My wacom intuos4 is plugged in and a yellow light is on but the blue light isnt coming on and the express keys/touch ring won't work the but tablet area does. Ive only just got it. What might be wrong with it?
SOURCE: wacom 12 wx cintiq
I had the same problem at first but managed to solve it. In my case I was setting up in tandem with another monitor and once I had correctly set the pixel dimensions of both monitors and set them to to 'mirror' mode it works pretty well. The only issue now seems to be a slowing of stroke speed ie the cursor lags behind my strokes. I have downloaded a new driver but not installed yet. Does anyone else have this problem?
Posted on Aug 31, 2008
SOURCE: WIRE FROM WACOM TABLET NEEDS REPLACEMENT
Wacom will send you the wire for your tablet. Its only $15. You have to be very careful in opening the tablet in that the top and bottom are connected by a short flat wire leash someone eager to get all the way apart will permanently damage. If its out of warranty you have absolutely nothing to lose. Its very easy to replace. Replacing it fixed my problem caused by having the computer sitting on the corner of the wire for several months.
Posted on Jan 30, 2009
  • 78 Answers
SOURCE: need driver for an old wacom cte-430 tablet
Go to this page:
http://www.wacom.com/downloads/drivers.php
Choose Graphire 3 or Graphire 4 as your tablet model. These are the CTE models. Then pick your OS and download the driver.
-J
Posted on Sep 03, 2009
Testimonial: "Problem solved! thank you veary much"
SOURCE: Wacom Bamboo Fun Tablet-Mac. Yellow box pops up under pen cursor.
Your tablet is set under the handwriting setting. Go to system preferences and select ink under hardware. Then turn off handwriting recognition.
Posted on Feb 21, 2010
SOURCE: Wacom tablet stopped working, blue light on.
Hey I had this problem too with my Bamboo too, I'm not sure if it was anything I changed or whatever but either way the blue light was on but it wasn't registering the pen.
I found a way just minutes ago to fix it however!
Go into 'start', 'all programs', then look for 'pen tablet'. Hopefully you should have this. If not then download the latest driver for your tablet from the wacom website and that should install it.
Next choose 'pen tablet preference file utilty'. Then under 'my preferences' choose to remove. Bingo! All was well in the world again.
This worked for me so hopefully it will for some of you guys too! Good luck!
Posted on Jul 11, 2010
Why does my intuos tablet not respond
Can you set back an older version of XP? with restore under the configuration tab?
If possible one from before you installed your driver.
Take care with XP, because "bad" guys try to get access to any XP computer, not in the last place by offering drivers you don't need.
Nov 21, 2014 | Wacom Intuos4 PTK640 Graphic Tablet
My Wacom pen doesn't work. The blue light on the tablet turns green when I touch the pen to it, but the cursor doesn't move on the screen. I thought that the tip needed to be replaced, but after changing...
Does the mouse work (on the tablet)? What happens when the side buttons are pressed do they work? Try un-installing the Wacom driver (Pen Tablet Utility) and Install the latest version from www.wacom.com and see if that helps.
Mar 05, 2011 | Wacom Intuos3 Graphic Tablet
When I use my 21ux everything is slow and the pen touching the screen stops most times
Really the problem is you need to get a faster computer.
Once you do that, you can actually make the 21ux respond ultra fast by going to the Wacom Tablet properties program, then select "Functions" next to "Tool".
In the "Express Keys" tab that appears, the 3rd one down by default should say "Precision Mode..."
Open that (by clicking it, then again on the menu that appears) and move the Precision slider to ULTRA FINE.
This makes the wacom respond almost instantly.
Its available with the latest Wacom tablet drivers (6.1.6-7)
Apr 05, 2010 | Wacom Cintiq 21UX (CINTIQ21UXNR)
My computer suddenly won't recognize my wacom tablet--the blue power light doesn't even flash when I plug it in. I think it's a problem with my computer rather than my actual tablet, as the tablet...
Make sure driver is installed and there is not any ? mark or yellow ! mark in device manager.
Reinstall your tablet driver then check.
Uninstall all usb driver from computer.
Connect your tablet to computer then when you power up the computer press F8 key then enter in safe mode.
Make sure usb cable is works fine if you connect your tablet to computer with usb cable.
Let me know if you need further assistance.
Thanks for using FixYa.
Dec 07, 2009 | Wacom Computers & Internet
Pen doesn't work
It could be the drivers problem which does not support operating system. Please visit the vendor web site and get the drivers for 64 bit OS.
Aug 05, 2009 | Wacom (PTZ930AC) Graphic Tablet
Problems with the express keys
the driver wasn't loaded on my new system, so i went to the wacom website and downloaded the latest driver for the tablet
Jan 24, 2009 | Wacom Bamboo Fun 5.8" x 3.7" USB Tablet...
Since you are running Windows Vista on your PC this is the driver you should have downloaded.
Click Here
Serial cables are not hot swappable. The computer and tablet should be turned off before you plug them in.
Apr 10, 2008 | Wacom (PTZ930AC) Graphic Tablet
Computers & Internet Logo
149 people viewed this question
David Payne
David Payne
