Question about Kenmore 73952 Gas Dryer
The door will not stay closed when drying - Kenmore 73952 Gas Dryer
  • Kenmore Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
The door latch is broken...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Sep 12, 2010
My dryer door won't stay shut while drying
Dryers have a Door latch that is female and the strike that is male. When the door is closed, the door latch hooks up to the strike and keep the door closed. PLEASE inspect these items. Also, make sure that the door is loose from the screws that hold it to the body.
Dec 03, 2014 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Dryer door opens during drying cycle, had it "repaired" but still opening - worked originally well for about 2 years - but cannot get it to stay closed for the entire drying cycle.
these newer dryers are such garbage with their thin Sheet metal. see if the door is bent by the hinges. Dropping clothes on the doors bend these newer machines. then they don't seat correctly
Aug 05, 2013 | Kenmore Elite HE4 Electric Dryer
Dryer door won't stay shut when drying clothes
There is a clip inside your dryer door that acts as snap (kinda like on baby clothes). It snaps the door closed - so to speak. If the outer part of that 'snap' gets a little stretched out it will not hold as tightly. When those heavy, wet clothes hit against the door it pops it open because the 'snap' is not working right. As long as the outer part of the 'snap' is still intact, you can fix this problem by simply squeezing it together alittle to make it grab tighter so that the door stays closed while drying your clothes. If that doesn't make it tight enough you could tear off a small corner of a paper towel to fill in the hole a little to make it tighter.
Hope this info was helpful to you. Good Luck!
Jan 29, 2010 | Whirlpool Dryers
The dryer door will not stay closed. It will actually close but it will not stay closed therefore it stops during the cycle. It we prop something against the door it will stay closed and a full drying...
Go to www.appliancepartspros.com do a search using the model number and you will find the schematics for the dryer. Look for the cabinet parts diagram and locate the latch assembly. Look for the door latch and the door catch both parts will probably cost less than $10. There may be some minor disassembly required but not a big ordeal.
Nov 22, 2009 | Dryers
Lights stay on constantly even when not running; does not run aft
That clip is necessary as it tells the dryer when the door is open and when the door is closed. you will have to get a new door switch.
Jul 04, 2009 | Dryers
Kenmore dishwasher 665 15752 wont cycle right
Sound like door/latch is not providing a secure door close anymore. Push on the door when the lights flash and see if this stops the blinking and continues with wash cycle. If it does, there is either somehing interfering withe the door closing fully, or the door latch on the door or dishwasher side is worn/defective.
Feb 22, 2009 | Kenmore Dishwashers
Dryer door pops open. leaves burn marks on clothes.
check to see if you have bent door hinges first, do this by opening the door all the way down and see if it is level with the floor. if it goes past level then the hinges are bent.
guess someone may have fell on the door or used it as a step.
if so, then you can take a hand towel and roll it up, then put it at the bottom of the door and close the door gently to "bend" the hinges back into place. this will aloow the door to stay closed and should also take care of the "burn" marks on your clothes.
i would guess the unit was overheating from the door not closing right allowing air to enter around the door. that will cause the unit to overheat and leave marks on your clothes.
Dec 28, 2008 | Kenmore 63942 Dryer
Sub-zero 500 series refrigerator door wont stay closed
If Your Refrigerator's Freezer Door Pops Open When You Close the Fresh Food Door... If a 'top-freezer' refrigerator's freezer door pops open when the larger fresh food door's closed, it's actually a good thing. That tells us the seals are in great shape, sealing well.
Some freezer door 'pop' is unavoidable bc the bottom door's so much larger than the top one and the hydraulic effect of compressing all that air kicks in. The two compartments share the same air via a duct between them, and that compressed air rushes up into the freezer compartment and can 'pop' the door.
To improve the situation, apply a few drops of oil (sewing machine oil or 'three in one' - NOT WD-40) to each freezer door hinge pin. (Even better: if you can, pull the doors and coat the hinge pins with petroleum jelly). This will help the freezer door swing back closed by itself. The freezer door usually stays ajar because it's binding a bit, and that's usually caused by it's swinging 'dry', with no lubrication.
It’s also a good idea to ‘kick’ the habit of letting the refrig door close hard.
Sep 04, 2008 | Refrigerators
Not Drying
I found that if the rinse agent (Jet Blue) has run out the dishes stay wet.
Aug 21, 2008 | Bosch SHU3305 Dishwasher
Kenmore 73952 Gas Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
