Question about Refrigerators
FREEZER IS -2 WHILE THE FRIGE IS 62. - Refrigerators
  • Refrigerators Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 28, 2010
Frige not cooling on bottom freezer frige
Check the air vents, from the freezer to fridge. Air travels through those vents. Sometimes, products get shoved under the vents, preventing air flow. It sounds like, the vents are clogged with something. I guess, the fan is working inside, of the freezer? Ice in the bottom, of the freezer pan, could be clogging the vents. You'll have to dig deeper. Good luck.
Aug 16, 2014 | Kenmore Refrigerators
Frige temp went up to 62 and won't come back down to 40. Try resetting and unplugging several times. Suggestions?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 25, 2010 | Samsung RS267LBBP 26.1 Cu. Ft. Side by...
I have double door refrigrator and have cooling problem in lower portion
i am haven the same issue but lol mine is at the top i found out what it is the frige has no motor if u look closly you will see holes from the freezer side to the frige side that is what cools the frige. ur freezer needs 2 be defrosted by pulling evrything out then the back panel needs to be pulled out as well from the inside of the freezer and u may have to buy a heating element is what i did and it worked for a year now haven same issue lol but this time it is my thermastat i hope
Aug 15, 2010 | Refrigerators
Our Kitchenaid KBFA25ERSS01 freezer suddenly does not stay at 0 degrees. Fluctuates between 2 degrees and 12 degrees.
Sounds to me like you could have some serious problems. What you're seeing could be either the result of faulty electronics (i.e. the thermostat) or an even larger problem with the refrigeration system itself.
About the only thing that I could think of that could be repaired by the user would be the door seals if those are leaking. Anything more intensive than that though and your best bet is to contact a service person.
Jul 29, 2009 | KitchenAid Refrigerators
Freezer is cold but frige not at all even on 9
deforst you frige mean take out every thing and off your frige long perod.then agan start emte frige.allmost 2 H
Jul 20, 2009 | GE CleanSteel GSL25JFTBS
Frige freezing solid
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jul 03, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
10 year old frige leaking water from the freezer onto the floor
drain tube is plugged the fridge goes into defrost about every 8 hours use a hair dryer to melt the ice and check the drain tube goes to the pan by the compressor
Jun 30, 2009 | Refrigerators
Frige
check to see if the air chamber between freezer and frige is not blocked with ice or something else
Apr 13, 2009 | Kenmore 64812 / 64814 Top Freezer...
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
My freezer is working but my frige is not cooling
wrong model # ,defrost problem. remove freezer panel, check heater, check limit switch while still covered in ice, if both ohm infinity, replace defrost timer.
Sep 15, 2008 | Haier HTP18GAA Top Freezer Refrigerator
Refrigerators Logo
18 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
