Question about Jandy Lite 2 Natural Gas Pilot Light Heater
FL 4 code Hot surface igniter problem on Jandy Lite 2 - FixYa
    Top Expert:
  • Jandy Master
  • 8,163 Answers
Check the fuses from the red wires if blown replace if ok replace ignitor
Posted on Jan 30, 2016
4 Suggested Answers
  • 21 Answers
SOURCE: FL 4 error, Jandy Lite 2 pool heater
I believe you may have a draft restriction and this may stop the start up diagnostics. The draft detection switch is sometimes restricted or weak. Common problem. Tap the gas valve to see if the winter has caused the valve to seat heavily and stick.
Posted on Apr 25, 2010
john224
  • 1378 Answers
SOURCE: Jandy Lite 2 pool heater
Thank you for posting your question here on Fixya.com.
Page 34 and 35 of your manual, found here, describe FL0 as a flow issue most likely caused by dirty filters. Depending on the type of filter you have a good cleaning/backwash will usually remedy that. It is also possible the unit's pressure switch, which senses water flow and therefore reacts to dirty filters when present, may have failed, especially if you winterize the heater in a cold climate and leave water in the switch which can burst the diaphragm inside.
Start with cleaning the filter. If the heater still won't fire jump out the pressure switch while the pump is running to confirm the part is the problem. Assuming it is replacing it with a new pressure switch which should be under $75. The part number can be found in the rear of the manual.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Posted on Apr 29, 2011
  • 36 Answers
SOURCE: jandy lite 2 heater model
Igniter circuit is open. Check fuses on igniter wires. Identify and correct loose or broken wires.
Element has a fine crack in it. Replace
Igniter fault. Replace igniter.
Posted on Aug 31, 2011
What part failure produces error code FL 4?
igniter failure. this is a problem with either the hot surface igniter, or the main circuit board. if the problem is the board you must replace the high voltage chip along with it
Aug 18, 2014 | Jandy Lite2 Heater LJ175P - 175,000 BTU LP
Jandy Lite 2 heater won't ignite FL4 code?
So, you replaced part R367100 (Igniter)? This part if very susceptible to failure if touched. I would inspect and/or run a continuity check to make sure it has non cracks. Does it glow red when you attempt to start the heater? Remember, that is the how it ignites the flame, by getting red hot.
If it glows red hot, but does not light then I'd do the following testing in between;
Check that the inline fuses on the igniter aren't blown,
Check if the control board is sending a charge,
Check the flame sensor for gunk build up. Unfortunately to replace the flame sensor look like you have to purchase a whole new burner assembly to get a new flame sensor.
I also believe there is a toggle switch on the front door. It may need to be depressed before the system will ignite.
May 10, 2014 | Jandy Lite 2 Natural Gas Pilot Light...
Jandy lite 2 heater model lj325n - code fl4 - hot surface igniter problem- I tapped the gas valve and checked the fuse , still getting the same code.
Aug 31, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
Fl 4 code
fl4 = Igniter Failure
A. Igniter circuit is open: Check fuses on igniter wires
B. Element has a fine crack in it: Replace igniter
C. Igniter fault: Replace igniter
Apr 09, 2011 | Jandy Lite 2 Natural Gas Pilot Light...
JANDY LITE2 LJ HAS A FL-2 CODE WHEN HEATER STARTS
check gas flow, check for cobwebs in gas orfices also check if 24 volts ac to the brown gas lead if not check safety circuit if so bad gas valve
May 31, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
fl 4 bad ignitor or bad fuses if fuses ok replace ignitor
Apr 01, 2010 | Jandy Lite 2 Natural Gas Pilot Light...
Jul 29, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Describe your Jandy Laars Lite2 Pool & Spa Heater - Electronic Dual Ignition - 125,000 BT Problem FL 4 code and have changed igniter and still getting the FL4 code its the lite 2 model...
A. Check fuses on igniter wires. Identify and correct loose connections or broken wires. B. Measure room temperature resistance and ensure value is in the correct range. See manual for details. C. Replace igniter.
Jul 04, 2009 | Jandy Laars Lite2 Pool & Spa Heater -...
Jandy heater not starting
FL 4 is igniter failure.
1. check the fuses on igniter wire as well as the wires.
2. replace igniter
Jun 13, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Jandy Lite 2 Natural Gas Pilot Light Heater Logo
105 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
