Question about NetGear RangeMax WPN824 Router
How do I get the cable to connect to the internet? The cable supplied is an ethernet cable not a dsl cable and does not fit the microfilter. I keep seeing reference to a modem. What does this refer to? Do I need to buy something else?
  • 220 Answers
Ok, the phone line from the wall goes to your dsl model.
The ethernet plugs in the back of the modem and runs to the router.
Hope this helps.
Posted on Aug 27, 2010
Trying to connect to internet cant find wireless & cant find a ethernet place either
The laptop in question does not have a place to plug in the ethernet cable. The laptop is not fitted with wi-fi or bluetooth adapters either. The best and cheapest way to connect this laptop to the internet is using a PCMCIA Card Adapter (type two or three as both are supported.) such as the product supplied by linksys. If yours is similar to the one in the photo then it should include a cable with the required network connection on the end. The "linksys" card you mentioned is no doubt the correct one, but minus the vital cable!
May 20, 2016 | NEC Versa LX Notebook
A friend of mine has this D-Link DSL-2750U router & is trying to connect his cable internet to the router but failing to do so. We suspect it is a purely ADSL router & does not support ethernet connection...
You need a router which connects to ethernet..ADSL is connected by RJ45(Telephone connection) ... Many cable companies include a router in the Modem (Verizon) others need a router to do wireless which gets connected between the PC and the Modem . the DSL-2750U is well over $2000.00.. a normal wireless router is $50-$100... a regular router gets connected by ethernet to Modem and router ,, then has 4 other connectors .. ehternet to PC.. Also requires power supply. .. wireless has to be setup for the software.
Oct 28, 2013 | D-Link Computers & Internet
Won't connect to internest.
first there should be 2 cables connected the device.
1) power adapter
2) ethernet cable from either a dsl modem or a cable modem connected to the wan connector
with most cable modem service its usually dhcp meaning you are always connected to the internet
with some there is ppoe connection where a user name and password is used to make a connection to be on the internet with the dsl modem
there are some dsl companies that are dhcp just like the cable modem companies.
with the ethernet cable connected the wan port on your router there should be some kind of activity light on the router but check with the type connection from your dsl or cable internet provider. also you will need a second ethernet cable to connect your computer to setup and configure the wireless settings and wep protection.
need more info?
Aug 24, 2011 | NetGear WNR2000 Wireless Router
How do i connect to the internet
Well, first you need to have an internet connection. DSL, CABLE, etc. Your internet service provider will supply you with a modem. On the back of the modem you will find an ethernet port. It is a rj45 jack which is wider than telephone. An ethernet cable, usually yellow or blue, is supplied with the modem. This cable plugs into the ethernet port on your computer. This gives you internet capability. All you have to now is open a browser.
Feb 06, 2011 | Panasonic Toughbook 71 Notebook
Followed all the set up steps but my DSL light would not stay on
  • 1 Plug the Ethernet cable into the Internet port on your wall. If you do not have Internet ports installed in your home, connect a phone line adapter to a phone line jack. The adapter makes the phone line wider so Ethernet cables can connect to it. This does not block your phone from use.
  • 2 Plug the other end of the Ethernet cable into the Internet port on the back side of the Netgear DSL modem.
  • 3 Connect the Netgear DSL modem to a local power source. The power plug inserts into the modem via a small port on the rear of the modem.
  • 4 Insert a second Ethernet cable into one of the numbered ports on the back of the modem. Run the cable to your computer and plug it into the Ethernet port on the computer.
  • 5 Look on the back end of the DSL modem for an HTTP: address. Type this into your Internet browser's search bar. The Netgear DSL modem menu appears on the screen.
  • 6 Select how many computers are to use the modem, if you are using it with other DSL modems and set up a password (the default username and password is "admin"). Click "OK" to initiate the changes you made to the menu. You can now use your Netgear DSL modem to connect to the Internet.
  • Read more: How to Install a Netgear DSL Modem ' eHow.com http://www.ehow.com/how_5886784_install-netgear-dsl-modem.html#ixzz10lH4dl2y
    Sep 27, 2010 | NetGear DGN2000 Wireless Router
    Ethernet light keeps blinking
    I think the light that blinks is the light that shows when you have a connection established to your ISP. Not sure if you have cable or ADSL but if the light is blinking then the router is Synchronising with the line card at the ISP/exchange end. If it continues to blink then no sync is occurring. If ADSL replace the microfilter and check that any devices atached to that line also have a microfilter between them and the socket. ALso try replace the phone cable to the microfilter to the socket. Finally you can see wether sync has occurred by looking in the log on the router
    Hope this helps
    Mark
    Aug 26, 2009 | Westell Wirespeed VersaLink...
    Cannot connect to internet. I had internet connection over telephone modem before Hard drive crashed. I replaced HD and could not connect to internet. Dell was no help at all. I signed up for Verizon DSL...
    I bet you are using the phone modem that canme in your machine. You need to connect the Network card ( Ethernet Card) and make sure the drivers are working. Find it is System, Hardware, device manager, look for ethernet.
    Connection icon and see if the netcard driver is installed.Connect the cat5 cable that was sent to you with the DSL modem box. It chould be a yellow cable... It only fits one way and in a maked plug on the DSL modem and into the network card in the computer. Everything there after should go automatically.
    Jul 24, 2009 | Dell Dimension 4700C PC Desktop
    I don't know how to connect my router. please help
    If you have DSL or cable internet, disconnect the ethernet cable going from the DSL or cable internet modem to the computer. Disconnect the end of that cable that plugs into the modem. Connect an ethernet cable from your cable or DSL modem to the router where it says something like "modem", "internet", or "in". If the router is a wired router, connect the ethernet cable that is still attached to the computer to any open ethernet port on the router.
    Jul 15, 2009 | D-Link DI 514 Wireless Router (DI-514)
    No internet signal between router and desktop pc.
    have you plugged everything in with the modem off and the router off?
    have you tried unplugging the linksys for a sec then plug it back in?
    also have you checked the pin connection on the plug on both the computer and the router?
    what are the lights indicating?
    Oct 14, 2008 | Computers & Internet
    How do I connect my cable/DSL line to this device?
    The 3Com® OfficeConnect® Cable/DSL Gateway does not have an internal cable or DSL modem. The gateway router is designed to connect to the Ethernet output from your cable or DSL modem. An Ethernet cable is supplied with the product for this purpose.
    Feb 16, 2006 | 3Com (3CR856-95-UK) Firewall
    NetGear RangeMax WPN824 Router Logo
    24 people viewed this question
    Top NetGear Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
