and explore files if somthing pops up on your computer. if not, go to my computer, then memory stick K (or what ever letter your compute shows). then if its not already there, make a new folder and call it MUSIC
then drag and drop / copy and paste your songs into that folder.
Nov 18, 2007 | Sony PlayStation Portable (PSP) Console
Magic Sing Along Consumer Microphone Logo
64 people viewed this question
Top Magic Audio Players & Recorders Experts
Michial Gueffroy
conquer111
Level 1 Expert
T-Comtech Repairs
T-Comtech Repairs
Are you a Magic Audio Player and Recorder Expert? Answer questions, earn points and help others
