Streaks appear to the right of icons and text boxes. How do I fix this?
  • 3,940 Answers
Generally an indication of a failing video card. Try updating the BIOS and the video driver, if not effect, replace the video card. In some instances, I've seen where both the motherboard and video card had to be replaced to avoid cascade failure (On part damaging the other)
Posted on Aug 28, 2010
What does f1to12 do
the "f" keys are called "Function Keys" some have "universal" functions - F3 will bring up a "find text" function in most programs and "F5" will refresh the screen/web page etc. The other "F" keys get functions assigned by the program you are using at the time. You can also assign an un-used "F-key" to a deskop shortcut by right-clicking the icon, selecting "Properties" then click in the text box next to "Short cut key" then - Press the F-key you want to use as a shortcut for that Icon. (F number should appear in the text box). Click "save" or "OK" and close the Property box. Now press the F-Key you programmed into the Icon - it should execute whatever the Icon is for.. And that is was the F-keys do.
Feb 03, 2015 | HP Compaq nc6140 PC Notebook
This started out as error 5200. Now, my Canon MX340 printer isn't connecting to the computer. The computer acts like the printer hasn't been installed. I tried to remove the printhead and restart...
Issue: How do I align the print head?
Solution: Perform a Print Head Alignment (Windows)- MX340
Aligning the Print Head Position Print head alignment corrects the installation positions of the print head and improves deviated colors and lines. The procedure for performing print head alignment is as follows:
alignike.gif Print Head Alignment
  1. Open the printer driver setup window
    • In Windows Vista, select the Start menu -> Control Panel -> Hardware and Sound -> Printers.
    • In Windows XP, select the Start menu -> Control Panel -> Printers and Other Hardware -> Printers and Faxes.
    • In Windows 2000, select the Start menu -> Settings -> Printers.
  2. Right-click your model name icon, and then select Printing Preferences from the displayed menu.
    The printer driver setup window appears.
  3. Click Custom Settings on the Maintenance tab.
    The Custom Settings dialog box opens.
  4. Check the Align heads manually check box.
  5. Click Send, and click OK when the confirmation message appears.
  6. Click Print Head Alignment alignike.gif on the Maintenance tab The Start Print Head Alignment dialog box opens.
  7. Load three sheets of A4 size or Letter size plain paper into the rear tray (3).
  8. Execute head alignment Make sure that the machine is on and click Align Print Head.
    Follow the instruction in the message.
  9. Check the printed pattern
    Enter the numbers of the patterns with the least amount of streaks in the associated boxes.
    Clicking the patterns with the least amount of streaks in the preview window, will automatically set their numbers in the associated boxes.
  10. When you have entered all the necessary values, click OK.
    Note:
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable vertical white streaks.
      (A) Less noticeable vertical white streaks
      (B) More noticeable vertical white streaks
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal white streaks.
      (A) Less noticeable horizontal white streaks
      (B) More noticeable horizontal white streaks
  11. Confirm the displayed message and click OK.
    The second pattern is printed.
    Important: Do not open the Scanning Unit (Cover) while printing is in progress.
  12. Check the printed pattern
  13. When you have entered all the necessary values, click OK.
    Note:
  14. Confirm the displayed message and click OK.
    The third pattern is printed.
  15. Check the printed pattern
    Enter the numbers of the patterns with the least noticeable horizontal stripes in the associated boxes.
    Clicking the patterns with the least noticeable horizontal stripes in the preview window, will automatically set their numbers in the associated boxes.
  16. When you have entered all the necessary values, click OK.
    Note:
    • If it is difficult to pick the best pattern, pick the setting that produces the least noticeable horizontal white stripes.
      (A) Less noticeable horizontal white stripes
      (B) More noticeable horizontal white stripes
Note: To print and check the current setting, open the Start Print Head Alignment dialog box, and click Print Alignment Value.
Aug 11, 2011 | Canon PIXMA MX340 Wireless Office...
Hi When I write text in messenger, I press enter but my text does not appear in the chat box Any clues? Thanks Michael
This is all I can think of. Is there any chance that your text color is set to white?
The way to check the text color setting is to click on the text icon (a capital T with a box around it). And then click on the little color palette icon and check to see what color is selected.
Also changes in settings some times require you to close and open a window to take effect.
Restart the program to see if that helps.
HTH
Jun 16, 2011 | Yahoo Messenger
How to change icon size on laprop
Try to go to this link, on how you change icon size.
http://www.techtalkz.com/windows-7/516049-how-change-font-size-icon-size-windows-7-a.html
AnEspera
Apr 18, 2011 | Computers & Internet
I downloaded free open office and can see it in my download box but cant see the icon on the desktop so i cant use it, what am i doing wrong? i use a compac presario laptop with windows vista.
Click the start button and in "Start Search" text box type open office.
If it has been installed it will show up in the search list.
Right Click the icon and a sub menu will appear. From the sub menu hover mouse over "Send To" and options will appear to the right. select "Desktop (create shortcut)".
Desktop icon should now appear from which you can run Open Office.
Congratulations on using Open Source alternative to MS Office!
Hope this helps.
Dec 09, 2009 | Cell Phones
The color streaks on the pages
There are several possibilities...
1.The Type setting is wrong for the type of paper or specialty media you are using. Change Paper Type to match the paper or specialty media you are using.
2.The Texture setting is wrong for the type of paper or specialty media you are using. Change Paper Texture from Normal to Smooth or Rough.
3. The Weight setting is wrong for the type of paper or specialty media you are using. Change Paper Weight from Plain to CardStock (or other appropriate weight).
4. The fuser is worn or defective. Replace the fuser.
Oct 14, 2009 | Lexmark C760 Laser Printer
I want yahoo mail to be my home page
In IE goto Tools > Internet Options > enter http://mail.yahoo.com in the Home page text box Click Apply
In Safari goto Settings (icon on the right/wheel) > Preferences enter http://mail.yahoo.com in the Home page text box Close the window
In Google Chrome go to Settings (icon on the right/spanner) > Options click the Basics tab and enter http://mail.yahoo.com in the Home page text box Click Close
Sep 23, 2009 | Yahoo Mail
Vertical Light Streaks on text documents, both single and duplex
Clean the glass thoroughly using Isopropyl alcohol. Dont use solvents. Check if there is any scratch on the glass. Repeated scanning with stapler pins can scratch the glass. If it is scratched, you may need to chage it.
S. Mohan, India
Mar 11, 2009 | Panasonic KV S2025C Path-Through Scanner
Pictures scanned with Canon 4200f show streaks
when scanning photos and especially magazines, don't go to low on the dpi (at least 300) and select DESCREEN as well as grain correction: HIGH
Dec 31, 2008 | Canon CanoScan 4200F Flatbed Scanner
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
