Question about Netopia 2247NWG-VGx Wireless Router (2247NWGVGX)
Unlock netopia 2247 router
I've got the eircom netopia 2247 wireless router. But is seems to be locked as it does not eccept any user name and password. I've tried to reset it but same. Is it possible to unlock it?
Thanks in advance
P.S. I'm currently with another BB provader .
  • reg1979 Jun 05, 2008
    i have aircom modom and wont to youse it wite clearwire modom
  • serra baby
    serra baby May 11, 2010
    hello!
    are you referring to the router username and password or the wireless security username and password?
Well Netopia from eircom will sit on default username & password provided by eircom.
Only way you can use it with other provider is that you will need to update it with a new firmware from netopia's website !
Posted on May 29, 2008
  • Netopia Master
  • 6,487 Answers
If your talking about the password for the router user interface that is not working that resetting it again using a pen or a paper clip just press and hold the reset button for 30 seconds then that should bring your router to its default settings with the default username and password.
Posted on May 09, 2008
I purchased a Motorola Netopia 2247-62-10NA 4-Port Modem. I have followed the instructions and am unable to activate the internet. The instuctions ask for a user name and a password that is supplied by...
First make sure the dialling is done to the correct number - it will be listed in the contract papers.
Phone your ISP and request them to confirm you that those are indeed the correct username and password.
Sep 14, 2011 | Netopia 2247NWG-VGx Wireless Router...
HOW TO set up PORTFORWARDING ON NEOTOPIA 2247
Since your router is Netopia 2247NWG-VGX follow this on line guide, choose the application you need to forward to and make all the settings you need.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Aug 12, 2010 | Netopia 2247NWG-VGx Wireless Router...
Netopia 3347nwg wifi locked!!!
Hello michael,
The lock you see indicates that the network you are trying to connect to requires a password for authentication.
You can access your ipod settings and enter the credentials by following the below steps:
1- First connect to your closed Wi-Fi network
2- Choose Wi-Fi, then tap Other and enter the network name.
3- Choose Security, tap the type of security the network uses, and enter the password.
This should be it.
Have a good day.
Mar 15, 2009 | Netopia 2247NWG-VGx Wireless Router...
Netopia 2247NWG for smarttelecom
Sorry if my writing is not clear I dont have best english.
If you move your router from eircom to smartelecom you have to change security protocol from "chap" eircom to "pap" smarttelecom.
Now Do this few steps.
Go to start menu on windows find and click run.
type: cmd and press ok
When you will see black screen that will be command prompt.
Now you have to type your defaul ip adress. To check your defaul ip adress type ipconfig in command prompt and press enter.
Default Gateway is your default ip adress. Now when you know your ip type in command prompt:
telnet yourip 23 and press enter, for example:
telnet 192.168.1.254 23
If you didnt setup any password to login to the router you will be loged automaticly and you will see "Netopia-2000/18861188>
But if you have setuped login and password to your router you have to first type your login and press enter,then password and press enter to have acces.
next is easy type:
configure and press enter
ppp and press enter
set and press enter
now you have to pressing enter about till you will see line:
option <chap-only> [ off : on : pap-only : chap-only ]:
on this line type pap-only and press enter
now start pressing enter till you see:
Netopia-2000/18861188 <ppp>>>
then type save and press enter.
When you see line:
Configuration data saved you can close command prompt window.
From this moment your router will be work with smarttelecom.
Dec 13, 2008 | Netopia 2247NWG-VGx Wireless Router...
Netopia 2247 NWG can't find Atheros AR5007EG WLAN
ok heres the solution.
goto start,control panel,performance and maintainance,administrative tools,services.
Scroll down to bottom to WIRELESS ZERO CONFIG,double click and click start.
now exit and wait a minute and your limited or no connectivity should change to connected,
let me know if this helps,
Patrick.
Aug 02, 2008 | Netopia 2247NWG-VGx Wireless Router...
How can i unlock my router?
Firstly... avoid showing your SSID (eircom-123456789) here, as the WEP key can be reverse engineered from the SSID.
To change your SSID, connect your router to your PC with an ethernet cable, go to your web browser (Intenet Explorer, Forefox, etc) and type 192.168.1.254, and press return.
This will open the control panel for the router.
Select 'EXPERT MODE' from the menu on the right, and accept the warning prompt. Then click on 'CONNECTION' and the 'WIRELESS' on the menu on the right.
In the main window you can then change the SSID for your network.
You can also change some of the other options in this window such as enabling closed mode, change security protocol, password, etc.
Feb 13, 2008 | Netopia 2247NWG-VGx Wireless Router...
How can i unlock netopia 2247NWG
Feb 10, 2008 | Netopia 2247NWG-VGx Wireless Router...
Netopia 2247NWG-VGx Wireless Router (2247NWGVGX) Logo
2,345 people viewed this question
Top Netopia Computers & Internet Experts
Douglas  Erikson
Douglas Erikson
Prashant M
Prashant M
John Hong
John Hong
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
